Previous input check
flame
Hey everyone,
Is there a way to check if the direction input was the same as the last ? I have a value that needs to reset if it is not.
MoveRT:
	lda direction
	cmp #$20
	beq .Reset
	jmp .Done
MoveLT:
	lda direction
	cmp #0
	beq .Reset
	jmp .Done
.Reset
	lda #0
	sta value
.Done:	rts
I have a direction facing that switches thanks to advice from @SpiceWare
This is what I am trying to do, but I am missing something.
MoveRT	subroutine
	lda direction
	cmp #0
	beq .repeat
	lda #0
	sta steps
.repeat
	inc steps
	lda #0
	sta direction
	rts
MoveLT	subroutine
    lda direction
	cmp #$20
	beq .repeat
	lda #0
	sta steps
.repeat
	inc steps
	lda #$20
	sta direction
	rts
I friend chimed in with some advice, this seems to be working !
MoveRT subroutine
        lda #0
        beq .move ; always branch
MoveLT
        lda #$20
.move
        cmp direction
        sta direction
        beq .repeat
        lda #1
        sta steps
        rts
.repeat
        inc steps
        rts
I haven’t tested it but believe this will do the same thing, in fewer bytes and worst-case cycles. (You could also change the #1 to #0 and remove the first rts, trading a few cycles for a byte.)
I don't recall what direction is holding, but if you save the value of SCHWA from one frame you can easily compare it using EOR.
    lda SWCHA
    eor SAVED_SWCHA
    beq no_change
; handle change here, any bit in the accumulator that's a 1 is a joystick direction that's not the same as the prior frame
no_change:
    lda SWCHA
    sta SAVED_SWCHA
