DASM question about ORG/RORG
PacManPlus
I am using bank switching in my PMC_XM game, but I'd really like to put code in some of the banks (right now I'm using it for tables, graphics, and data only).  The only issue I see is addressing.
I am compiling the main program (fixed at $C000-$FFFF) separately from the banks (7 banks switchable from $8000-$BFFF).  However the banks are listed from $0000-$1BFFF to compile (like I did for Bentley Bear).  I am assuming when I compile them, any direct jumps (JMP, JSR) are going to use the $0000-$1BFFF addresses and not the $8000-$BFFF for each bank (as it doesn't know about them).
Is there a way to either: a) Force DASM to compile the banks as repeating $8000-$BFFF blocks, or b) Combine the source code for the main program and 'DataBanks' (BTW, excellent unreleased Prince song of the same name), compile them together and tell DASM to use $8000-$BFFF for each bank before $C000-$FFFF?
Thanks, guys
Bob
Edited by PacManPlus
Option a) is a little easier, for each bank you can do something like this...
	SEG	OBJ_STAGE_F
	ORG	ADDR_OC_STGF,EMPTY_FILL
	RORG	BANK_SWAP
BANK_THIS	SET BANK_OC_STGF
	INCDIR	"./SUB/OBJ_Over"
	INCLUDE	"ANI_OverMis.asm"
	INCLUDE	"OBJ_OverMis.asm"
	INCDIR	"./SUB/RBX"
	INCLUDE	"ANI_Fiddler.asm"
	INCLUDE	"OBJ_Fiddler.asm"
	INCDIR	"./SUB/RMX"
	INCLUDE	"ANI_Launcher.asm"
	INCLUDE	"OBJ_Launcher.asm"
	INCLUDE	"ANI_Pipe.asm"
	INCLUDE	"OBJ_Pipe.asm"
	INCLUDE	"ANI_Laser.asm"
	INCLUDE	"OBJ_Laser.asm"
	INCLUDE	"ANI_Sentry.asm"
	INCLUDE	"OBJ_Sentry.asm"
	INCLUDE	"ANI_FoxBot.asm"
	INCLUDE	"OBJ_FoxBot.asm"
	INCDIR	"./SUB/OBJ_Glue"
	INCLUDE "ANI_GoodEnd.asm"
	INCLUDE "OBJ_GoodEnd.asm"
BANK_USED	SET (* - BANK_SWAP)
ROM_USED	SET (ROM_USED + BANK_USED)
	ECHO "[OC] OBJ_STAGE_F   :",BANK_USED,(BANK_SIZE - BANK_USED)
	REND
Where BANK_SWAP = $8000 (start of bank from Sally's view), ADDR_[NAME] is the start of the bank in ROM, and BANK_[NAME] is the bank number. The value of BANK_THIS is changed at the start of each bank definition so that any object code will use this instead of a fixed bank number. This makes it easier to "defragment" objects later on.
  • Like 4
  • 3 months later...
Bump!
Thanks for the tip, TailChao.
If I need to put certain things at specific addresses within a bank, must I use both ORG and RORG every time? That is unwieldy. I could use ALIGN, but then dasm won’t detect overflows, so I’d want to add macros to do that, which is getting back to unwieldy.
And out of curiosity, does anybody else think of RORG addresses as virtual and ORG addresses as physical? Or is there some other terminology people use here?
If you're creating labels to access this data, then yes - ORG and RORG or ALIGN it. Don't forget you can do math in the ORG and RORG directives to make this a little cleaner, something like ORG (ADDR_CD_STG2 + SS_A).
Yeah, RORG is creating the logical addresses for your resources and ORG is generating the physical addresses in ROM (or other storage).
