Using Bits From a Variable
KevKelley
I was looking at possibly freeing up variables if necessary and was curious if you could use part of a variable for a counter and the rest for bit operations?
So based of my understanding, say I have a counter and it only ever used up to 4 bits (%00000000 - %00001010).
Can I use the 4 bits that are never used or when a variable is used does it check all of the bits?
So if I were to check for x{7} while having the counter at 10 (%10001010), would it read both or by turning on x{7} would it be read as 138?
There's only one bit 7, but the counter would be 138, you can turn the first half into a four bit variable aka nibble, it can only count to 15.
   macro _Set_Lo_Nibble
   {1}=(({2}^{1})&$0F)^{1}
end
   def PEEK_Counter = x&$0F
   def POKE_Counter = callmacro _Set_Lo_Nibble x
To set it to 0
POKE_Counter 0 ;notice no equal sign
To check if it's 15
if PEEK_Counter = 15 then...
To add 1
temp5 = (PEEK_Counter) + 1
POKE_Counter  temp5
Then you can use bits 4-7 for other things, it won't affect peeking at the counter since it only checks the first four bits
Ah. Okay. Thanks! I remember reading about nybble variables early on but never knew what for but now it makes sense. I will definitely play around with this.
So then if I have it count up and need to change back to 0 then I would do:
If PEEK_Counter = 15 then POKE_Counter 0
And then add to it using a temp variable.
I'm sure I'll get the hang of this. Thanks very much!
