Intellivision graphics corruption
6 minutes ago, kevincondrick@gmail.com said:
Yah there still connected they get really hot tho. Also what about the c5 missing you think that's a problem
Could you switch to AC mode and check the voltage at the same point?
It's hard to read the labels on this low-res scan of the service manual.  If C5 is the blob that's on the negative voltage supply though, it's not a current concern.  You could look at the solder side of the board though, and look for evidence that there may have once been a capacitor there once.  Actually a good high-res picture of the solder side would help to match components to the schematic anyway.
1 minute ago, kevincondrick@gmail.com said:
Yah it jumps around but it seams like 14 is the highest
Then it sounds like the capacitor isn't making a good connection.  It could be the opposite of the usual problem (internal short/leakage) and instead the wire is broken inside.  Did you already replace the 2200?
I have not but I did replace the smaller caps the .1uf and the 100uf. Also I know I blow out that one voltage 12.v regulator wile testing ? so that might be a problem I plan on getting a new one of them. Also I also planed on getting new caps for the 2 main. So if you think that's the problem we can check it all again when I replaced them
Yeah there's definitely something weird going on with the 2200 if you get such crazy readings.  It's as if it connects for a little bit, then due to temperature changes or whatever, it disconnects and then repeats.
Yah those resistors were real hot that on there to I didn't know if that was normal or not.
They were draining a lot of power straight to ground, so yeah they were going to get hot.  It's possible that they are quarter-watt resistors too, and in my head I was thinking of half-watt resistors to do the job.  Basically they have to handle 2W of power.  So definitely not a permanent solution, but I only wanted to know if they would ease the suffering of the logic board.
I mean it did seam to help alittl you think if I were to add more resistors it could get back down to were it needs ?
Possibly, but it's not the best solution.  Just a convenient test.
Here's another question:  With everything still hooked up, test in AC mode, between the two blue points.  Then between the two red points.
1 hour ago, ChildOfCv said:
For future reference, here's a cleaned up schematic and PCB for the power board.  I don't know if I got all the labels right (blobs are just hard to read, after all), but I'll refer to these labels since they're readable.
Ok thanks ?
Do you know what the k means on the diodes
