Synthpopalooza Posted May 16, 2020 Share Posted May 16, 2020 A little known POKEY trick: Writing $10-$1F rapidly to one of the AUDCx registers will cause POKEY to replay 4-bit audio samples. Downside of this is it takes 100% CPU. Now here's the hard part ... I believe I can down sample to 4-bit audio using Audacity. How then would I include this data into 7800basic, i.e. read data and convert to 4-bit values to be written as follows: psound 0,0,1,x ... where x is $00 to $0F I know 5200 Berserk does this trick for the robot voices, though the game stops while doing so. Quote Link to comment Share on other sites More sharing options...
+Stephen Posted May 17, 2020 Share Posted May 17, 2020 Can't answer this directly, but there are now timer techniques used (see Space Harrier), that allow full digi playback without blanking the screen, nor stopping the action. Quote Link to comment Share on other sites More sharing options...
RevEng Posted May 17, 2020 Share Posted May 17, 2020 TIA has the exact same trick, with identical resolution. No need to require a pokey for playing samples. I haven't done this yet in my own code, but Bob has done it a few times. You'd need to use assembly code within 7800basic to update the register, to play the sample. 1 Quote Link to comment Share on other sites More sharing options...
Synthpopalooza Posted May 17, 2020 Author Share Posted May 17, 2020 I'll have to look at the code then. This ties into the Kung Fu Master thing in another thread a little ... but I wanted to experiment too. Quote Link to comment Share on other sites More sharing options...
