+Karl G Posted April 3, 2020 Share Posted April 3, 2020 I am able to test AtariVox speech on the 2600 side via Stella with my AtariVox attached to my MacBook via a 2600-daptor II flashed with firmware to support the AtariVox specifically. Is it possible to get this to work using any available emulator for the 7800? 1 Quote Link to comment https://forums.atariage.com/topic/304780-atarivox-device-communication-via-emulator/ Share on other sites More sharing options...
RevEng Posted April 3, 2020 Share Posted April 3, 2020 Not presently. I have a few more to-do's than hobby time lately, but after I work through them I'll look at the possibility of adding exernal atarivox support to a7800. 2 1 Quote Link to comment https://forums.atariage.com/topic/304780-atarivox-device-communication-via-emulator/#findComment-4499804 Share on other sites More sharing options...
+stephena Posted April 3, 2020 Share Posted April 3, 2020 13 minutes ago, RevEng said: Not presently. I have a few more to-do's than hobby time lately, but after I work through them I'll look at the possibility of adding exernal atarivox support to a7800. It's relatively easy to add support. These are the applicable files from Stella: https://github.com/stella-emu/stella/blob/master/src/unix/SerialPortUNIX.cxx (serial port settings) https://github.com/stella-emu/stella/blob/master/src/emucore/AtariVox.cxx, https://github.com/stella-emu/stella/blob/master/src/emucore/AtariVox.hxx (specific stuff for speech) https://github.com/stella-emu/stella/blob/master/src/emucore/SaveKey.cxx, https://github.com/stella-emu/stella/blob/master/src/emucore/SaveKey.hxx (specific stuff for SaveKey) https://github.com/stella-emu/stella/blob/master/src/emucore/MT24LC256.cxx, https://github.com/stella-emu/stella/blob/master/src/emucore/MT24LC256.hxx (I2C code for EEPROM) For just the sound output, you only need the first two. 1 Quote Link to comment https://forums.atariage.com/topic/304780-atarivox-device-communication-via-emulator/#findComment-4499815 Share on other sites More sharing options...
RevEng Posted April 3, 2020 Share Posted April 3, 2020 Thanks! Totally aware of those, as I did a lot of compare and contrast with the stella code when getting speakalator to work under MacOS, so double-thanks are in order. The update is still a bit of chore, even with the example code. a7800 is a fork of the MAME a7800 driver, and half of the work in these sorts of additions is figuring out how the interfaces in question are supposed to be coded within the MAME framework. The api documentation often doesn't exist, and instead you wind up having to learn from similar implementations in other drivers, if you're lucky enough that similar implementations exist. Quote Link to comment https://forums.atariage.com/topic/304780-atarivox-device-communication-via-emulator/#findComment-4499822 Share on other sites More sharing options...
+Karl G Posted April 3, 2020 Author Share Posted April 3, 2020 Thanks, and no worries; I suspected that was probably the answer. I can develop speech via Stella and 2600 apps, and import the data into my 7800 project for now. 1 Quote Link to comment https://forums.atariage.com/topic/304780-atarivox-device-communication-via-emulator/#findComment-4499840 Share on other sites More sharing options...
+stephena Posted April 3, 2020 Share Posted April 3, 2020 26 minutes ago, RevEng said: Thanks! Totally aware of those, as I did a lot of compare and contrast with the stella code when getting speakalator to work under MacOS, so double-thanks are in order. The update is still a bit of chore, even with the example code. a7800 is a fork of the MAME a7800 driver, and half of the work in these sorts of additions is figuring out how the interfaces in question are supposed to be coded within the MAME framework. The api documentation often doesn't exist, and instead you wind up having to learn from similar implementations in other drivers, if you're lucky enough that similar implementations exist. I understand. There's probably only 200 lines of relevant code from Stella that you'd need (ignoring the SaveKey stuff). I just meant the code itself is fairly easy and straightforward. Integrating it into another project (particularly one like MAME that is so large) is another story. Good luck Quote Link to comment https://forums.atariage.com/topic/304780-atarivox-device-communication-via-emulator/#findComment-4499851 Share on other sites More sharing options...
RevEng Posted April 3, 2020 Share Posted April 3, 2020 Thanks Quote Link to comment https://forums.atariage.com/topic/304780-atarivox-device-communication-via-emulator/#findComment-4499857 Share on other sites More sharing options...
+Karl G Posted April 5, 2020 Author Share Posted April 5, 2020 While I'm on the topic of AtariVox speech, is it valid syntax to spread the speechdata over multiple lines? E.g.: speechdata hey_cabbie_2 raw 31 raw 21,120,22,150,183,130,22,180,8,154,22,150,2,194,22,180,132,132,132,22,150,172,170,128 raw $FF end Quote Link to comment https://forums.atariage.com/topic/304780-atarivox-device-communication-via-emulator/#findComment-4501537 Share on other sites More sharing options...
+SmittyB Posted April 5, 2020 Share Posted April 5, 2020 Yes, that's okay to do. When it's compiled it's basically a straight conversion to '.byte' statements for the assembler and then when that does its thing it doesn't care how the data is formatted so use as many lines as you want to keep things organised. On a related note.... oh boy how did I not know the 2600-daptor was a thing? Here's me spending time making my own tools to do the same thing with more effort like a chump. 1 Quote Link to comment https://forums.atariage.com/topic/304780-atarivox-device-communication-via-emulator/#findComment-4501569 Share on other sites More sharing options...
+Karl G Posted April 5, 2020 Author Share Posted April 5, 2020 1 hour ago, SmittyB said: Yes, that's okay to do. When it's compiled it's basically a straight conversion to '.byte' statements for the assembler and then when that does its thing it doesn't care how the data is formatted so use as many lines as you want to keep things organised. Thanks! 1 hour ago, SmittyB said: On a related note.... oh boy how did I not know the 2600-daptor was a thing? Here's me spending time making my own tools to do the same thing with more effort like a chump. But you probably saved money, and the pride of accomplishment when you got it to work. ? 1 1 Quote Link to comment https://forums.atariage.com/topic/304780-atarivox-device-communication-via-emulator/#findComment-4501619 Share on other sites More sharing options...
+SmittyB Posted April 5, 2020 Share Posted April 5, 2020 10 minutes ago, Karl G said: But you probably saved money, and the pride of accomplishment when you got it to work. True, but my solution was to write Voxolotl! so I have to faff around with controller commands to build something that sounds good, and then write down or photograph the output to copy manually into my game. I'd much rather have some way to do it all from my PC. Quote Link to comment https://forums.atariage.com/topic/304780-atarivox-device-communication-via-emulator/#findComment-4501644 Share on other sites More sharing options...
+Muddyfunster Posted July 19, 2020 Share Posted July 19, 2020 @Karl G Trying to copy your atarivox setup. To connect to Stella, in addition to the AtariVox, I just would need the 2600daptorII but flashed to AtariVox support firmware? Is that just a case of running a flashing program or does it require anything funky like an ST2 cable like early firmware UNOcart? Do I need to grab anything else? Thanks! Quote Link to comment https://forums.atariage.com/topic/304780-atarivox-device-communication-via-emulator/#findComment-4588905 Share on other sites More sharing options...
+Karl G Posted July 19, 2020 Author Share Posted July 19, 2020 @Muddyfunster - Correct, and it is just a matter of running the flashing program. Here's the page with info on how to do the firmware update: http://www.2600-daptor.com/AtariVox-daptor.htm Other than that, it's just a matter of setting the correct COM port in Stella as described on that page. 2 Quote Link to comment https://forums.atariage.com/topic/304780-atarivox-device-communication-via-emulator/#findComment-4588920 Share on other sites More sharing options...
+SmittyB Posted July 19, 2020 Share Posted July 19, 2020 I got one recently and did the same. It's dead easy, the hardest part was finding a paperclip in my drawers with which to bridge the necessary pins. The one difference from the guide is that there wasn't a connector on the board so it was just a matter of pushing the paperclip in the right through-holes. 2 Quote Link to comment https://forums.atariage.com/topic/304780-atarivox-device-communication-via-emulator/#findComment-4588926 Share on other sites More sharing options...
+Muddyfunster Posted July 19, 2020 Share Posted July 19, 2020 Thanks guys appreciate the quick advice. I confirm a suitable quantity of paperclips Quote Link to comment https://forums.atariage.com/topic/304780-atarivox-device-communication-via-emulator/#findComment-4588935 Share on other sites More sharing options...
+Karl G Posted July 19, 2020 Author Share Posted July 19, 2020 It's been long enough that I forgot about the paperclip part. 1 Quote Link to comment https://forums.atariage.com/topic/304780-atarivox-device-communication-via-emulator/#findComment-4589023 Share on other sites More sharing options...
