Kung Fu Master - POKEY replacement?
Synthpopalooza
Ok ... I have been thinking about doing Kung Fu Master music in POKEY.  If I can do this ...
Is there anyway that the cart can be hacked to play the POKEY music in place of the current TIA music?  Or some way to disassemble the ROM to hack in the music?  A recent facebook post about KFM kinda inspired me in this direction ...
Not really. Not very easily anyhow. That is why when I see these sound files for all types of different games being made it makes little sense to me cause they can't be implemented into pre-existing programs nor into new programs that didn't have such a thing in mind in the first place. It would be neat if it could but realistically it's not gonna happen.
Yes, it can.  It's not something I know how to do, but @tep392 has done this with Donkey Kong and was going to do Donkey Kong Junior and Mario Bros, but I believe he had too much on his plate with the XM to finish those.  Double Dragon is my biggest hope for this.  KFM is a 32K game, so disassembly is less challenging than if it were bankswitched.  If it were to get the upgrade treatment I'd like to see some additional features and sprites added, like the jumpkick and fall-away enemies.  But, all this would probably require it to be bumped up to 48K and upgraded music would still be nice to have.
I think one would want to add the music first before expanding the game out further. You wouldn't want to end up with the kernel being "too busy" like with other 7800 games. It would be cool to have POKEY - dual POKEY via PokeyMax - music as an option for those who have an XBoard, an SD Cart with POKEY socket, or say a hacked Ballblazer cart and aren't going to be getting an XM. Because if an updated game supported the XM, then the arcade's YM2151 audio could be added.
Crom knows the 7800 versions of Kung-Fu Master and Double Dragon could really use those audio mods...
Kung Fu Master doesn't need double POKEY.  It has a standard AY chip for sound (3 square plus 1 noise) not dissimilar from what Colecovision has.  POKEY is more than capable.
In fact, the main in game music can be done using a bass square wave, and 1.79 mhz pink noise, with 2 POKEY channels free for sound fx.
Also:
POKEY can do 4-bit audio sampling.  You write $10 to $1F to AUDCx very quickly.  This plays a sample.  Drawback is it takes 100% CPU so can't be done in game.  It can be used for that kung fu yell at the beginning, or when you lose a life (freeze screen while sound plays, then resume).  Berzerk for 5200 does this for robot voices.
OK, here you go ... main music.  Only 2 POKEY channels.
AUDCTL=$41
00 - $0x noise snare
01 - $Ax square bass
Two channels free. :)
Emulation:  Use A7800, not Prosystem, Prosystem won't play the snare.
kfm-main-4000.A78 kfm-main-4000.asm kfm-main-4000.bin kfm-main-450.A78 kfm-main-450.asm kfm-main-450.bin
Edited by Synthpopalooza
The other musics as follows:
Opening:  $Ax in 16-bit mode, and $Ax in 8-bit ... only two channels
Stage Clear:  $Ax in 16-bit, and 2 $Ax 8-bit channels
Defeat Boss: Same as above
Game Over:  Same as opening, only two channels.
This is easily doable with standard POKEY $Ax settings.
  • 1 month later...
Kung Fu Master intro music.
Simple setup:
$00 - silent
$01 - $Ax 16-bit square wave - bass
$02 - $Ax standard 8-bit square - lead
Works perfectly in both Prosystem and A7800.
All of the music will rely on the standard square waves.
kfm-intro-450.A78 kfm-intro-450.asm kfm-intro-450.bin kfm-intro-4000.A78 kfm-intro-4000.asm kfm-intro-4000.bin
Game over music
This time, the music is played in standard 8-bit square waves in the last two channels.  The bass channel never goes below B2 (255 on the standard square table), and putting the music on the last two here, allows for AUDCTL to stay at $50.  The fewer changes we have to make to AUDCTL, the easier this will be to hack in.
As before ... emulation (Prosystem or A7800) is 100% to real hardware.
kfm-gameover-4000.A78 kfm-gameover-4000.asm kfm-gameover-4000.bin kfm-gameover-450.A78 kfm-gameover-450.asm kfm-gameover-450.bin
KFM - Intro - Real HW - 20200702.mp3 (x3 Pressing Reset when finished)
On 7/1/2020 at 11:23 PM, Synthpopalooza said:
Updated main music.
KFM - Main Theme - Real HW - 20200702.mp3 (~1 Minute loop)
On 7/2/2020 at 12:02 AM, Synthpopalooza said:
Game over music
KFM - Game Over - Real HW - 20200702.mp3 (x3 Pressing Reset when finished)
  • 4 weeks later...
Last two.
Stage complete:
AUDCTL=$50
0 - silent
1 - $Ax bass
2 - $Ax lead
Game complete
AUDCTL=$50
0 - silent
1 - $Ax bass
2 - $ax lead
3 - $Ax harmony
All of these work 100% in either Prosystem or A7800
Now ... someone hack this into the 7800 game. :)
kfm-complete-450.asm kfm-complete-450.bin kfm-complete-4000.A78 kfm-complete-4000.asm kfm-complete-4000.bin kfm-complete-450.A78 kfm-endstage-450.asm kfm-endstage-450.bin kfm-endstage-4000.A78 kfm-endstage-4000.asm kfm-endstage-4000.bin kfm-endstage-450.A78
Do you have the means to burn eproms or flash a dev cart for use with your XM yet or are you still getting others to test on real hardware after you write these? Would be a real shame if you don't have the means to do so on your own.
