COCO3: HOW TO MAKE THE BORDER BLACK IN 256X192 4 COLOR PROGRAMS!!!
swallis7
    HOW TO MAKE THE BORDER BLACK IN 256x192 4 COLOR PROGRAMS!!!
I figured out how to make the border black instead of white in 256x192 4 color
games/programs!!!   (Running Color Computer 1/2 games on a CoCo 3.)
This works in RGB and CMP modes.  I have the palette set to RGB colors,
so this effectively does an "RGB Patch" too!
It has the added benefit of being able to change the
Black/Blue/Red/White colors to whatever palette colors you want (some
game just don't look good in Black/Blue/Red/White).
I haven't figured out how many colors there are to choose from yet.
And you can change the border color to whatever palette color you want!
So far I've tried this with Donkey King, Downland CC3 and a couple of
other games, but it should work on any 256x192x4 program you want.
I did this using MAME 0.187 and it works in VCC.
I do not have a real CoCo 3 to try this out on.
I also did this years ago on a real CoCo 3, it seems like there were
less commands required then, so maybe this can be simplified??
MY TEST DISC:
It is the "Disk EdtAsm+ 1.0" disk (for testing) with these files added:
VM.BAS         Sets the video mode (see the code below).
VM.ASM         Sets the video mode (see the code below).
VM.BIN         Sets the video mode (only good for Donkey King unless recompiled).
DONKEY.BIN     Donkey King.
DONKEY2.BIN    Donkey King with the video mode commands at $340D-$341A removed (for testing).
GETSMART.BAS   A Barbara Feldman picture (for testing whether the screen is displaying the way you want).
TO TRY THIS OUT:
For Donkey King:  Just insert my test disc and RUN"VM.BAS".
(Or use your Donkey King disc and run the BASIC code below.)
Since this is not a perfect fix for Donkey King (it goes from graphics
mode to text mode & back to graphics mode when its first started);
press Enter, wait 7 seconds, press 1, press Y to make the game start.
For Downland CC3:  LOAD"VM.BAS", edit line 110 and change the Vertical
Offset as stated, insert the Downland CC3 disc, then type RUN.
NOTE1: "VM.BAS" is all that is needed for some games (Donkey King is a
VERY friendly game to test with).
"VM.ASM" is something I made to experiment with, since some ML games
write over any BASIC program in memory when loaded.
NOTE2: It's funny to note that when you set the video mode with this
($FF99), then Donkey King sets it the CoCo 2 way ($FF22) it seems to
basically get ignored... but not completely... hmmm.
Enjoy!
"VM.BAS"
10 ' THIS SETS THE COCO3 VIDEO MODE TO 256X192 4 COLORS.
20 ' TO TRY IT ON ANOTHER GAME:
30 ' CHANGE THE VIDEO MODE?, VERTICAL OFFSET AND COLORS AS NEEDED/DESIRED.
40 '
50 LOADM"DONKEY"
60 '
70 POKE&HFF90,126 'COCO COMPAT MODE
80 POKE&HFF91,0 'MMU-NOT NEEDED I GUESS
90 POKE&HFF98,128 'BIT PLANE GRAPHICS-NOT ALPHA TEXT
100 POKE&HFF99,9 'VIDEO MODE-256X192 4 COLORS
110 POKE&HFF9D,224:POKE&HFF9E,64 'VERTICAL OFFSET-DOWNLAND CC3=224,128
120 POKE&HFFB0,0:POKE&HFFB1,11:POKE&HFFB2,7:POKE&HFFB3,48 'CMP PALETTES-BLACK,BLUE,RED,WHITE
130 POKE&HFFB0,0:POKE&HFFB1,9:POKE&HFFB2,36:POKE&HFFB3,63 'RGB PALETTES-BLACK,BLUE,RED,WHITE
140 POKE&HFF9A,0 'BORDER COLOR!
150 '
160 EXEC
"VM.ASM"
Not the prettiest code, I tried in on Donkey King.
To try it on another game:
Change the "ORG $3000" to the address you want this to load at,
change the "JMP $3203" to the Start Address of the game you are using,
change the Video Mode, Vertical Offset and Colors and needed/desired.
00010     ORG $3000
00020 BEGIN    JMP START
00030     FDB DONE-BEGIN
00040 * COCO COMPAT MODE
00050 START    LDA    #$7E
00060     STA    $FF90
00070 * MMU-DON'T NEED THIS
00080     LDA    #$00
00090     STA    $FF91
00100 * BIT PLANE GRP-NOT ALPHA TEXT
00110     LDA    #$80
00120     STA    $FF98
00130 * VIDEO MODE-256X192 4 COLORS
00140     LDA    #$09
00150     STA    $FF99
00160 * VERTICAL OFFSET 1
00170     LDA    #$E0
00180     STA    $FF9D
00190 * VERTICAL OFFSET 2
00200     LDA    #$40
00210     STA    $FF9E
00220 * RGB PALETTE - BLACK
00230     LDA    #$00
00240     STA    $FFB0
00250 * RGB PALETTE - BLUE
00260     LDA    #$09
00270     STA    $FFB1
00280 * RGB PALETTE - RED
00290     LDA    #$24
00300     STA    $FFB2
00310 * RGB PALETTE - WHITE
00320     LDA    #$3F
00330     STA    $FFB3
00340 * BORDER COLOR!
00350     LDA    #$00
00360     STA    $FF9A
00370 * EXEC DONKEY KING...
00380     JMP    $3203
00390 DONE    EQU    *
00400     END    START
coco 3 video mode test!.dsk
Edited by swallis7
