+TheBF Posted July 17, 2022 Share Posted July 17, 2022 Ya it can make you crazy when you are used to JMPing whereever you need to. Here is how the DxForth labels look. They are numbered since you don't write walls of code in Forth Assembler, just simple sub-routines. I think you could get the hang of this pretty quick. \ ======================================= CODE TEST ( n -- n') 1 $: R4 DEC, R4 400 CI, 2 $ JEQ, R1 DEC, R2 INCT, R4 R4 MOV, 1 $ JNE, 2 $: NEXT, ENDCODE CODE TEST3 1 $: 2 LIMI, 0 LIMI, 1 $ JMP, NEXT, ENDCODE CODE BADTEST 1 $: R1 BEEF LI, 2 $ ( this will cause "Un-resolved forward jump") 1 $ JMP, NEXT, ENDCODE 1 Quote Link to comment Share on other sites More sharing options...
+TheBF Posted July 17, 2022 Share Posted July 17, 2022 I have been threatening to make more normal looking, prefix Forth assembler but did not do it yet. MPE Forth (UK) has had prefix assemblers in their systems for 40 years. 1 Quote Link to comment Share on other sites More sharing options...
GDMike Posted July 17, 2022 Author Share Posted July 17, 2022 Here I can get the time and date as a copy \ paste item in SNP ITIME MOV @POS,R0 BLWP @VSBR MOVB R1,@KYBUF BL @SYSDL MOV @SWDT,R4 * check if clock is on CI R4,0 JEQ ITIMEE * exit LI R0,0 LI R1,ITBUF * go get the time LI R2,8 BLWP @VMBR MOV @POS,R0 BLWP @VMBW AI R0,8 MOV R0,@POS * adjust POS ITIMEE B @CUR *** * * INSERT DATE **** IDATE MOV @SWDT,R4 BLWP @VSBR MOVB R1,@KYBUF BL @SYSDL CI R4,0 JEQ IDATEE LI R0,40 LI R1,IDBUF * go get the date LI R2,8 BLWP @VMBR MOV @POS,R0 BLWP @VMBW AI R0,8 MOV R0,@POS IDATEE B @CUR Quote Link to comment Share on other sites More sharing options...
GDMike Posted July 17, 2022 Author Share Posted July 17, 2022 7 minutes ago, TheBF said: I have been threatening to make more normal looking, prefix Forth assembler but did not do it yet. MPE Forth (UK) has had prefix assemblers in their systems for 40 years. i mean, most of what im doing doesnt even require an assembler routine that i can think of actually. BUT its nice to know it can be loaded up when I need, Im sure i can work through it, but I seemed to find a WORD to do what I needed...instead of making a assembled routine... Quote Link to comment Share on other sites More sharing options...
GDMike Posted July 17, 2022 Author Share Posted July 17, 2022 I'll finish up with SNP 2.2 and leave ver 3 (DB ver) alone. I think it's just too much to try and add in the DB stuff, and probably should just be a standalone program designated for DB. I'm happy with SNP and all it can do. I'll probably ease back into Turbo Forth, and start small as my memory only lets me do that. I do have the quick reference guide to everything you need to know about TF ? handy. Quote Link to comment Share on other sites More sharing options...
GDMike Posted July 17, 2022 Author Share Posted July 17, 2022 (edited) I think I'll make a >6000 - >7FFF ram memory display by decimal value, hex and ASCII like I did in assembly, but do it in Forth. But I'll do it with 80 column style. And designed for supercart ram. Plus it's something I know a bit about, like apples and oranges..mmm ..Orange Edited July 17, 2022 by GDMike 1 Quote Link to comment Share on other sites More sharing options...
+TheBF Posted July 17, 2022 Share Posted July 17, 2022 9 hours ago, GDMike said: I think I'll make a >6000 - >7FFF ram memory display by decimal value, hex and ASCII like I did in assembly, but do it in Forth. But I'll do it with 80 column style. And designed for supercart ram. Plus it's something I know a bit about, like apples and oranges..mmm ..Orange If you do this in TF look up the code for DUMP. It will give you lots of ideas how to do this. 1 Quote Link to comment Share on other sites More sharing options...
apersson850 Posted July 17, 2022 Share Posted July 17, 2022 18 hours ago, GDMike said: I'm receiving military time format and I'd like to see it in my SNP program as AM/PM time instead. No, you don't. Time to modernize! ? 1 Quote Link to comment Share on other sites More sharing options...
GDMike Posted July 17, 2022 Author Share Posted July 17, 2022 1 hour ago, apersson850 said: No, you don't. Time to modernize! ? I'm just wondering if it's going to slow the key response down too much. I mean, I might get by doing it with timestamp during Ctrl T paste time, but maybe not at the desktop level. Quote Link to comment Share on other sites More sharing options...
apersson850 Posted July 17, 2022 Share Posted July 17, 2022 (edited) On 7/17/2022 at 2:47 AM, Lee Stewart said: It should be as simple as setting up the output string with “AM”, testing for hour > 12 and, if so, subtracting 12 and changing the ‘A’ of “AM” to ‘P’. Post your code for the time and we can work with it. Not really. Due to the ridiculous way of telling the time this old fashioned way, you should change AM to PM if the hour>12, but compute hour mod 12, then if hour=0 add 12. Edited July 18, 2022 by apersson850 2 Quote Link to comment Share on other sites More sharing options...
apersson850 Posted July 17, 2022 Share Posted July 17, 2022 14 hours ago, GDMike said: Here I can get the time and date as a copy \ paste item in SNP ITIME MOV @POS,R0 BLWP @VSBR MOVB R1,@KYBUF BL @SYSDL MOV @SWDT,R4 * check if clock is on CI R4,0 JEQ ITIMEE * exit LI R0,0 LI R1,ITBUF * go get the time LI R2,8 BLWP @VMBR MOV @POS,R0 BLWP @VMBW AI R0,8 MOV R0,@POS * adjust POS ITIMEE B @CUR *** * * INSERT DATE **** IDATE MOV @SWDT,R4 BLWP @VSBR MOVB R1,@KYBUF BL @SYSDL CI R4,0 JEQ IDATEE LI R0,40 LI R1,IDBUF * go get the date LI R2,8 BLWP @VMBR MOV @POS,R0 BLWP @VMBW AI R0,8 MOV R0,@POS IDATEE B @CUR Compare the two. There are some hints about saving memory and time by removing redundant instructions. Remember that the TMS 9900 is pretty slow to execute an instruction. It usually pays to make an instruction more complex (more complicated addressing), if that means you can remove another instruction. Never load an immediate as zero, when you have the CLR instruction. Also remember that many instructions, like MOV, compares the result to zero intrinsically. Here it's improved a bit. You waste a lot of memory with your coding ITIME MOV @POS,R0 BLWP @VSBR MOVB R1,@KYBUF BL @SYSDL CLR R0 ; You may need this reset to zero soon anyway C @SWDT,R0 * check if clock is on - by a direct compare with zero. You dont' need to move what's at SWDT anywhere here JEQ ITIMEE * exit LI R1,ITBUF * go get the time LI R2,8 BLWP @VMBR MOV @POS,R0 BLWP @VMBW A R2,@POS * adjust POS R2 already contains 8 ITIMEE B @CUR *** * * INSERT DATE **** IDATE BLWP @VSBR MOVB R1,@KYBUF BL @SYSDL MOV @SWDT,R4 ; A MOV compares data to zero JEQ IDATEE LI R0,40 LI R1,IDBUF * go get the date LI R2,8 BLWP @VMBR MOV @POS,R0 BLWP @VMBW A R2,@POS ; You stored 8 in R2 a few instructions up IDATEE B @CUR 2 Quote Link to comment Share on other sites More sharing options...
apersson850 Posted July 17, 2022 Share Posted July 17, 2022 15 hours ago, GDMike said: ************************************ * PICL TIPI CLOCK USAGE * * 04/09/22* 80 column version 3.0 * * modified 06/01/22 * ************************************ MDS DATA 0 MDT DATA 0 DSRC MOV R11,@SAVRTN CLR R4 MOV @POS,@MDT LI R0,PABADR LI R1,PAB LI R2,20 BLWP @VMBW MOVB @READ,R1 LI R0,PABADR BLWP @VSBW LI R6,PABADR+9 MOV R6,@POINTR BLWP @DSRLNK DATA 8 LI R0,PABADR+1 BLWP @VSBR MOV @POS,R0 SRL R1,13 AI R1,>30 SLA R1,8 CI R1,>3000 JEQ DSRE MOV @POS,R0 CI R1,0 JEQ DSRERR DSRE MOV @MDS,@POS MOV @MDT,R0 MOV @SAVRTN,R11 RT *R11 I DINT have time to make comments in this one.. Here's another example of some improvements. ************************************ * PICL TIPI CLOCK USAGE * * 04/09/22* 80 column version 3.0 * * modified 06/01/22 * ************************************ MDS DATA 0 MDT DATA 0 DSRC CLR R4 ; No need to save R11 when you don't do another BL before you return MOV @POS,@MDT LI R0,PABADR LI R1,PAB LI R2,20 BLWP @VMBW MOVB @READ,R1 LI R0,PABADR BLWP @VSBW LI R6,PABADR+9 MOV R6,@POINTR BLWP @DSRLNK DATA 8 LI R0,PABADR+1 BLWP @VSBR MOV @POS,R0 SRL R1,13 AI R1,>30 SLA R1,8 CI R1,>3000 JEQ DSRE MOV @POS,R0 MOV R1,R1 ;Compares R1 to zero, but shorter than CI JEQ DSRERR DSRE MOV @MDS,@POS MOV @MDT,R0 RT ; Not RT *R11. RT implies B *R11, so it's already included. 2 Quote Link to comment Share on other sites More sharing options...
GDMike Posted July 17, 2022 Author Share Posted July 17, 2022 (edited) 4 hours ago, apersson850 said: ; Not RT *R11. RT implies B *R11, so it's already included. It's just my notes written this way. But yeah, this is known already. I cut the heading in this code by mistake that doesn't show the sav R11, but this is a BL routine, you'd not know that. It's handled. Taco night! Whohoo. Thx for your help. Edited July 17, 2022 by GDMike Quote Link to comment Share on other sites More sharing options...
apersson850 Posted July 18, 2022 Share Posted July 18, 2022 11 hours ago, GDMike said: I cut the heading in this code by mistake that doesn't show the sav R11, but this is a BL routine, you'd not know that. It's handled. Maybe it's called by a BL. That I can't see here, of course. But that doesn't matter anyway. The important thing is that there is no BL call in this part, only BLWP, so there's no need to save the R11 register. It contains the address to return to, and it's not disturbed by another BL inside this procedure. Quote Link to comment Share on other sites More sharing options...
apersson850 Posted July 18, 2022 Share Posted July 18, 2022 (edited) One way to convert 0-23 hours to the old style format. MOV @HOUR,R3 ; Fetch the hour (integer value) from somewhere CLR R2 LI R1,12 DIV R1,R2 MOV R3,R3 ; Check if reminder is zero JNE READY MOV R1,R3 ; If zero replace by 12 READY At READY, you now have the vaule in the range 12, 1-12, 1-11 instead of 0-23. You then have to convert the hour value in R3 to characters to display. READY LI R1,10 CLR R2 DIV R1,R2 ; Leaves first digit in R2, second in R3 MOVB @MYWS+5,R3 ORI R3,>3030 ; Converted to characters in R3 (if you want both characters in one register) Another option here is of course to keep the two digits separate, and convert them to characters in the registers where they are and then send them to the screen. DIV is an instruction with a long execution time, but try divide by ten and calculate both the quotient and the reminder without using DIV, and do it faster. It's not that easy. Edited July 18, 2022 by apersson850 3 1 Quote Link to comment Share on other sites More sharing options...
Willsy Posted July 18, 2022 Share Posted July 18, 2022 That's neat. The old 9900 is so versatile. 1 Quote Link to comment Share on other sites More sharing options...
+Lee Stewart Posted July 18, 2022 Share Posted July 18, 2022 3 hours ago, apersson850 said: At READY, you now have the value in the range 12, 1-12, 1-11 instead of 0-23. You then have to convert the hour value in R3 to characters to display. READY LI R1,10 CLR R2 DIV R2,R1 ; Leaves first digit in R2, second in R3 MOVB @MYWS+5,R3 ORI R3,>3030 ; Converted to characters in R3 (if you want both characters in one register) Typo in third line should be DIV R1,R2 ...lee 3 Quote Link to comment Share on other sites More sharing options...
apersson850 Posted July 18, 2022 Share Posted July 18, 2022 5 minutes ago, Lee Stewart said: Typo in third line... Thank you. I did try to check my typing, but alas... 3 Quote Link to comment Share on other sites More sharing options...
apersson850 Posted July 18, 2022 Share Posted July 18, 2022 (edited) Here's another way to fix the hour. MOV @HOUR,R3 ; Fetch the hour (integer value) from somewhere LI R1,12 C R3,R1 JLT SMALL S R1,R3 SMALL MOV R3,R3 JNE READY MOV R1,R3 ; If zero replace by 12 READY Ten words of memory instead of nine, but no DIV, so it should be faster anyway. DIV is more efficient in the second case, where we need both the quotient and the reminder. Edited July 18, 2022 by apersson850 5 Quote Link to comment Share on other sites More sharing options...
GDMike Posted July 18, 2022 Author Share Posted July 18, 2022 Great stuff I'll try to implement something this week. And I'll be done with SNP, as is. Quote Link to comment Share on other sites More sharing options...
GDMike Posted July 18, 2022 Author Share Posted July 18, 2022 (edited) latest downloads for SNP - ver 2.2 july 2022 ill look for help docs, but there is help with F9 key program name is SNP start name is SNP must have SAMS card (1mb) and F18A otherwise ask me for the 40 column vers SNP Edited July 18, 2022 by GDMike 1 Quote Link to comment Share on other sites More sharing options...
GDMike Posted July 18, 2022 Author Share Posted July 18, 2022 (edited) A couple helpful items about SNP. Filename is, like 9 or less characters and so a save would look like: SAVE DSK4.SCHOOL No lowercase, and a load looks like, LOAD DSK3.SCHOOL Files should be kept in the same directory as SNP is in, I don't think it can save outside a root folder. F5 - command line calls. CALL CHAR (231) would place ASCII character at cursor position. CALL COLOR (F1) uses hex code for color scheme. Screen colors can be local to the page or global to every page. CALL GOTO (43) would load page 43 to the screen. Import from Windows clipboard, or classic 99. Ctrl M after you have data in the clipboard, follow instructions. Will overwrite to top of screen if there is too much data in clipboard. Edited July 18, 2022 by GDMike 1 Quote Link to comment Share on other sites More sharing options...
GDMike Posted July 23, 2022 Author Share Posted July 23, 2022 Supercart build update.. Year to date, I've built 17 supercarts, in which 5 are the 8K type and 12 we're the 32K type this year. I've got 2 each on hand. And 4 of any type I wish ready for build. But I'll need more boards from Jim soon. Quote Link to comment Share on other sites More sharing options...
GDMike Posted July 23, 2022 Author Share Posted July 23, 2022 (edited) For faster loading of SNP, ill be removing the SAMS INIT page counter that appears at boot and replacing with "Wait". This will improve performance at boot up. And I'll be hoping to add a couple more things to SNP soon. So far I've NOT made version 2.2 a supercart requirement. SNP will continue to load via editor assembler option 3 and ram requirement of SAMs with F18A. Edited July 23, 2022 by GDMike 2 Quote Link to comment Share on other sites More sharing options...
GDMike Posted July 26, 2022 Author Share Posted July 26, 2022 SNP looking to get a DV 80 add on soon. (Latest bandit photo). 2 Quote Link to comment Share on other sites More sharing options...
