FLEX for the 6502 or building a compatible operating system...
BillG
I discovered this several months ago:
https://www.corshamtech.com/ss-50-65...rd-experiment/
So I contacted Bob Applegate and told him that I have been working on a debugger for the 6502 and will convert it into a monitor.
We were talking about operating systems. Most of the popular ones on the 6502 are wrapped tightly around its host hardware. None of them were anything like a CP/M or MS-DOS which can be readily adapted to a new system.
I brought up the OSI DOS. He said that he had looked at it and thought it was “clunky.” I had to agree because the user had to manually allocate disk tracks.
There is DOS/65, a CP/M clone, but there is not much information available on how to adapt it and build a boot disk.
While working on adding support for his SD card “disk system” in my debugger/monitor, I had a thought. Why not build a clone of FLEX for the 6502?
I started working on it and have most of the command line interface of the DOS portion working and can boot it off of a virtual disk in my emulator. Next up are disk drivers then the file system.
This morning, I reached out to Dave , local Ohio Scientific expert and owner of http://www.osiweb.org/ , for his input. We have been having some interesting discussions.
More to come…
  • Like 4
  • 2 weeks later...
At long last, I am finally able to load and run a program from a binary file.  A surprising amount of the file system had to be implemented in order to be able to do that.  I am very thankful to be developing this using emulation.  Using real hardware will have taken much, much longer.
It is often said that code on a 6502 tends to be faster but bigger.
The following subroutine in the FLEX file system copies an 8.3 file name to a temporary save area in a file control block.
The original 6809 code:
 D540 BE D413                 [6] 00177    MOVNAM   LDX    CURFCB    MOVE FILE NAME TO TEMP
 D543 C6 0B                   [2] 00178             LDB    #$0B
 D545 A6 04                   [5] 00179    MOVNM1   LDA    $04,X
 D547 A7 88 24                [5] 00180             STA    $24,X
 D54A 30 01                   [5] 00181             LEAX   $01,X
 D54C 5A                      [2] 00182             DECB
 D54D 26 F6 (D545)            [3] 00183             BNE    MOVNM1
 D54F 39                      [5] 00184             RTS
The 6502 code:
.C57A                     01901    MOVNAM
.C57A 18              [2] 01902             clc              ; Copy file name to temp
.C57B A5 04           [3] 01903             lda    FCBPtr
.C57D 69 20           [3] 01904             adc    #FCBWrk-FCBNam   ; Offset to temp area
.C57F 85 06           [3] 01905             sta    FMSPtr
.C581 A5 05           [3] 01906             lda    FCBPtr+1
.C583 69 00           [2] 01907             adc    #0
.C585 85 07           [3] 01908             sta    FMSPtr+1
.                         01909
.C587 A2 0B           [2] 01910             ldx    #8+3
.C589 A0 04           [2] 01911             ldy    #FCBNam
.                         01912
.C58B B1 04         [5/6] 01913    MOVNM1   lda    (FCBPtr),Y
.C58D 91 06           [6] 01914             sta    (FMSPtr),Y
.                         01915
.C58F C8              [2] 01916             iny
.C590 CA              [2] 01917             dex
.C591 D0 F8 (C58B)  [2/3] 01918             bne    MOVNM1
.                         01919
.C593 60              [6] 01920             rts
In this example, the 6502 code is 20 cycles faster, but 10 bytes bigger.
I can now view a catalog of files on a disk, type out the contents of text files, delete and rename files.
Overall, I am very pleased with the progress of this project; it was started on April 6, less than a month ago.
Next up, testing all of the ways to write files.  That should keep me busy over the weekend.
While working on file deletion, it became obvious that a very safe and reliable file undelete utility can be built.  Should I decide to develop that, I'll do it first on the 6502, then migrate it back to the 6800 and 6809.
Edited by BillG
This is a bit of a one month progress report.
The FLEX file system (File Management System or FMS) is feature complete except for the portions dealing with the creation, reading and writing of random access files.  FLEX stores data on disk as a linked list of sectors.  Reading or writing an arbitrary location in a file is not a simple arithmetic calculation; a naive implementation would have to read every sector of the file to follow the list until the needed sector is found.  To solve this problem, creating a random file adds two special sectors which contain the addresses of the sectors in the file as they are allocated.  Reading a byte from random location in a file requires first reading this sector map then the sector.
The FLEX user interface is feature complete except for enhanced error reporting and background printing.  When a random file named ERRORS.SYS is present, its contents is used to present a meaningful error message instead of an error code number.  This capability is dependent upon FMS random access file support.  Background printing is an option which requires a source of periodic interrupts.  I have not investigated this feature very much yet; there are hooks for it in various parts of the system.
The third leg of the FLEX system triad is the Utility Command Set, a collection of small programs on disk which provide a large majority of the user commands.  The following commands have been implemented:
ASN
BUILD
CAT
DATE
DELETE
JUMP
LINK
LIST
RENAME
TTYSET
VERIFY
VERSION
leaving these yet to be implemented:
APPEND
COPY
EXEC
I
NEWDISK
O
P
PRINT
QCHECK
SAVE
XOUT
The bootstrap loaders work so the operating system can be loaded from a disk image.
The system total so far is about 9K bytes of machine code.  That is an average of around 300 bytes per day.  It may not seem like much, but remember that it is all written in assembly language.
The current memory map is:
$0000..$00FF - Zero page, locations at $12 and above are free for application programs to use
$0100..$017F - FLEX line buffer
$0180..$01FF - Stack
$0200..$033F - FLEX entry points, variables and printer driver
$0340..$047F - System File Control Block
$0480..$0AFF - FLEX Utility Command Space
$0B00..MEMEND - User memory
Somewhere above that is about 6K of FLEX itself.
Unlike the 680x versions, the UCS area has been intentionally placed adjacent to free RAM so that a program needing maximum memory can easily use both.
The User's Guide is almost ready to publish; this is slightly modified from an original FLEX manual.  The Programming Guide is about halfway done; it is a heavily modified version of an existing FLEX manual.
Finally, some preliminary work has been done on an editor and an assembler.  The assembler subproject is actually comprised of four smaller projects:
* enhance the existing 6800 assembler to add features such as conditional assembly directives
* convert the 6800 assembler into a 6502 cross assembler running on the 6800
* convert the 6800 assembler into a 6800 cross assembler running on the 6502
* combine the three into a 6502 native assembler
Edited by BillG
I dove headlong into the assembler.  Implementing conditional assembly does not initially appear to be very easy.
So to learn the code, I made a few changes to fix some things which have always bothered me about this assembler:
* The assembler does not allow placing a colon after a label.  It now allows but does not require it.
* The assembler distinguishes between upper and lower case in symbols.  That is now a selectable option.
* The assembler reformats the source code when it generates a listing.  It originally printed "ldaa" as "lda a"; it now preserves both forms of the mnemonic as written.  I am still investigating making the reformatting a selectable option.
A simple and elegant solution presented itself after I slept on it and came back to look at the problem from outside of the box:  format each line of code, or not, in this case, as if the whole thing was a comment.
This is ideal for those of you on the spaces side of the Great Spaces versus TABs Debate.  FLEX already provides automagic space compression on disk as sequences of two or more spaces (up to 255) are replaced with two bytes: a tag and a count.  You may now make your code listings look exactly like you want.
Despite having this feature, many early FLEX programmers got into the unusual habit of separating fields in their assembly language programs with a single space and relying on the assembler to make listings legible.
Those on the TAB side were left out because the tag byte was, you guessed it, the hard TAB character.  FLEX text files cannot contain hard TABs the way the tools were configured.  Editors responded to the TAB key by inserting an appropriate number of spaces.
  • 2 weeks later...
I have been known to say that programming a 6502 in assembly language is tedious compared with other processors.  However, I just encountered an example in which the 6502 absolutely blows away the 6800.
One of my current projects is to convert the original 6800 FLEX assembler into a cross assembler running on the 6502.
Its symbol table is an array of eight byte entries: two bytes for the value and six for the symbol name.  The symbol name is hashed to obtain an index into the array.  In case of a collision, the name is rehashed up to a maximum of forty times to try other locations.
At the end of the assembly process, the table is packed and sorted, then the entries are printed in alphabetical order.
A subroutine swaps two entries addressed by the variables I and J, a task which the 6502 does with ease.  It has just enough registers to avoid unnecessary memory accesses.  I have observed in the past that the 6800 can be severely hampered by having only a single index register and that the 6502 addressing modes are particularly well suited for marching in lockstep through two parallel arrays.
The 6502 version of the subroutine consumes less than half the cycles while also being much smaller.
The 6502 code:
.1832                     04047 XCHNG
.                         04048 ; LDX I
.1832 A0 07           [2] 04049          ldy    #8-1      ; SET COUNT and index
.                         04050
.1834                     04051 XCHNG1                    ;PSHB ; SAVE COUNT
.1834 B1 22         [5/6] 04052          lda    (I),Y     ; GET CHAR FROM I
.1836 AA              [2] 04053          tax              ; Stash I[Y]
.                         04054 ; STX I
.                         04055 ; LDX J
.1837 B1 24         [5/6] 04056          lda    (J),Y     ; GET CHAR FROM J
.1839 91 22           [6] 04057          sta    (I),Y     ; Replace in I
.                         04058 ; INX
.                         04059 ; STX J ; SET NEW J
.                         04060 ; LDX I
.183B 8A              [2] 04061          txa              ; Recover I[Y]
.183C 91 24           [6] 04062          sta    (J),Y     ; Replace in J
.                         04063 ; INX
.                         04064
.                         04065 ; PULB ; RESTORE COUNT
.                         04066
.183E 88              [2] 04067          dey              ; DECREMENT IT
.183F 10 F3 (1834)  [2/3] 04068          bpl    XCHNG1    ; LOOP IF NOT -1TH BYTE
.                         04069
.                         04070 ; BSR XSUB8 ; FIX I POINTER
.                         04071 ; STX I
.                         04072 ; LDX J
.                         04073 ; BSR XSUB8 ; FIX J POINTER
.                         04074 ; STX J
.                         04075
.1841 60              [6] 04076          rts
The original 6800 code:
.151F 09              [4] 02889 XSUB8    DEX              DECREMENT X BY 8
.1520 09              [4] 02890          DEX
.1521 09              [4] 02891          DEX
.1522 09              [4] 02892          DEX
.1523 09              [4] 02893          DEX
.1524 09              [4] 02894          DEX
.1525 09              [4] 02895          DEX
.1526 09              [4] 02896          DEX
.1527 39              [5] 02897          RTS
.                         02898 *
.1528 DE 20           [4] 02899 XCHNG    LDX    I
.152A C6 08           [2] 02900          LDAB   #$08      SET COUNT
.152C 37              [4] 02901 XCHNG1   PSHB             SAVE COUNT
.152D E6 00           [5] 02902          LDAB   0,X       GET CHAR FROM I
.152F DF 20           [5] 02903          STX    I
.1531 DE 22           [4] 02904          LDX    J
.1533 A6 00           [5] 02905          LDAA   0,X       GET CHAR FROM J
.1535 E7 00           [6] 02906          STAB   0,X       REPLACE WITH I CHAR
.1537 08              [4] 02907          INX
.1538 DF 22           [5] 02908          STX    J         SET NEW J
.153A DE 20           [4] 02909          LDX    I
.153C A7 00           [6] 02910          STAA   0,X       REPLACE WITH J CHAR
.153E 08              [4] 02911          INX
.153F 33              [4] 02912          PULB             RESTORE COUNT
.1540 5A              [2] 02913          DECB             DECREMENT IT
.1541 26 E9 (152C)    [4] 02914          BNE    XCHNG1    LOOP IF NOT 8TH BYTE
.1543 8D DA (151F)    [8] 02915          BSR    XSUB8     FIX I POINTER
.1545 DF 20           [5] 02916          STX    I
.1547 DE 22           [4] 02917          LDX    J
.1549 8D D4 (151F)    [8] 02918          BSR    XSUB8     FIX J POINTER
.154B DF 22           [5] 02919          STX    J
.154D 39              [5] 02920          RTS
On further examination, the 6800 version can be made substantially faster than the 6502 version by completely unrolling the loop but the code is almost twice as big.  (The XSUB8 subroutine is also used elsewhere, so it cannot be eliminated in the process.)  A small speed gain by a similar transformation of the 6502 version does not justify the massive increase in code size required.
I have to partially retract that statement.  Somehow, I managed to forget that the 6800 only has one index register; the X register must to be ping ponged between I and J.  Still, completely unrolling that loop makes the 6800 code about as fast as the 6502 version, but with much bigger code size.  The result would look something like this:
 0100 DE 00          [4] 00006             ldx    I
                         00007 *
 0102 E6 00          [5] 00008             ldab   0,X
 0104 DE 02          [4] 00009             ldx    J
 0106 A6 00          [5] 00010             ldaa   0,X
 0108 E7 00          [6] 00011             stab   0,X
 010A DE 00          [4] 00012             ldx    I
 010C A7 00          [6] 00013             staa   0,X
                         00014 *
 010E E6 01          [5] 00015             ldab   1,X
 0110 DE 02          [4] 00016             ldx    J
 0112 A6 01          [5] 00017             ldaa   1,X
 0114 E7 01          [6] 00018             stab   1,X
 0116 DE 00          [4] 00019             ldx    I
 0118 A7 01          [6] 00020             staa   1,X
etc.
There are two other service subroutines for the symbol table sorter.
CMPLBL compares two symbols, pointed to by the variables I and J.  Note that the 6800 version uses a couple of temporary variables instead of modifying I and J, then fixing them after the loop is finished; this same approach would have made the exchange subroutine better.  Completely unrolling the loop is again the fastest implementation.
.154E DE 20           [4] 02922 CMPLBL   LDX    I
.1550 DF 76           [5] 02923          STX    XTEMP     GET I INTO XTEMP
.1552 DE 22           [4] 02924          LDX    J
.1554 DF 80           [5] 02925          STX    XTEMP5    GET J INTO XTEMP5
.1556 C6 06           [2] 02926          LDAB   #$06      SET COMPARE COUNT
.1558 DE 76           [4] 02927 CMPLB1   LDX    XTEMP
.155A A6 00           [5] 02928          LDAA   0,X       GET CHAR FROM I
.155C 08              [4] 02929          INX
.155D DF 76           [5] 02930          STX    XTEMP
.155F DE 80           [4] 02931          LDX    XTEMP5
.1561 A1 00           [5] 02932          CMPA   0,X       COMPARE WITH J CHAR
.1563 26 06 (156B)    [4] 02933          BNE    CMPLB2    EXIT IF NOT EQUAL
.1565 08              [4] 02934          INX
.1566 DF 80           [5] 02935          STX    XTEMP5
.1568 5A              [2] 02936          DECB             ELSE DECREMENT COUNT
.1569 26 ED (1558)    [4] 02937          BNE    CMPLB1    LOOP UNTIL DONE
.156B 39              [5] 02938 CMPLB2   RTS
The 6502 code:
.1981                     04172 CMPLBL
.                         04173 ; LDX I
.                         04174 ; STX XTEMP ; GET I INTO XTEMP
.                         04175 ; LDX J
.                         04176 ; STX XTEMP5 ; GET J INTO XTEMP5
.1981 A0 00           [2] 04177          ldy    #0        ; SET index
.1983                     04178 CMPLB1                    ;LDX XTEMP
.1983 B1 22         [5/6] 04179          lda    (I),Y     ; GET CHAR FROM I
.                         04180 ; INX
.                         04181 ; STX XTEMP
.                         04182 ; LDX XTEMP5
.1985 D1 24         [5/6] 04183          cmp    (J),Y     ; COMPARE WITH J CHAR
.1987 D0 05 (198E)  [2/3] 04184          bne    CMPLB2    ; EXIT IF NOT EQUAL
.                         04185 ; INX
.                         04186 ; STX XTEMP5
.                         04187
.1989 C8              [2] 04188          iny              ; ELSE inCREMENT index
.198A C0 06           [2] 04189          cpy    #6
.198C D0 F5 (1983)  [2/3] 04190          bne    CMPLB1    ; LOOP UNTIL DONE
.                         04191
.198E 60              [6] 04192 CMPLB2   rts
PUSH pushes an address onto a software stack.  This code is an even test which illustrates shortcomings in both processors.  The 6800 does not provide easy access to the index register; this is corrected in the 6809.  The 6502 does not provide an easy way to perform 16-bit arithmetic.
.14B5 DF 80           [5] 02823 PUSH     STX    XTEMP5    PUT THE VALUE IN
.14B7 DE 28           [4] 02824          LDX    SRSP      THE X REGISTER ONTO THE
.14B9 96 80           [3] 02825          LDAA   XTEMP5    SORT REQUEST STACK AND
.14BB A7 00           [6] 02826          STAA   0,X       UPDATE THE SORT REQUEST
.14BD 08              [4] 02827          INX              STACK POINTER
.14BE 96 81           [3] 02828          LDAA   XTEMP5+1
.14C0 A7 00           [6] 02829          STAA   0,X
.14C2 08              [4] 02830          INX
.14C3 DF 28           [5] 02831          STX    SRSP
.14C5 39              [5] 02832          RTS
The 6502 code:
.18AB                     03977 PUSH
.                         03978 ; STX XTEMP5 ; PUT THE VALUE IN
.                         03979 ; LDX SRSP ; THE X REGISTER ONTO THE
.                         03980 ; LDAA XTEMP5 ; SORT REQUEST STACK AND
.                         03981
.                         03982 ; Address in A:X
.18AB A0 01           [2] 03983          ldy    #1
.18AD 91 2A           [6] 03984          sta    (SRSP),Y  ; UPDATE THE SORT REQUEST
.18AF 88              [2] 03985          dey              ; STACK POINTER
.18B0 8A              [2] 03986          txa
.18B1 91 2A           [6] 03987          sta    (SRSP),Y
.                         03988
.18B3 18              [2] 03989          clc              ; Update "stack pointer"
.18B4 A5 2A           [3] 03990          lda    SRSP
.18B6 69 02           [2] 03991          adc    #2
.18B8 85 2A           [3] 03992          sta    SRSP
.18BA A5 2B           [3] 03993          lda    SRSP+1
.18BC 69 00           [2] 03994          adc    #0
.18BE 85 2B           [3] 03995          sta    SRSP+1
.                         03996
.18C0 60              [6] 03997          rts
At this time, the symbol table sorter has been completely coded.  Wish me luck as I begin to test it...
I am now able to cross assemble most inherent 6800 instructions.
While 6800 binary files currently have no value on a 6502, this means that a large part of the fundamental infrastructure of the assembler is working.
Next up, evaluating expressions...
  • 3 weeks later...
This project is now two months old.
The FLEX file system (File Management System or FMS) is still lacking the code for writing random access files until I can come up with a good way to test it.  I may go ahead and write the code but leave it disconnected to get an idea how big it is likely to be.
The FLEX user interface portion is feature complete except for background printing.  Again, I may write the code to find out how large it will be.  The error message reporting mechanism is complete.
There was little progress on the Utility Command Set this month.  The SAVE utility has been written, but not thoroughly tested.
The 6800 assembler now runs on the 6502 as a cross assembler.  To help test it, I have started implementing the text editor.  It can currently create a text file and make some simple edits to it.  The editor is definitely more difficult code than the assembler has been.
The current system memory map is:
It is time to start trying to freeze the memory organization.  I am considering making a somewhat radical change to move the public portions (entry points, variables, Utility Command Space) from $200 up to $2000.  Why?  Doing this will make it possible for a KIM-1 or clone with a expanded RAM and a serial port to run FLEX.  The operating system itself can reside from $200 to $2000 on systems which allow that and at the top of user memory otherwise.  Because the binary file format consists of a collection of separate chunks, pieces of the system can potentially be built to load into several disjoint places where memory is available.
Another decision is whether the system should reserve a part of the lower or upper end of the zero page.
The important part now is to determine where the public portions are located.  This is where I need your input as to what your particular system requires and allows.  It may not be possible to please everyone, but the main goal is to have one version of the utilities and application programs which work on all supported platforms.
  • 2 weeks later...
The text editor code has been difficult; I can only stand to work on it a bit at a time.
The 6800 version keeps values in the X register for long stretches of code, sometimes across several subroutines.  I am about to give up trying to keep it in 6502 registers even part of the time, but to declare RegX, a 2-byte variable in the zero page, and copy values into and out of it as the 6800 loads and stores X.  Addresses already have to be stored in the zero page to access memory.  It will not be as efficient, but the code will be somewhat clearer; this program really needs that.
So far, the following functionality is complete:
loading a file
saving a file
text buffer management
Print command
Insert command
Delete command
Renumber command
Overlay command
Find command
The Copy command has been coded, but it does not work.  When that is done, the Move command should be easy as it does a copy followed by a delete.  I would guess we are somewhat past the halfway mark.
During breaks, I have been working on assemblers.
First, I added the SET directive to the 6800 ASMB.  It is like EQU, but a label may be assigned a value more than once.
I have always liked the local labels in RELASMB, the 6809 relocatable assembler, and wished that ASMB implemented them.
Local labels work like this: a one or two digit number in the label field is considered to be a local label.  It is referenced by stating the number followed by a "b" or "f" to designate whether to search for the nearest occurrence of the number before or following the current line.  Note that it is not possible to find a local label on the current line.  For example:
2                       ; This is the target for "2b"
2       beq     target  ; The label for this line cannot be specified
2                       ; This is the target for "2f"
Advantages of a local label include doing away with the need to come up with meaningful and unique names for short, trivial branches and a local label uses less memory than a regular symbol.
A web search for local label uncovered no prevalent standard, but a number with a "b" or "f" suffix is a very common form.
I will put a seemingly arbitrary limit on local labels: the number may not consist of only "0" and "1" digits.  Why?  ASMB 6800 accepts binary numbers in both the %xx and xxb forms.  Something like "1b" is ambiguous.
I had been initially tempted to limit the reference of local labels to relative branch instructions to prevent people writing FORTRANish code, but RELASMB does not have that restriction.  And it is convenient to be able to do something like the following:
        ldx     #2f     ; Print error message
        jsr     PSTRNG
        rts
2       fcc     "Operand expected."
        fcb     4
I am currently implementing local labels in my 6502 cross assembler.  Should that go well, the capability will be migrated to the 6800 and 6809 assemblers.  Then I will implement it in ASMB 6800; ASMB 6502 will inherit that functionality.
  • 1 month later...
The Poor Man's Linker experiment has gone well.  The conversion of the run-time library to the new approach is done.  In the foreseeable future, my Python library (currently 6502 only) will be converted in the same way; it really needs it.
The following program, the skeleton of a monitor or a debugger, compiles into a 6800 binary image a little under 2K bytes in size; it uses quite a bit but not all of the library code.
10 PRINT '? ';
20 INPUT LINE A$
30 GOSUB 1000:REM Strip leading spaces from A$
40 B$=LEFT$(A$,1):A$=MID$(A$,2):GOSUB 1000:GOSUB 1100
50 IF B$ = 'D' THEN 10000
60 IF B$ = 'U' THEN 12000
90 IF B$ = 'Q' THEN END
95 PRINT 'Unrecognized command.':GOTO 10
1000 REM Strip leading spaces from A$
1010 IF ASC(' ') = ASC(A$) THEN A$=MID$(A$,2) ELSE RETURN
1020 GOTO 1010
1100 REM Convert B$ to upper case
1110 IF ASC('a') <= ASC(B$) AND ASC('z') >= ASC(B$) THEN B$=CHR$(ASC(B$)-32)
1120 RETURN
10000 REM DUMP
10001 print "DUMP ";a$:goto 10
12000 REM UNASSEMBLE
12001 print "UNASSEMBLE ";a$:goto 10
You may have noticed the ordering of "IF ASC(' ') = ASC(A$)" as a bit unusual.  A single-pass compiler which generates code as it parses the source can do a better job if simple expressions which can be completely evaluated at compile time are on the left while things which must wait until run time are postponed as long as possible.  The opposite "IF ASC(A$) = ASC(' ')" gets the first character from the string, puts it into a temporary variable, then does the comparison because without lookahead, the compiler does not know that a constant follows.
Since what I thought was source code for the FLEX BASIC interpreter turned out to be something else, SWTPC BASIC instead of TSC BASIC, I will be building a version of this compiler to generate 6502 code for TSC BASIC programs.  I am just starting to reverse engineer the FLEX BASIC and Extended BASIC interpreters and thus cannot commit to doing anything with them at this time.
For comparison, here is some code from the two compilers...
The 6502 code generated by the compiler:
                          00108 ; 120 C = A * (B + 1)
 0B26                     00109    L00120:
                          00110          ifdef  __TRACE
                          00111          ldx    #<120
                          00112          lda    #>120
                          00113          jsr    Trace
                          00114          endif
                          00115          ifdef  __ATLIN
                          00116          ldx    #<L00120
                          00117          stx    ResLn_
                          00118          ldx    #>L00120
                          00119          stx    ResLn_+1
                          00120          endif
                          00121
 0B26 18              [2] 00122          clc
 0B27 AD 0F39         [4] 00123          lda    B_
 0B2A 69 01           [2] 00124          adc    #<1
 0B2C AA              [2] 00125          tax
 0B2D AD 0F3A         [4] 00126          lda    B_+1
 0B30 69 00           [2] 00127          adc    #>1
 0B32 AC 0F37         [4] 00128          ldy    A_
 0B35 84 14           [3] 00129          sty    Int0
 0B37 AC 0F38         [4] 00130          ldy    A_+1
 0B3A 84 15           [3] 00131          sty    Int0+1
 0B3C 20 0D30         [6] 00132          jsr    IMul
 0B3F 8E 0F3B         [4] 00133          stx    C_
 0B42 8D 0F3C         [4] 00134          sta    C_+1
The 6800 code generated by the compiler:
                          00083 * 120 C = A * (B + 1)
 0119                     00084 L00120
                          00085          ifdef  __TRACE
                          00086          ldx    #120
                          00087          jsr    Trace
                          00088          endif
                          00089          ifdef  __ATLIN
                          00090          ldx    #L00120
                          00091          stx    ResLn_
                          00092          endif
                          00093
 0119 C6 01           [2] 00094          ldab   #1
 011B 4F              [2] 00095          clra
 011C FB 0435         [4] 00096          addb   B_+1
 011F B9 0434         [4] 00097          adca   B_
 0122 FE 0432         [5] 00098          ldx    A_
 0125 BD 0297         [9] 00099          jsr    IMul
 0128 F7 0437         [5] 00100          stab   C_+1
 012B B7 0436         [5] 00101          staa   C_
The 6502 multiply subroutine:
.                         00730 ;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;
.                         00731 ;
.                         00732 ; IMul - Multiply integers
.                         00733 ;
.                         00734 ; Input:
.                         00735 ;       A:X = one number
.                         00736 ;       Int0 = the other number
.                         00737 ;
.                         00738 ; Output:
.                         00739 ;       A:X = the product
.                         00740 ;
.                         00741
.0D2C                     00742 IMulB    rmb    2         ; Operand
.0D2E                     00743 IMulC    rmb    1         ; Bits left
.0D2F                     00744 IMulS    rmb    1         ; Sign of the product
.                         00745
.0D30                     00746 IMul:
.0D30 A0 00           [2] 00747          ldy    #0        ; Clear sign of product
.0D32 8C 0D2F         [4] 00748          sty    IMulS
.                         00749
.0D35 C9 00           [2] 00750          cmp    #0        ; Is first number negative?
.0D37 10 10 (0D49)  [2/3] 00751          bpl    IMul1     ; No
.                         00752
.0D39 EE 0D2F         [6] 00753          inc    IMulS     ; Update sign of product
.                         00754
.0D3C 49 FF           [2] 00755          eor    #$FF      ; Negate the number
.0D3E A8              [2] 00756          tay
.0D3F 8A              [2] 00757          txa
.0D40 49 FF           [2] 00758          eor    #$FF
.0D42 18              [2] 00759          clc
.0D43 69 01           [2] 00760          adc    #1
.0D45 AA              [2] 00761          tax
.0D46 98              [2] 00762          tya
.0D47 69 00           [2] 00763          adc    #0
.                         00764
.0D49                     00765 IMul1:
.0D49 8E 0D2C         [4] 00766          stx    IMulB     ; Save the number
.0D4C 8D 0D2D         [4] 00767          sta    IMulB+1
.                         00768
.0D4F A5 15           [3] 00769          lda    Int0+1    ; Is the other number negative?
.0D51 10 10 (0D63)  [2/3] 00770          bpl    IMul2     ; No
.                         00771
.0D53 EE 0D2F         [6] 00772          inc    IMulS     ; Update sign of product
.                         00773
.0D56 A9 00           [2] 00774          lda    #0        ; Negate the other number
.0D58 38              [2] 00775          sec
.0D59 E5 14           [3] 00776          sbc    Int0
.0D5B 85 14           [3] 00777          sta    Int0
.0D5D A9 00           [2] 00778          lda    #0
.0D5F E5 15           [3] 00779          sbc    Int0+1
.0D61 85 15           [3] 00780          sta    Int0+1
.                         00781
.0D63                     00782 IMul2:
.0D63 A9 10           [2] 00783          lda    #16       ; 16 bits to multiply
.0D65 8D 0D2E         [4] 00784          sta    IMulC
.                         00785
.0D68 A9 00           [2] 00786          lda    #0        ; Clear product
.0D6A A8              [2] 00787          tay
.                         00788
.0D6B                     00789 IMul3:
.0D6B 4E 0D2D         [6] 00790          lsr    IMulB+1   ; Shift number right
.0D6E 6E 0D2C         [6] 00791          ror    IMulB
.0D71 90 09 (0D7C)  [2/3] 00792          bcc    IMul4     ; Skip add if low bit was clear
.                         00793
.0D73 18              [2] 00794          clc              ; Add number to product
.0D74 65 14           [3] 00795          adc    Int0
.0D76 AA              [2] 00796          tax
.0D77 98              [2] 00797          tya
.0D78 65 15           [3] 00798          adc    Int0+1
.0D7A A8              [2] 00799          tay
.0D7B 8A              [2] 00800          txa
.                         00801
.0D7C                     00802 IMul4:
.0D7C 06 14           [5] 00803          asl    Int0      ; Shift the other number left
.0D7E 26 15           [5] 00804          rol    Int0+1
.                         00805
.0D80 CE 0D2E         [6] 00806          dec    IMulC     ; One fewer bit to do
.0D83 D0 E6 (0D6B)  [2/3] 00807          bne    IMul3     ; More?
.                         00808
.0D85 4E 0D2F         [6] 00809          lsr    IMulS     ; Is product negative?
.0D88 90 0E (0D98)  [2/3] 00810          bcc    IMul5     ; No
.                         00811
.0D8A 49 FF           [2] 00812          eor    #$FF      ; Negate the product
.0D8C 18              [2] 00813          clc
.0D8D 69 01           [2] 00814          adc    #1
.0D8F AA              [2] 00815          tax
.0D90 98              [2] 00816          tya
.0D91 49 FF           [2] 00817          eor    #$FF
.0D93 69 00           [2] 00818          adc    #0
.                         00819
.0D95 4C 0D9A         [3] 00820          jmp    IMul6
.                         00821
.0D98                     00822 IMul5:
.0D98 AA              [2] 00823          tax              ; Product goes in A:X
.0D99 98              [2] 00824          tya
.                         00825
.0D9A                     00826 IMul6:
.0D9A 60              [6] 00827          rts
The 6800 multiply subroutine:
.                         00560 ******************************************************************************
.                         00561 *
.                         00562    * IMul - Multiply integers
.                         00563 *
.                         00564 * Input:
.                         00565 *       A:B = one number
.                         00566 *       X = the other number
.                         00567 *
.                         00568 * Output:
.                         00569 *       A:B = the product
.                         00570 *
.0293                     00571 IMulB    rmb    2         ; Operand
.0295                     00572 IMulC    rmb    1         ; Bits left
.0296                     00573 IMulS    rmb    1         ; Sign of the product
.                         00574
.0297                     00575 IMul
.0297 7F 0296         [6] 00576          clr    IMulS     ; Clear sign of product
.                         00577
.029A DF 02           [5] 00578          stx    Int0      ; Save second number
.                         00579
.029C 4D              [2] 00580          tsta             ; Is first number negative
.029D 2A 07 (02A6)    [4] 00581          bpl    IMul1     ; No
.                         00582
.029F 7C 0296         [6] 00583          inc    IMulS     ; Update sign of product
.                         00584
.02A2 40              [2] 00585             nega             ; Negate the number
.02A3 50              [2] 00586          negb
.02A4 82 00           [2] 00587          sbca   #0
.                         00588
.02A6                     00589 IMul1
.02A6 B7 0293         [5] 00590          staa   IMulB     ; Save the number
.02A9 F7 0294         [5] 00591          stab   IMulB+1
.                         00592
.02AC 96 02           [3] 00593          ldaa   Int0      ; Is the other number negative?
.02AE 2A 0E (02BE)    [4] 00594          bpl    IMul2     ; No
.                         00595
.02B0 7C 0296         [6] 00596          inc    IMulS     ; Update sign of product
.                         00597
.02B3 73 0002         [6] 00598          com    Int0      ; Negate the other number
.02B6 70 0003         [6] 00599          neg    Int0+1
.02B9 25 03 (02BE)    [4] 00600          bcs    IMul2
.02BB 7A 0002         [6] 00601          dec    Int0
.                         00602
.02BE                     00603 IMul2
.02BE 86 10           [2] 00604          ldaa   #16       ; 16 bits to multiply
.02C0 B7 0295         [5] 00605          staa   IMulC
.                         00606
.02C3 4F              [2] 00607          clra             ; Clear product
.02C4 5F              [2] 00608          clrb
.                         00609
.02C5                     00610 IMul3
.02C5 74 0293         [6] 00611          lsr    IMulB     ; Shift number right
.02C8 76 0294         [6] 00612          ror    IMulB+1
.02CB 24 04 (02D1)    [4] 00613          bcc    IMul4     ; Skip add if low bit was clear
.                         00614
.02CD DB 03           [3] 00615          addb   Int0+1    ; Add number to product
.02CF 99 02           [3] 00616          adca   Int0
.                         00617
.02D1                     00618 IMul4
.02D1 78 0003         [6] 00619          asl    Int0+1    ; Shift the other number left
.02D4 79 0002         [6] 00620          rol    Int0
.                         00621
.02D7 7A 0295         [6] 00622          dec    IMulC     ; One fewer bit to do
.02DA 26 E9 (02C5)    [4] 00623          bne    IMul3     ; More?
.                         00624
.02DC 74 0296         [6] 00625          lsr    IMulS     ; Is the product negative?
.02DF 24 04 (02E5)    [4] 00626          bcc    IMul5     ; No
.                         00627
.02E1 40              [2] 00628          nega             ; Negate the product
.02E2 50              [2] 00629          negb
.02E3 82 00           [2] 00630          sbca   #0
.                         00631
.02E5                     00632 IMul5
.02E5 39              [5] 00633          rts
  • 3 weeks later...
Reverse engineering of the TSC FLEX BASIC interpreters is not going well.  I have real doubts about being able to build a compatible interpreter for the 6502 any time soon.  Source code is available for the SWTPC interpreter, but it is not the same.
I was reminded of the Lucidata Pascal compiler.  It generates an interpreted P-code instead of native machine code.  The compiler is also provided in P-code form.  What this means is that if a compatible interpreter can be implemented on the 6502, the compiler comes along for the ride.  The interpreter is not very big, in fact, it is substantially smaller than BASIC.  This is potentially going to be the next native language system to be available after the assembler.
Which brings up my toy Pascal compiler.  I just did some work on the type system to allow single-byte variables, signed, unsigned and character.  These are important for efficiency on an 8-bit system.  The following is some code testing these features:
                          00080 ; 00001 program Test;
                          00081 ; 00002
                          00082 ; 00003   var
                          00083 ; 00004     B                           : byte;
                          00084 ; 00005     B2                          : byte;
                          00085 ; 00006     Ch                          : char;
                          00086 ; 00007     Ch2                         : char;
                          00087 ; 00008     I                           : integer;
                          00088 ; 00009     S                           : shortint;
                          00089 ; 00010     S2                          : shortint;
                          00090 ; 00011     W                           : word;
                          00091 ; 00012
                          00092 ; 00013   begin
                          00093 ; 00014     S := -1;
 0B09 A9 FF           [2] 00094          lda    #-1
 0B0B 8D 0F3C         [4] 00095          sta    S_
                          00096 ; 00015     I := S;
 0B0E AE 0F3C         [4] 00097          ldx    S_
 0B11 8A              [2] 00098          txa
 0B12 09 7F           [2] 00099          ora    #$7F
 0B14 30 02 (0B18)  [2/3] 00100          bmi    2f
 0B16 A9 00           [2] 00101          lda    #0
 0B18                     00102 2:
 0B18 8E 0F3A         [4] 00103          stx    I_
 0B1B 8D 0F3B         [4] 00104          sta    I_+1
                          00105 ; 00016     W := S;
 0B1E AE 0F3C         [4] 00106          ldx    S_
 0B21 8A              [2] 00107          txa
 0B22 09 7F           [2] 00108          ora    #$7F
 0B24 30 02 (0B28)  [2/3] 00109          bmi    2f
 0B26 A9 00           [2] 00110          lda    #0
 0B28                     00111 2:
 0B28 8E 0F3D         [4] 00112          stx    W_
 0B2B 8D 0F3E         [4] 00113          sta    W_+1
                          00114 ; 00017     writeln(I, ' ', W);
 0B2E AE 0F3A         [4] 00115          ldx    I_
 0B31 AD 0F3B         [4] 00116          lda    I_+1
 0B34 20 0D86         [6] 00117          jsr    WriteInteger
 0B37 A9 20           [2] 00118          lda    #32
 0B39 20 0DBF         [6] 00119          jsr    PUTCHR
 0B3C AE 0F3D         [4] 00120          ldx    W_
 0B3F AD 0F3E         [4] 00121          lda    W_+1
 0B42 20 0D8C         [6] 00122          jsr    WriteWord
 0B45 20 0DCC         [6] 00123          jsr    PCRLF
                          00124 ; 00018
                          00125 ; 00019     B := S;
 0B48 AD 0F3C         [4] 00126          lda    S_
 0B4B 8D 0F39         [4] 00127          sta    B_
                          00128 ; 00020     I := B;
 0B4E AE 0F39         [4] 00129          ldx    B_
 0B51 A9 00           [2] 00130          lda    #0
 0B53 8E 0F3A         [4] 00131          stx    I_
 0B56 8D 0F3B         [4] 00132          sta    I_+1
                          00133 ; 00021     W := B;
 0B59 AE 0F39         [4] 00134          ldx    B_
 0B5C A9 00           [2] 00135          lda    #0
 0B5E 8E 0F3D         [4] 00136          stx    W_
 0B61 8D 0F3E         [4] 00137          sta    W_+1
                          00138 ; 00022     writeln(I, ' ', W);
 0B64 AE 0F3A         [4] 00139          ldx    I_
 0B67 AD 0F3B         [4] 00140          lda    I_+1
 0B6A 20 0D86         [6] 00141          jsr    WriteInteger
 0B6D A9 20           [2] 00142          lda    #32
 0B6F 20 0DBF         [6] 00143          jsr    PUTCHR
 0B72 AE 0F3D         [4] 00144          ldx    W_
 0B75 AD 0F3E         [4] 00145          lda    W_+1
 0B78 20 0D8C         [6] 00146          jsr    WriteWord
 0B7B 20 0DCC         [6] 00147          jsr    PCRLF
                          00148 ; 00023
                          00149 ; 00024     S := 20;
 0B7E A9 14           [2] 00150          lda    #20
 0B80 8D 0F3C         [4] 00151          sta    S_
                          00152 ; 00025     S2 := S;
 0B83 AD 0F3C         [4] 00153          lda    S_
 0B86 8D 0F40         [4] 00154          sta    S2_
                          00155 ; 00026     S2 := S2 + S;
 0B89 18              [2] 00156          clc
 0B8A AD 0F40         [4] 00157          lda    S2_
 0B8D 6D 0F3C         [4] 00158          adc    S_
 0B90 8D 0F40         [4] 00159          sta    S2_
                          00160 ; 00027     writeln(S, ' ', S2);
 0B93 AD 0F3C         [4] 00161          lda    S_
 0B96 20 0D30         [6] 00162          jsr    WriteShortint
 0B99 A9 20           [2] 00163          lda    #32
 0B9B 20 0DBF         [6] 00164          jsr    PUTCHR
 0B9E AD 0F40         [4] 00165          lda    S2_
 0BA1 20 0D30         [6] 00166          jsr    WriteShortint
 0BA4 20 0DCC         [6] 00167          jsr    PCRLF
                          00168 ; 00028
                          00169 ; 00029     B := 20;
 0BA7 A9 14           [2] 00170          lda    #20
 0BA9 8D 0F39         [4] 00171          sta    B_
                          00172 ; 00030     B2 := B;
 0BAC AD 0F39         [4] 00173          lda    B_
 0BAF 8D 0F38         [4] 00174          sta    B2_
                          00175 ; 00031     B2 := B2 + B;
 0BB2 18              [2] 00176          clc
 0BB3 AD 0F38         [4] 00177          lda    B2_
 0BB6 6D 0F39         [4] 00178          adc    B_
 0BB9 8D 0F38         [4] 00179          sta    B2_
                          00180 ; 00032     writeln(B, ' ', B2);
 0BBC AD 0F39         [4] 00181          lda    B_
 0BBF 20 0D36         [6] 00182          jsr    WriteByte
 0BC2 A9 20           [2] 00183          lda    #32
 0BC4 20 0DBF         [6] 00184          jsr    PUTCHR
 0BC7 AD 0F38         [4] 00185          lda    B2_
 0BCA 20 0D36         [6] 00186          jsr    WriteByte
 0BCD 20 0DCC         [6] 00187          jsr    PCRLF
                          00188 ; 00033
                          00189 ; 00034     I := 32;
 0BD0 A2 20           [2] 00190          ldx    #32
 0BD2 A9 00           [2] 00191          lda    #0
 0BD4 8E 0F3A         [4] 00192          stx    I_
 0BD7 8D 0F3B         [4] 00193          sta    I_+1
                          00194 ; 00035     writeln(chr(I + I));
 0BDA 18              [2] 00195          clc
 0BDB AD 0F3A         [4] 00196          lda    I_
 0BDE 6D 0F3A         [4] 00197          adc    I_
 0BE1 20 0DBF         [6] 00198          jsr    PUTCHR
 0BE4 20 0DCC         [6] 00199          jsr    PCRLF
                          00200 ; 00036
                          00201 ; 00037     Ch := 'A';
 0BE7 A9 41           [2] 00202          lda    #65
 0BE9 8D 0F41         [4] 00203          sta    CH_
                          00204 ; 00038     Ch2 := Ch;
 0BEC AD 0F41         [4] 00205          lda    CH_
 0BEF 8D 0F3F         [4] 00206          sta    CH2_
                          00207 ; 00039     writeln(Ch, chr(ord(Ch)+1))
 0BF2 AD 0F41         [4] 00208          lda    CH_
 0BF5 20 0DBF         [6] 00209          jsr    PUTCHR
 0BF8 18              [2] 00210          clc
 0BF9 AD 0F41         [4] 00211          lda    CH_
 0BFC 69 01           [2] 00212          adc    #1
 0BFE 20 0DBF         [6] 00213          jsr    PUTCHR
 0C01 20 0DCC         [6] 00214          jsr    PCRLF
                          00215 ; 00040   end.
  • 4 weeks later...
Microsoft BASIC might be easier to port since it was designed for that.
Source is available
https://www.pagetable.com/?p=774
Nice to see a Flex like OS for the 6502.  The OS is well suited to the 6502.
I've been itching to create a version for the 6803... minus the evil 6800 memory map.
There was a 6502 machine shown at a Computer Show back around 1977.
I think it's briefly mentioned in MICRO.
It was supposed to have a CP/M like OS.  I don't think it ever went into production.
Edited by JamesD
Source is available
I am steering away from Microsoft BASIC because it is still under copyright protection.  I do not want to risk putting effort into something then be told I cannot use it.
  • 1 year later...
  • 1 month later...
<snip>
FWIW, the 6809 can copy 16 bits at a time, cutting it's clock cycles significantly.
It just isn't required here since this is likely related to a disk operation and you will never notice the difference.
I haven't written 6809 code in a while so no promise all of this is right, but here you go.
MOVNAM
  LDX  CURFCB+$24  MOVE FILE NAME TO TEMP
  LDY  #$05              COPY 10 BYTES, 2 AT A TIME
MOVNM1
  LDD  -32,X             -32 is -$20
  STD ,X++   HAD TO START AT +$24 SO WE CAN USE AUTO INCREMENT HERE
  LEAY -1,Y    DECREMENT COUNTER, Z IS ONE OF THE ONLY BITS CHANGED BY THIS INSTRUCTION
  BNE  MOVNM1
  LDA -32,X    COPY LAST BYTE
  STA ,X
  RTS
You could also unroll the loop.  This will still be smaller than the 6502 code and should be faster.
  LDX CURFCB+$24
  LDD -32,X
  STD ,X++
  LDD -32,X
  STD ,X++
  LDD -32,X
  STD ,X++
  LDD -32,X
  STD ,X++
  LDD -32,X
  STD ,X++
  LDA -32,X
  STA ,X
  RTS
Or this:
 LDY CURFCB+4
 LDX CURFCB+$24
 LDD ,Y++
 STD ,X++
 LDD ,Y++
 STD ,X++
 LDD ,Y++
 STD ,X++
 LDD ,Y++
 STD ,X++
 LDD ,Y++
 STD ,X++
 LDA ,Y
 STA ,X
 RTS
*edit* forgot one.  Adjust the syntax slightly and this works on the 6801/6803  (LDA -> LDAA, STA -> STAA)
 LDX CURFCB+4
 LDD ,X
 STD 20,X
 LDD 2,X
 STD 22,X
 LDD 4,X
 STD 24,X
 LDD 6,X
 STD 26,X
 LDD 8,X
 STD 28,X
 LDA 10,X
 STA 30,X
 RTS
That last one might also work on the 6800
Edited by JamesD
Memory in both the 6800 and 6809 versions of FLEX was pretty tight, so they probably leaned a bit toward smaller rather than faster code.
Edited by BillG
grammar
On 9/27/2021 at 12:42 AM, JamesD said:
I'm curious what the status of this project is.  Any updates?
I'm sorry, I have not been monitoring this forum lately.
The original prototype has been redone with what I hope is the final memory layout.  The documented "interface" portions of the API have been moved from $200 and up to $800 and up to open the possibility of running it on Apple II family hardware.  I am finalizing the design of the background printing feature as several of the utilities hook into it though I do not currently have a way to test it.
Also in the works is an option to put much of the operating system in ROM, primarily for homebrew systems with only 32K of RAM.
I am also prototyping several "advanced" features:
  • The notion of a "current" drive like in CP/M or DOS to work with the FLEX working drive concept.  This is complete except for changes to the ASN utility to toggle the feature on and off as well as some small modifications related to program file search.
  • A hierarchical directory structure.  HIER was an add-on program which did this with 6809 FLEX.
  • A simplistic command history capability.
  • A reloadable disk driver interface so that frequently used commands can be made "resident" in memory or to implement fast temporary storage.
I have also been working on several tangents to increase the software base:
  • A 6502 version of the LUCIDATA Pascal run-time system to allow running compiled programs and hopefully the compiler itself.  This is pretty much complete except for the ability to run the compiler.
  • An emulator to allow running 6800 FLEX programs on the 6502.  This was barely started before I ran into several issues requiring more study.  I am ready to resume work on this.
  • An emulator to allow running 8080 CP/M programs on the 6502.  This is about half done while I deal with some issues surrounding simulating the CP/M file system with FLEX FMS.
  • A method to convert a Turbo Pascal program compiled for a Z80 into one which can run on an 8080.  This is about 75% complete and was largely done to support the 8080 CP/M emulator.  I do not foresee being able to actually run CP/M Turbo Pascal on the 6502 any time soon though that is a possibility down the road.
Sounds like you've made a lot of progress.
As I said, I've been thinking of creating a Flex-01 for the 6801/6803 series.
This series will run 6800 code, but the built in hardware sits on the direct page (page zero) so programs would require slight modification.
I figured I'd also move the I/O area to the top of memory to make memory management easier for interpreters as long as the memory map was already changing.
Deciding on the memory map is tough.  Once you set it in stone you are stuck with it, so you want to get it right.
I searched for LUCIDATA Pascal and found where you've been posting, and your Github page.
That should work nicely.  In the search I ran across an article in a Heathkit related 1988 newsletter that mentions it was released into the public domain.
I spent several hours porting the UCSD P-Machine to the 6803.  About all I had left was the hardware specific changes, but I had to migrate machines, and the code is... um... currently misplaced.
I wanted to change the UCSD environment so it supported a shell where you could add commands or programs run from the command line under the P-Machine.
That way the system could be expanded easily, and it could run advanced commands that would otherwise require too much memory.
The 6801/6803 places internal registers at $0000..$001F
In general, FLEX programmers are not aware of this.  It is very easy to type "org 0" or just let the assembler default to 0.
The TSC assembler and BASIC intepreters do not load anything below $0020 but I am not familiar enough with them to be able to say whether they use that area for variables.
