U.S.A. intellivision console in europe
So i got that super pro system which is possibly a "tutorvision" console.
The problem is that:
it has of course U.S. power supply cable
it has not tv cable.
I am concerned about the first one, what exactly i should do to get a power supply adaptor working in europe, without damaging the console?
i know that there are voltage issues, due to differences in the 2 continents.
About the tv cable, should a normal pal tv cable work?
Can you help me?
1 minute ago, Spadafermo51 said:
Hi Alex,
for the power supply you must use a 220 v to 125 v current transformer.
To connect to the TV you can use any console cable,
but you must have a TV that is multistandard and also has the NTSC system.
Can you send me an ebay / amazon link where to buy it?
  • 4 weeks later...
Hi Alex, did you found something by now?
I found this in a German retro store: https://www.polyplay.xyz/PALNTSC-Mini-TV-System-Konverter-weiss
It converts every TV signal in any direction. PAL to NTSC, SECAM to PAL and so on...
I ordered one and will test it on one of my Intellivision 2 (where I can easily can replace the power plug) without AV mod.
Mike, keep us informed on the results of your tests. I'm very interested in such device.
I already got this converter.
It is a partial success. I assumed it would convert the RF (antenna) signal. But instead it is for CVBS signals. So you need a modded Intellivision.
But it helps with older TVs that can't handle the NTSC CVBS signal like old Commodore monitors.
Without the converter, the picture is b/w, With it, it's in color.
IMG_7150.thumb.jpeg.b016c3d6975ee85688b57b8523a95f1e.jpegIMG_7154.thumb.jpeg.8ca246d2e85088251b249b854d11707f.jpeg
