enuffsaid Posted May 21, 2020 Share Posted May 21, 2020 Hello, I am looking for an Apple II graphics application that will allow me to copy part of a Hi-Res picture to another H-Res picture and then save. Thank you for your assistance. Quote Link to comment Share on other sites More sharing options...
The Usotsuki Posted May 22, 2020 Share Posted May 22, 2020 (edited) MousePaint? (ETA: not 100% sure if that lets you carry the clipboard across files) Edited May 22, 2020 by The Usotsuki Quote Link to comment Share on other sites More sharing options...
enuffsaid Posted May 23, 2020 Author Share Posted May 23, 2020 Thank you for the suggestion The Usotsuki. Sounds very promissing. I did give this a try, but for some reason when I try to load my images (eg. TITLE.PIC) it keeps saying "No such file". Need to dive in a bit more. Quote Link to comment Share on other sites More sharing options...
enuffsaid Posted May 23, 2020 Author Share Posted May 23, 2020 Hi The Usotsuki. Happy to report MousePaint worked like a charm. Copy/paste from one image to another worked perfect. Thank you for your suggestion. Quote Link to comment Share on other sites More sharing options...
Keatah Posted May 23, 2020 Share Posted May 23, 2020 I was able to cut and paste from one pic to the other like so: Seems the clipboard survives loading across to another image. The MousePaint disk I was using has ProDOS 1.1.1 on it. Try using "Get Picture" and "Put Copy In" as your load and save functions under the FILE dropdown in MousePaint. I made me a blank ProDOS (.po) disk image with CiderPress and used the default setting of "NEW.DISK" for the name. In AppleWin I put MousePaint in D1 and NEW.DISK in D2 In MousePaint I was able to click on "Get Picture.." Then typed /NEW.DISK/A3 to load the picture titled A3. The same to save it, except you use "Put Copy In..." from the FILE dropdown. If you need help with Ciderpress just ask. It's not hard. If you're still stuck I'll answer more later tonite. Quote Link to comment Share on other sites More sharing options...
enuffsaid Posted May 24, 2020 Author Share Posted May 24, 2020 Hi Ketah. I am familiar with Ciderpress. Making a .po disk isn't a bad idea, actually. Thank you for your suggestion. Quote Link to comment Share on other sites More sharing options...
