Tursi Posted April 28, 2020 Share Posted April 28, 2020 5 hours ago, Gip-Gip said: Apparently I didn't catch this yesterday It should now, the newest binary should at least. It enables 16k mode instead of 4k The 4k mode binary does not work on old hardware, however Thanks! Just for curiousity's sake, the reason 4k mode doesn't work is that it changes the meanings of the address lines, but the chip still physically has 16k attached. So data doesn't land where you expect. Though in retrospect, I don't understand why that matters on hardware... unless the VDP uses a different circuit to generate the address for display generation than for data access... will need to investigate that at some point. In Classic99 this is definitely the case (a different virtual circuit for pulling video data than for data access). Now that I think it through I'm surprised it didn't work on hardware and need to take a moment to try it out myself. Quote Link to comment Share on other sites More sharing options...
Asmusr Posted April 28, 2020 Share Posted April 28, 2020 1 hour ago, Tursi said: Though in retrospect, I don't understand why that matters on hardware... unless the VDP uses a different circuit to generate the address for display generation than for data access... will need to investigate that at some point. In Classic99 this is definitely the case (a different virtual circuit for pulling video data than for data access). Now that I think it through I'm surprised it didn't work on hardware and need to take a moment to try it out myself. But you do understand: ? Quote Link to comment Share on other sites More sharing options...
Tursi Posted April 28, 2020 Share Posted April 28, 2020 1 hour ago, Asmusr said: But you do understand: ? Yes, how that's generated I do understand, and I even understood it well enough to confirm that mapping landed data at the expected address in 16k space on hardware. But on a normal memory chip, as long as you read and write using the same address lines, who cares how they are scrambled? So why doesn't it just work anyway? All the tables are located in the first 4k (well, except the sprite descriptor table, but that's empty at startup...) Are we sure it didn't work on hardware? Cause I'm wondering if I should change the Classic99 VDP drawing code to respect the 4k bit too... right now it doesn't and that feels like an oversight. Quote Link to comment Share on other sites More sharing options...
Gip-Gip Posted April 28, 2020 Author Share Posted April 28, 2020 2 hours ago, Tursi said: Are we sure it didn't work on hardware? Cause I'm wondering if I should change the Classic99 VDP drawing code to respect the 4k bit too... right now it doesn't and that feels like an oversight. I double checked on my TI, definitely didn't work 1 Quote Link to comment Share on other sites More sharing options...
Gip-Gip Posted April 29, 2020 Author Share Posted April 29, 2020 Alright! I've somewhat successfully implemented bankswitching! If you want to see a "demo" of this bankswitching, the binary is included down below Not sure how to make a multi-bank RPK sadly The code's kinda half-baked at this point so I'd avoid the GitHub unless you want to be disappointed Next update will be a little more exciting, I promise vepseu8.bin Quote Link to comment Share on other sites More sharing options...
+FarmerPotato Posted April 29, 2020 Share Posted April 29, 2020 4 hours ago, Tursi said: Yes, how that's generated I do understand, and I even understood it well enough to confirm that mapping landed data at the expected address in 16k space on hardware. But on a normal memory chip, as long as you read and write using the same address lines, who cares how they are scrambled? So why doesn't it just work anyway? All the tables are located in the first 4k (well, except the sprite descriptor table, but that's empty at startup...) Are we sure it didn't work on hardware? Cause I'm wondering if I should change the Classic99 VDP drawing code to respect the 4k bit too... right now it doesn't and that feels like an oversight. I'm stumped too. I would have thought it behaves like you said. On a 16K 4116, there are 7 bits of row and 7 bits of col. A 4K 4027 has 6 bits of row and 6 bits of col. In 4K mode, the 9918 outputs a 0 in the MSB because that's chip enable for the 4027. So if 4116s are connected and 4K mode is active, the 7th and 14th bits of the address are lowered to 0. This would make a pattern of skipping every other 64 bytes of the 16K RAM, and then hitting the bottom half again. Then there is DRAM refresh. If the 9918 is in 4K mode, it doesn't refresh half the rows (because 6 bit row counter.) It does refresh the rows you are using... I don't understand what else might be going on inside the DRAM. There's something weird in the V9938 book too. The appendix tries to explain how to connect 16K chips with 8-bit rows (8,6 not 7,7), so that they refresh, though they lose half the rows. It seems that they try to guarantee that the MSbit gets toggled, while a LSbit gets ignored. The implication is that it matters. 1 Quote Link to comment Share on other sites More sharing options...
Tursi Posted April 29, 2020 Share Posted April 29, 2020 19 hours ago, Gip-Gip said: I double checked on my TI, definitely didn't work All right, thanks! I won't change my end then. 1 Quote Link to comment Share on other sites More sharing options...
+mizapf Posted April 29, 2020 Share Posted April 29, 2020 18 hours ago, Gip-Gip said: Not sure how to make a multi-bank RPK sadly I can do it, but I need to know your banking scheme, i.e. how you switch banks. And is this ROM-only, or do you again use RAM? We have various cartridge types, based on different selector chips (e.g. 74LS378). Quote Link to comment Share on other sites More sharing options...
Gip-Gip Posted April 29, 2020 Author Share Posted April 29, 2020 3 hours ago, mizapf said: I can do it, but I need to know your banking scheme, i.e. how you switch banks. And is this ROM-only, or do you again use RAM? We have various cartridge types, based on different selector chips (e.g. 74LS378). Both ROM and RAM, using FinalGROM's RAM mode-style bankswitching. Quote Link to comment Share on other sites More sharing options...
+mizapf Posted April 30, 2020 Share Posted April 30, 2020 (edited) [Edited] If you are developing directly for the FinalGROM, I'll have to fold at this time. Currently I have no plans for emulating the FinalGROM because it involves a lot of powerful hardware (including a micro controller) that cannot easily be emulated. I could possibly simulate it, though. Maybe it suffices to know how to do the bankswitching and where the RAM is located. Edited April 30, 2020 by mizapf 1 Quote Link to comment Share on other sites More sharing options...
Gip-Gip Posted April 30, 2020 Author Share Posted April 30, 2020 4 hours ago, mizapf said: [Edited] If you are developing directly for the FinalGROM, I'll have to fold at this time. Currently I have no plans for emulating the FinalGROM because it involves a lot of powerful hardware (including a micro controller) that cannot easily be emulated. I could possibly simulate it, though. Maybe it suffices to know how to do the bankswitching and where the RAM is located. This is from the finalgrom website: Quote In RAM Mode, each 8 KB bank is split into a ROM half-bank >6000->6FFF and a RAM half-bank >7000->7FFF. The RAM may be freely written to, but it is not battery-backed and will be lost on power down or cart reset. ROM half-banks are switched by writing to >60XX, and RAM half-banks are switched independently by writing to >6800. Intermediate bits are again ignored. Note that writing to >7XXX will not switch banks but update the RAM at that location. Other than that it's a fairly standard bankswitching scheme, write to an even address read-only address in cartridge ROM and a bank is swapped Quote Link to comment Share on other sites More sharing options...
Gip-Gip Posted April 30, 2020 Author Share Posted April 30, 2020 It looks like I'm getting under 10 FPS somehow and that kinda worries me... I'll actually have to do some optimization and commenting now Quote Link to comment Share on other sites More sharing options...
Gip-Gip Posted May 1, 2020 Author Share Posted May 1, 2020 I finally have music working! Granted, I completely broke the keyboard routine and the code's fairly buggy, but now you can listen to music stolen from inspired by Wolfenstein 3D! vepseu8.bin 4 Quote Link to comment Share on other sites More sharing options...
Asmusr Posted May 1, 2020 Share Posted May 1, 2020 8 minutes ago, Gip-Gip said: I finally have music working! Granted, I completely broke the keyboard routine and the code's fairly buggy, but now you can listen to music stolen from inspired by Wolfenstein 3D! vepseu8.bin 32 kB · 2 downloads Cool Quote Link to comment Share on other sites More sharing options...
Elia Spallanzani fdt Posted May 1, 2020 Share Posted May 1, 2020 (edited) 21 minutes ago, Gip-Gip said: I finally have music working! maybe make a little video for those that read this forum on smartphone? Edited May 1, 2020 by Elia Spallanzani fdt Correction Quote Link to comment Share on other sites More sharing options...
Gip-Gip Posted May 1, 2020 Author Share Posted May 1, 2020 (edited) 1 hour ago, Elia Spallanzani fdt said: maybe make a little video for those that read this forum on smartphone? I can provide a mp3. A video wouldn't be much worth anything as it's the same demo level with Wolfenstein music plastered on it Keep in mind the TI's music is fairly loud vepseu99_5_1_2020.mp3 Edited May 1, 2020 by Gip-Gip Quote Link to comment Share on other sites More sharing options...
Gip-Gip Posted May 4, 2020 Author Share Posted May 4, 2020 (edited) I've finally fixed the keyboard! And a few other things I'm going to work on commenting the code and documenting everything, which will be a pain, but I NEED to do it However I can safely say the testmap is on it's final version for now, and if you want to check it out the binary is attached Tell me how it runs on real hardware too, if you can vepseu8.bin Edited May 4, 2020 by Gip-Gip 4 Quote Link to comment Share on other sites More sharing options...
arcadeshopper Posted May 5, 2020 Share Posted May 5, 2020 quak quak 1 1 Quote Link to comment Share on other sites More sharing options...
Gip-Gip Posted May 5, 2020 Author Share Posted May 5, 2020 So far documentation is progressing, easily my least favorite part of development but it's kinda important Quick favor to ask of those who read this, how readable is my commenting? For example, here's the file that loads textures onto the VDP. It's simple, short, and in my opinion, relatively easy to follow. I'd like to opinions on it so I can better document code in the future Quote Link to comment Share on other sites More sharing options...
Tursi Posted May 6, 2020 Share Posted May 6, 2020 Coding style is as personal as a fingerprint, but if I were reviewing that code, I'd ask for some blank lines to improve readability. However, I like the quantity and content of the comments. 4 Quote Link to comment Share on other sites More sharing options...
sometimes99er Posted May 6, 2020 Share Posted May 6, 2020 7 hours ago, Tursi said: Coding style is as personal as a fingerprint ... So true ... Quote Link to comment Share on other sites More sharing options...
+Vorticon Posted May 17, 2020 Share Posted May 17, 2020 Just wondering where progress was on this project. Quote Link to comment Share on other sites More sharing options...
Gip-Gip Posted May 17, 2020 Author Share Posted May 17, 2020 1 hour ago, Vorticon said: Just wondering where progress was on this project. Currently I'm just working on the game I'm making for this engine. I'm adding features along as I go so once I have a demo out I'll update VePseu99 with the features as well 3 Quote Link to comment Share on other sites More sharing options...
+Ksarul Posted July 19, 2020 Share Posted July 19, 2020 I'm definitely interested to see how this one is progressing. . .it has been too quiet lately. Quote Link to comment Share on other sites More sharing options...
