Asmusr Posted April 26, 2020 Share Posted April 26, 2020 (edited) I decided to see how much speed I could squeeze out of a character based raycaster with only 32 columns. The result can be seen here: https://youtu.be/Y_WR974T_Ak You can also run it yourself using one of the attached files. The frame rate is 15-20 FPS, so this is quite within the limits of a playable game. The question is whether it's too ugly? The algorithm is a simple raycaster where reality is sacrificed for speed. The world is divided into 128 directions, and for each direction I pre-calculate a unit vector (cos(a), sin(a)) in Java and store it as two 8.8 fixed point numbers, i.e. multiply floating point number by 256, round, and store in a 16-bit word. So the output from the Java program is a list of 128 x values and 128 y values as TI-99/4A assembly DATA statements. The player's position is also stored as two 8.8 fixed point numbers (x and y) and the player's direction is stored as one of the 128 directions. For each frame we cast 32 rays from the player's position, each in a different direction, with the player's current direction at the center, so from direction - 16 to direction + 15. Each ray start with the player's position, and we keep adding the unit vector in the given direction until we hit a wall or give up. So for each iteration we need to check what the map contains at the given position. To do this as quickly as possible we make the map width 256 so the map address can be calculated as 256 * y + x + base, which it's very fast to do in assembly. So the central loop of the raycaster looks like this, where (r0,r1) contains the current (x,y) position, (r3,r4) contains directional unit vector, and r8 is a counter for max iterations: cast_ray_1: a r3,r0 ; x += xdir a r4,r1 ; y += ydir movb r1,r6 ; y -> r6 msb movb r0,*r5 ; x -> r6 lsb (for a bit of speed, r5 contains the address of r6 lsb) movb @map(r6),r7 ; Get map entry jne cast_ray_2 ; Not zero is a hit dec r8 ; Distance count down jne cast_ray_1 ; Loop until we give up The value of r8 after the loop determines the distance we have traveled, and the value of r7 determines what we have hit. From the distance we can calculate the height of the wall at the given screen column. The formula is something like max_height / distance, but I use a look-up table. Calculating distances from a single point is resulting in a fish-eye view of the world, as you can see in the demo. A more sophisticated algorithm would calculate the perpendicular distance to the view plane instead. I think it should be possible to fix this without sacrificing speed by having an additional correction look-up table. We now have a height for the walls for each of the 32 screen columns. For each column we want to draw a strip of sky, then a strip of wall, and finally a strip of floor. To do this most efficiently I have pre-drawn the columns at different wall heights in Magellan. That also makes it easy to add the primitive 'textures' you see on the demo. Drawing columns one by one is bad for performance because you have to set up the VDP write address for each row, so instead we set up the write address once and then draw one byte from each column in turn. To fetch the bytes to draw we set up a pointer for each column that point to the right column data. The drawing loop looks like this: upload_screen_loop: li r1,column_ptrs li r2,screen_width upload_screen_loop_1: mov *r1,r0 ; Get column pointer movb *r0+,*r15 ; Write byte to VDP (r15 contains VDPWD) mov r0,*r1+ ; Write pointer back dec r2 jne upload_screen_loop_1 ; Next column dec r3 jne upload_screen_loop ; Next row rt Finally, to push the last bit of performance out of the TI-99/4A, I run the two central loops from scratch pad RAM. The code is on GitHub: https://github.com/Rasmus-M/raycaster raycaster.dsk raycaster.rpk raycaster8.bin See also: Edited October 24, 2020 by Asmusr 16 1 Quote Link to comment Share on other sites More sharing options...
Tursi Posted April 26, 2020 Share Posted April 26, 2020 Looks pretty decent! Nobody would complain about those graphics in a solid game. 2 Quote Link to comment Share on other sites More sharing options...
jrhodes Posted April 26, 2020 Share Posted April 26, 2020 (edited) Add some A.I., movable entities (ghosts), some stationary entities (dots), and a handful of logic routines here and there and you've already got a decent 3d-pacman clone. Love it. Edited April 26, 2020 by jrhodes Quote Link to comment Share on other sites More sharing options...
ti99iuc Posted April 26, 2020 Share Posted April 26, 2020 fantastic result if you ask! ? Quote Link to comment Share on other sites More sharing options...
Elia Spallanzani fdt Posted April 26, 2020 Share Posted April 26, 2020 While refueling your spaceship hits a rock and crashes: you are now in the tunnel and you have to go out to retrieve another parsec spaceship and return to fight. But be careful because the evil aliens take advantage to land and hunt you down. 5 Quote Link to comment Share on other sites More sharing options...
Gip-Gip Posted April 26, 2020 Share Posted April 26, 2020 I did not expect this to be finished so quickly! And it runs nearly as fast as my engine, if not faster at this point.. Shows I have no right in dictating what can and cannot be done How big of a pain would it be to implement entities like in Wolf3D? Quote Link to comment Share on other sites More sharing options...
WhataKowinkydink Posted April 26, 2020 Share Posted April 26, 2020 I couldn't get the rpk to load Quote Link to comment Share on other sites More sharing options...
Asmusr Posted April 26, 2020 Author Share Posted April 26, 2020 2 hours ago, Gip-Gip said: How big of a pain would it be to implement entities like in Wolf3D? Like enemies and treasure? I think it might be possible to draw something, but the scaling would be a problem, and you would soon run of of characters. Quote Link to comment Share on other sites More sharing options...
Asmusr Posted April 26, 2020 Author Share Posted April 26, 2020 (edited) 13 minutes ago, WhataKowinkydink said: I couldn't get the rpk to load In which emulator? Edited April 26, 2020 by Asmusr Quote Link to comment Share on other sites More sharing options...
Asmusr Posted April 26, 2020 Author Share Posted April 26, 2020 According to this page http://www.permadi.com/tutorial/raycast/rayc8.html fisheye correction should be done by multiplying the height with the cosine of the angle between the ray and the player's direction, which makes a lot of sense, but if I do that the walls bend up at the edges instead of down like they do now. I can't think of any explanation except that my algorithm is just too inaccurate and/or the resolution too low. Quote Link to comment Share on other sites More sharing options...
Elia Spallanzani fdt Posted April 26, 2020 Share Posted April 26, 2020 Can you make enemies as if they were movable and semitransparent walls? Quote Link to comment Share on other sites More sharing options...
WhataKowinkydink Posted April 26, 2020 Share Posted April 26, 2020 10 minutes ago, Asmusr said: In which emulator? MESS 0.152 (I know its a bit old - long story) Quote Link to comment Share on other sites More sharing options...
+mizapf Posted April 26, 2020 Share Posted April 26, 2020 Short story: Please use the current release. ? I cannot support ancient releases. 1 Quote Link to comment Share on other sites More sharing options...
WhataKowinkydink Posted April 26, 2020 Share Posted April 26, 2020 4 minutes ago, mizapf said: Please use the current release. ? I cannot support ancient releases. That sounds good, but if you knew the "long story" then you'd know that really isn't an option. For better or worse, the computer is going to have to stay as is for the time being (i.e., no updates can be made now). Quote Link to comment Share on other sites More sharing options...
+mizapf Posted April 26, 2020 Share Posted April 26, 2020 Could be, still: You'll have to expect that lots of things just won't work, and there is likely no way to get them going. I'd really love to give as much support to any MAME user as possible, but this is an evolving system, and on https://www.mizapf.de/en/ti99/mame/changes you can see how much has been done since then. So I hope you (and others) understand why it is virtually impossible for me to help with old releases. 1 Quote Link to comment Share on other sites More sharing options...
Elia Spallanzani fdt Posted April 26, 2020 Share Posted April 26, 2020 (edited) 2 hours ago, Asmusr said: if I do that the walls bend up at the edges instead of down like they do now. You have 90 degrees field of view (32 - 128), the page you link use 60 degrees field of view (~21 - 128). Edited April 26, 2020 by Elia Spallanzani fdt Quote Link to comment Share on other sites More sharing options...
Tursi Posted April 26, 2020 Share Posted April 26, 2020 5 hours ago, Asmusr said: According to this page http://www.permadi.com/tutorial/raycast/rayc8.html fisheye correction should be done by multiplying the height with the cosine of the angle between the ray and the player's direction, which makes a lot of sense, but if I do that the walls bend up at the edges instead of down like they do now. I can't think of any explanation except that my algorithm is just too inaccurate and/or the resolution too low. You only have 32 columns - maybe you can just have a fixed correction table? Quote Link to comment Share on other sites More sharing options...
sometimes99er Posted April 27, 2020 Share Posted April 27, 2020 Very nice. The one in Don't mess with Texas "feels" a bit better. Quote Link to comment Share on other sites More sharing options...
Tursi Posted April 27, 2020 Share Posted April 27, 2020 1 hour ago, sometimes99er said: Very nice. The one in Don't mess with Texas "feels" a bit better. That one cheats quite a bit though.. you wouldn't be able to walk freely around that engine. 2 Quote Link to comment Share on other sites More sharing options...
sometimes99er Posted April 27, 2020 Share Posted April 27, 2020 7 hours ago, Tursi said: That one cheats quite a bit though.. you wouldn't be able to walk freely around that engine. Oh. Okay. That makes a difference. Quote Link to comment Share on other sites More sharing options...
artrag Posted April 27, 2020 Share Posted April 27, 2020 20 hours ago, Asmusr said: According to this page http://www.permadi.com/tutorial/raycast/rayc8.html fisheye correction should be done by multiplying the height with the cosine of the angle between the ray and the player's direction, which makes a lot of sense, but if I do that the walls bend up at the edges instead of down like they do now. I can't think of any explanation except that my algorithm is just too inaccurate and/or the resolution too low. Try this other DDA algorithm to prevent fisheye effect. It is able to compute directly the wall distance perpendicular to the screen plane without multiplications. https://lodev.org/cgtutor/raycasting.html#The_Basic_Idea_ 1 Quote Link to comment Share on other sites More sharing options...
Asmusr Posted April 27, 2020 Author Share Posted April 27, 2020 2 hours ago, artrag said: Try this other DDA algorithm to prevent fisheye effect. It is able to compute directly the wall distance perpendicular to the screen plane without multiplications. https://lodev.org/cgtutor/raycasting.html#The_Basic_Idea_ I'm familiar with that algorithm from when I made a raycaster for the F18A, but for this project I want something simpler and faster. 1 Quote Link to comment Share on other sites More sharing options...
Elia Spallanzani fdt Posted April 27, 2020 Share Posted April 27, 2020 Maybe this can help? https://santiontanon.blogspot.com/2017/09/raycasting-in-tales-of-popolon-msx.html?m=1 1 Quote Link to comment Share on other sites More sharing options...
PeteE Posted April 29, 2020 Share Posted April 29, 2020 On 4/26/2020 at 2:04 AM, Asmusr said: Drawing columns one by one is bad for performance because you have to set up the VDP write address for each row, so instead we set up the write address once and then draw one byte from each column in turn. To fetch the bytes to draw we set up a pointer for each column that point to the right column data. The drawing loop looks like this: upload_screen_loop: li r1,column_ptrs li r2,screen_width upload_screen_loop_1: mov *r1,r0 ; Get column pointer movb *r0+,*r15 ; Write byte to VDP (r15 contains VDPWD) mov r0,*r1+ ; Write pointer back dec r2 jne upload_screen_loop_1 ; Next column dec r3 jne upload_screen_loop ; Next row rt Hi Rasmus, thanks for sharing your code for this. I have made a small performance improvement in the screen drawing code, saving 20 cycles per byte written to the VDP, by removing the column pointer increment and write back, instead using self-modifying code to update the column offset for each row. The @0(r1) part of the instruction is modified by the "clr @self_modifying_offset" and "inc @self_modifying_offset". ********************************************************************* * * Upload screen * upload_screen: .proc mov @dbl_buffer_flag,r0 andi r0,>0001 sla r0,10 ai r0,nametb bl @vwad clr @self_modifying_offset li r3,screen_height bl @upload_screen_loop_pad .endproc *// upload_screen ********************************************************************* * * Upload screen loop * upload_screen_loop: li r0,column_ptrs li r2,screen_width upload_screen_loop_1: mov *r0+,r1 ; Get column pointer upload_screen_offset: movb @0(r1),*r15 ; Write byte to VDP (r15 contains VDPWD) dec r2 jne upload_screen_loop_1 ; Next column inc @self_modifying_offset dec r3 jne upload_screen_loop ; Next row rt upload_screen_loop_end: equ $ *// upload_screen_loop self_modifying_offset: equ upload_screen_offset+2-upload_screen_loop+upload_screen_loop_pad 2 Quote Link to comment Share on other sites More sharing options...
+FarmerPotato Posted April 29, 2020 Share Posted April 29, 2020 I think you are all talking about Graphics 1 mode? In bitmap, I like to arrange the screen table as chars 0:8:16:24 ... 1:9:17:25. So that I set the VDPWA and stripe down 8 chars in a column, then the next 8, and so on. Repeat for the other 3rds. I worked on this when I was trying a rectangle fill. Quote Link to comment Share on other sites More sharing options...
