+eebuckeye Posted April 4, 2020 Share Posted April 4, 2020 No idea why my system will not power on.. I'm trying to determine if it is the system or power supply first. How can I measure the power supply to make sure it is working? I used a multimeter with one probe on the power connector shell and the other on each pin but did not read any DC voltage on any pin. Am I doing this wrong? Any suggestions please? Thank you! Quote Link to comment Share on other sites More sharing options...
Daedalus2097 Posted April 4, 2020 Share Posted April 4, 2020 So you're not getting any power LED at all, no? Commodore PSUs are inconsistent in their grounding schemes, it's quite likely that the shell simply isn't connected to anything. These are the pinouts for the machine itself - try measuring the 5V and 12V pins against the 0V pin instead of the shield. 1 Quote Link to comment Share on other sites More sharing options...
+eebuckeye Posted April 4, 2020 Author Share Posted April 4, 2020 Thanks for the response! I measured against the ground pin and still nothing so I think it is the PSU - at least that is my first step. I hope that is the entire problem... will see.. Quote Link to comment Share on other sites More sharing options...
Daedalus2097 Posted April 4, 2020 Share Posted April 4, 2020 It's rare enough for Amiga PSUs to die, but it does happen. And, unlike C64 PSUs, when they die, they usually leave the machine unharmed. Quote Link to comment Share on other sites More sharing options...
GameGeezer Posted April 9, 2020 Share Posted April 9, 2020 On 4/4/2020 at 3:51 PM, Daedalus2097 said: So you're not getting any power LED at all, no? Commodore PSUs are inconsistent in their grounding schemes, it's quite likely that the shell simply isn't connected to anything. These are the pinouts for the machine itself - try measuring the 5V and 12V pins against the 0V pin instead of the shield. The 1541-II and the 1581 PSUs have the same pinout. If you have one of those, give it a try. Quote Link to comment Share on other sites More sharing options...
