Intellivision graphics corruption
If the system is on and you press on some components, not just tap, does the problem happen?  Flexing the board might open a break in a trace.
Also, if you have a cool-down spray, you can cool the components that are hot when the system exhibits its symptoms and see if the cooling recovers the system.
I took out the HD7407P and it seams like the the transistors don't get as hot if it's put so I'm feeling its the problem
4 minutes ago, kevincondrick@gmail.com said:
I don't have anything other then a multi matter
Right.  Red lead on the point labeled TP4 (looks like the + lead on the capacitor) and black lead on TP1 (the - lead of the other capacitor).  DC voltage mode with the unit turned on.  AC voltage mode readings might also be interesting.
6 hours ago, kevincondrick@gmail.com said:
Ok so I tested the cap and I get 20v
That seems too high.  The service manual specifies that its absolute highest should be (unloaded) 19.2V.  When loaded, it should be closer to 16V.  It offers the following instructions:
1) Unplug the transformer power input plug from the power board.  Then:
1510467729_ScreenShot2020-04-30at3_04_12AM.thumb.png.ca8e4afd7949a59fbf807d25c4e4d9ec.png
3 hours ago, kevincondrick@gmail.com said:
Alright I have checked those and also the voltage on the that cap was like 23.1 today  but I'll recheck the diodes I know the one diode was like 5.0 idk if that's good or not
Which diode was that?  And what mode was your meter in?  It's rare to see one that looks for more than about 2V in diode mode, so they tend not to be good for measuring the rating of zener diodes.  At best they can tell you if a diode blocks current one way and allows it the other way, and what the voltage drop in the allow direction is.  If you're measuring it in continuity/resistance mode, then the reading won't be useful other than for "yes/no" answers.
For a "load" test, do you happen to have 4 1K resistors?  If so, bundle the 1st leg of each resistor together, then do the same for the other leg, so that it should be about 250 ohms total.  Connect those across the smaller capacitor and unplug the logic board, but leave the transformer plugged in.  Measure the voltage across the capacitor.
The second one right below the 2200 cap
And I was just testing the diod in the diod test to see if it was reading both ways . Witch it wasn't.
 And in that message I ment .5 not 5.
Also I don't have any resisters on hand
One more thing I did was changed the one 100uf cap on there.
Is it possible for this voltage regulator to be bad?
Edited by kevincondrick@gmail.com
The voltage regulators are standard ICs.  One is a 7805 and the other is a 7812.  But for this issue, they are irrelevant.  One is the +5V output and the other is the +12V output.  The +16V output is unregulated for the most part.  It is tapped before the 7812.  If it's not connected to the logic board, it will be close to 17.1*1.41V because there's nothing draining it.  It relies on loading to bring its voltage within spec.  So the resistor suggestion was to create the expected amount of loading to see if it would respond accordingly.
You said you already tested all the diodes on the logic board too, right?  Because the two+one that are connected to the transistors are supposed to be that load.
