TGB1718 Posted April 13, 2020 Share Posted April 13, 2020 I'm have a strange problem, I want to open a normal BASIC Mode 0 screen using cc65. I've checked the header file and found a function _graphics() which says it uses the same parameters as BASIC So _graphics(0) should give me a standard 40 column text mode screen, what I get is a black screen and it hangs (I think as I can't see anything :)). If I remove the _graphics(0) call, my program runs fine (its the first line in my code). While the call is not essential for this program, I may need to call this in future programs, so would like to resolve whats wrong, is there something else I should be calling. #include <stdio.h> #include <conio.h> #include <peekpoke.h> #include <string.h> #include <fcntl.h> #include <unistd.h> #include <string.h> #include <atari.h> void main(void) { flag=0; _graphics(0); clrscr(); POKE(710,57); POKE(709,2); POKE(712,200); gotoxy(0,0); printf("---------------------------------------"); Quote Link to comment Share on other sites More sharing options...
Irgendwer Posted April 13, 2020 Share Posted April 13, 2020 (edited) See: https://atariage.com/forums/topic/242757-black-screen-crash-when-using-_graphics-call-in-cc65/ (inspect explanation from "dmsc") If you use the std. Atari configuration with the added byte for reserved memory: FEATURES { STARTADDRESS: default = $2000; } SYMBOLS { __EXEHDR__: type = import; __SYSTEM_CHECK__: type = import; # force inclusion of "system check" load chunk __AUTOSTART__: type = import; # force inclusion of autostart "trailer" __STACKSIZE__: type = weak, value = $0800; # 2k stack __STARTADDRESS__: type = export, value = %S; __RESERVED_MEMORY__: type = weak, value = $0001; } MEMORY { ZP: file = "", define = yes, start = $0082, size = $007E; # file header, just $FFFF HEADER: file = %O, start = $0000, size = $0002; # "system check" load chunk SYSCHKHDR: file = %O, start = $0000, size = $0004; SYSCHKCHNK: file = %O, start = $2E00, size = $0300; SYSCHKTRL: file = %O, start = $0000, size = $0006; # "main program" load chunk MAINHDR: file = %O, start = $0000, size = $0004; MAIN: file = %O, define = yes, start = %S, size = $BC20 - __STACKSIZE__ - __RESERVED_MEMORY__ - %S; TRAILER: file = %O, start = $0000, size = $0006; } SEGMENTS { ZEROPAGE: load = ZP, type = zp; EXTZP: load = ZP, type = zp, optional = yes; EXEHDR: load = HEADER, type = ro; SYSCHKHDR: load = SYSCHKHDR, type = ro, optional = yes; SYSCHK: load = SYSCHKCHNK, type = rw, define = yes, optional = yes; SYSCHKTRL: load = SYSCHKTRL, type = ro, optional = yes; MAINHDR: load = MAINHDR, type = ro; STARTUP: load = MAIN, type = ro, define = yes; LOWBSS: load = MAIN, type = rw, optional = yes; # not zero initialized LOWCODE: load = MAIN, type = ro, define = yes, optional = yes; ONCE: load = MAIN, type = ro, optional = yes; CODE: load = MAIN, type = ro, define = yes; RODATA: load = MAIN, type = ro; DATA: load = MAIN, type = rw; INIT: load = MAIN, type = rw, optional = yes; BSS: load = MAIN, type = bss, define = yes; AUTOSTRT: load = TRAILER, type = ro; } FEATURES { CONDES: type = constructor, label = __CONSTRUCTOR_TABLE__, count = __CONSTRUCTOR_COUNT__, segment = ONCE; CONDES: type = destructor, label = __DESTRUCTOR_TABLE__, count = __DESTRUCTOR_COUNT__, segment = RODATA; CONDES: type = interruptor, label = __INTERRUPTOR_TABLE__, count = __INTERRUPTOR_COUNT__, segment = RODATA, import = __CALLIRQ__; } and build with it (option: -C configname ) or just the short variant: cl65 -t atari -D__RESERVED_MEMORY__=1 test.c -o test.xex this code: #include <stdio.h> #include <conio.h> #include <peekpoke.h> #include <string.h> #include <fcntl.h> #include <unistd.h> #include <string.h> #include <atari.h> void main(void) { _graphics(0); clrscr(); OS.color2 = 57; OS.color1 = 2; OS.color4 = 200; gotoxy(0,0); printf("---------------------------------------"); while(1); } works: Edited April 13, 2020 by Irgendwer Quote Link to comment Share on other sites More sharing options...
TGB1718 Posted April 13, 2020 Author Share Posted April 13, 2020 Many thanks for your reply, but I tried both methods and still get the black screen, I even copy/pasted your example above and compiled it and that had the black screen too I must be missing something here. Using the config file with :- cl65 -t atari -Catari.cfg --static-locals -o autodata.xex autodata.c with this line modified in the atari.cfg file:- __RESERVED_MEMORY__: type = weak, value = $0001; I also tried :- cl65 -t atari -D__RESERVED_MEMORY__=1 --static-locals -o autodata.xex autodata.c I'm using a 130XE, so memory size etc. as described in the link you provided shouldn't be an issue Quote Link to comment Share on other sites More sharing options...
Wrathchild Posted April 13, 2020 Share Posted April 13, 2020 Irgendwer didn't use --static-locals but I presume you tried without too (plus with a space after the -C)? Can you build with an extra option: -Ln autodata.lbl Then post the xex and label file so we can debug. Quote Link to comment Share on other sites More sharing options...
Wrathchild Posted April 13, 2020 Share Posted April 13, 2020 @TGB1718 & @Irgendwer I've spotted the problem... you can leave the cfg/atari.cfg as it was: __RESERVED_MEMORY__: type = weak, value = $0000; But instead of passing the define to cl65 this needs to be passed onto the linker instead with: -Wl "-D__RESERVED_MEMORY__=1" 1 Quote Link to comment Share on other sites More sharing options...
TGB1718 Posted April 14, 2020 Author Share Posted April 14, 2020 Thanks @Wrathchild , that fixed it, I'll have to look and see why this is required, and what that switch does. It seems strange though to have to do something like this for a straightforward screen opening which is handled internally by the OS. Do you know if this switch is required if you do it by using CIO calls to open "S:" as you would in assembler ? Like this but in "C" code 0680 SCREENOPEN LDA #CLOSE ; MAKE SURE CHANNEL IS CLOSED 0690 LDX #$10 0700 STA ICCOM,X 0710 JSR CIOV 0720 LDA #0 ; RESERVE MEMORY 0730 STA APPMHI ; FOR NEW SCREEN 0740 LDA #$80 ; ELSE OPEN WILL FAIL 0750 STA APPMHI+1 0760 LDA #OPEN 0770 STA ICCOM,X 0780 LDA #NAME1&255 0790 STA ICBAL,X 0800 LDA #NAME1/256 0810 STA ICBAH,X 0820 LDA #3 0830 STA ICBLL,X 0840 LDA #0 0850 STA ICBLH,X 0860 LDA #$0C ;R/W 0870 STA ICAX1,X 0880 LDA #8 0890 STA ICAX2,X 0920 JSR CIOV 930 RTS 1000 NAME1 .BYTE "S:",$9B Quote Link to comment Share on other sites More sharing options...
Irgendwer Posted April 14, 2020 Share Posted April 14, 2020 9 hours ago, Wrathchild said: But instead of passing the define to cl65 this needs to be passed onto the linker instead with: -Wl "-D__RESERVED_MEMORY__=1" Interesting. My command line as given above works exactly as it should. "Linux Mint" cl65 V2.18 - Git a560052 Thanks for the solution! Quote Link to comment Share on other sites More sharing options...
Wrathchild Posted April 14, 2020 Share Posted April 14, 2020 3 minutes ago, Irgendwer said: cl65 V2.18 I have cl65 V2.17 - Git 5c8854f I'm not sure what the behaviour, say with gcc is, but I think the use of -D is just to pass to the pre-processor? If you've edited the atari.cfg to non-zero then because the define isn't passed to the linker then it would use that and so work in your case? Quote Link to comment Share on other sites More sharing options...
Irgendwer Posted April 14, 2020 Share Posted April 14, 2020 1 hour ago, Wrathchild said: I'm not sure what the behaviour, say with gcc is, but I think the use of -D is just to pass to the pre-processor? If you've edited the atari.cfg to non-zero then because the define isn't passed to the linker then it would use that and so work in your case? Just tried to reproduce what I did. Don't know - of course you are right and the "-Wl" is necessary. I only wonder why @TGB1718 wasn't able to create a working exe with the adapted config. Thanks again! Quote Link to comment Share on other sites More sharing options...
