Need some help with getting rid of excess code
I'm working on the Polarium game and I need help, specifically with drawing the PF. So why did I post it here and not in the bB subforum? Because the part I need help with is in ASM. I decided that instead of the playfield data being this:
  %11111111, %11111111, %11111111, %11111111
  %00000000, %00000001, %00000000, %00000000
  %01111110, %00001001, %01000101, %01110100
  %01000010, %00001101, %01000101, %00010101
  %01110110, %00001001, %01000101, %00010110
  %01101110, %11001001, %01000101, %01110100
  %01000010, %00001001, %01000101, %00010100
  %01111110, %00011101, %01110101, %01110100
I could just shorten it to this:
  %11111111
  %00000000
  %01111110
  %01000010
  %01110110
  %01101110
  %01000010
  %01111110
  %00000000
  %11111111
  %11111111
Thus saving 32 bytes per level, since the other three columns are the same per level (spelling out "1-LINE"). The code that 'prints' the playfield data on the screen is thus:
  asm
  lda #$00
  sta temp2
  lda ballx
  asl
  adc ballx
  asl
  rol temp2
  asl
  rol temp2
  sec
  sbc ballx
  bcs *+4
  dec temp2
  asl
  rol temp2
  asl
  rol temp2
  adc #<PF_dat1
  sta temp1
  lda temp2
  adc #>PF_dat1
  sta temp2
end
load_new_level3
 asm
 ldy #43
load_loop
 lda (temp1),y
 sta var0,y
 dey
 bpl load_loop
end
ballx being the level number because I ran out of a-z variables. So what I want to do is change this code so it only prints the left-most column. I tried various things but nothing seems to be working. Help me please.
 something like this maybe? (I didn't include the tables)
 how many levels? this needs an extra byte per for the x 11 table
 and assumes col0 data is all in one page so 256/11 = 23 levels max
  ldx #$2B
loop_pf
  lda pf_dat,x    ; col0 will be over written but it's probably not worth trying to avoid
  sta var0,x
  dex
  bbl loop_pf
  ldx level        ;  ballx
  ldy x11,x        ;  level x 11 look up
  ldx #$00
  lda #>col0_dat
  sta temp2
  lda #<col0_dat
  sta temp1
loop_col0
  lda (temp1),y
  sta var0,x
  iny
  inx
  inx
  inx
  inx
  cpx #$2C
  bne loop_col0
edit: the ending value for x is 44 (not var44, duh ;) )
Edited by bogax
goofed the cpx, didn't store the lo byte of the pointer, typos in the reason for edit
 lda #>col0_dat
  sta temp2
  lda #<col0_dat
loop_col0
I haven't looked at the logic of that code, but the above is missing a "sta temp2+1" just before the loop.
And inside the loop it looks like it should be "lda (temp2),y" not "lda (temp1),y"
And finally, no idea what that "cpx #var43" is, but that's something else to check.
must be something else going on
the playfield color changed, the score is corrupted, the movement is messed up
edit
fixed some of that
score is still corrupted, but I suppose you're using custom characters
Edited by bogax
update
  lda #>col0_dat
  sta temp2
  lda #<col0_dat
  sta temp1
loop_col0
If you are using (zp),y addressing, it is common usage to declare the variable (zp) as two bytes and then store low byte to zp, and high byte to zp+1.
The above still looks wrong to me, using two variables, one for the high (temp2) and one for the low (temp1).  In (zp),y addressing, zp is a single variable which happens to be two bytes in size. It's not two variables, temp1 and temp2.
So, I would still say the above looks wrong. If you use "lda (temp1),y" inside the loop, then store to temp1 (low) and temp1+1 (high) in the setup outside the loop.
I got this working. Since I probably will plan to have more than just 23 levels, I will just repeat the code and have it look up different data (like I did in Castle of Doom). One thing I don't understand though is the x11 thing you did. I ended up putting in data numbers divisible by 11 (0, 11, 22, 33). Don't know what that's all about. Thank you, and this did save a bunch of room.
I was able to save even more room by modifying the code a tiny bit:
 asm
  ldx level        ;  ballx
  ldx #$8
  lda #>col0_dat
  sta temp2
  lda #<col0_dat
  sta temp1
loop_col0
  lda (temp1),y
  sta var0,x
  iny
  inx
  inx
  inx
  inx
  cpx #$20
  bne loop_col0
end
   return otherbank
 data x11
  0, 6, 12, 18
end
 data col0_dat
  %01111110
  %01000010
  %01110110
  %01101110
  %01000010
  %01111110
  %00100100
  %01100110
  %00111100
  %00100100
  %00011000
  %01100110
  %00111100
  %01011010
  %01111110
  %01011010
  %01100110
  %00111100
  %01000010
  %01111110
  %01001010
  %01111110
  %01010010
  %01111110
end
you could substitute your times 11 (44) code for the table
I think I figured break even was about 8 levels
incidentally I think you weren't initializing y in your original code
 here the [byte] column 0 playfield data is transposed so essentially there's a table
 for each row of the playfield and the data is selected by the level and you loop through the tables
 so now you can have 256 levels or whatever you can fit into the bank (which ever is less
 the times 11 and indexing is built into the pf_ptr_dat table and x is just a pointer
 it compiles but I didn't go beyond the first level
load_new_level3
  const number_of_levels = 3
  asm
  ldx #$2B
loop_pf
  sta var0,x
  dex
  bpl loop_pf
  lda #<col_dat
  sta temp1
  lda #>col_dat
  sta temp2
  lda #$00
  sta temp3
loop_col
  ;  get the playfield pointer
  ldy temp3
  ldx pf_ptr_dat,y
  ;  get the level pointer and move the column 0 data
  ldy ballx
  lda (temp1),y
  sta $00,x
  ;  increment the data pointer
  lda temp1
  clc
  adc #number_of_levels
  sta temp1
  bcc *+4
  inc temp2
  ; increment the playfield pointer pointer
  inc temp3
  cpx #var40
  bne loop_col
end
  return otherbank
  data pf_ptr_dat
  var0,  var4,  var8, var12, var16, var20, var24, var28, var32,  var36,  var40
end
 data pf_dat
  %00000000, %11111111, %11111111, %11111111
  %00000000, %00001001, %01000101, %01110100
  %00000000, %00001101, %01000101, %00010101
  %00000000, %00001001, %01000101, %00010110
  %00000000, %11001001, %01000101, %01110100
  %00000000, %00001001, %01000101, %00010100
  %00000000, %00011101, %01110101, %01110100
end
  data col_dat
  %00000000, %00000000, %00000000
  %01111110, %00100100, %00111100
  %01000010, %01100110, %01011010
  %01110110, %00111100, %01111110
  %01101110, %00100100, %01011010
  %01000010, %00011000, %01100110
  %01111110, %01100110, %00111100
end
Edited by bogax
clarification
 OK one more
 y is now the page and temp2 the level index
 that saves a couple of bytes and a couple cycles in the loop
 back to incrementing x
 branches into the loop to avoid an unneeded increment of the pointers
load_new_level3
  const number_of_levels = 4
  ;  initialize the playfield
  asm
  ldx #$2B
loop_pf
  sta var0,x
  dex
  bpl loop_pf
  ;  initialize pointers
  ldy #<col_dat
  lda level
  sta temp1
  lda #>col_dat
  sta temp2
  ldx #var8
  bne enter_col0_loop
loop_col
  tya
  clc
  tay
  bcc increment_playfield_pointer
  inc temp2
  inx
  inx
  inx
  inx
enter_col0_loop
  ;  move the column 0 data
  lda (temp1),y
  sta $00,x
  cpx #var28
  bne loop_col
end
  return otherbank
 data pf_dat
end
  data col_dat
  %01111110, %00100100, %00111100, %01000010
  %01000010, %01100110, %01011010, %01111110
  %01110110, %00111100, %01111110, %01001010
  %01101110, %00100100, %01011010, %01111110
  %01000010, %00011000, %01100110, %01010010
  %01111110, %01100110, %00111100, %01111110
end
Edited by bogax
fix the data, touch up the code, satisfy the critics
10 minutes ago, bogax said:
  bcc *+4
Dangerous, and unnecessary.
Use a label to branch to.  That way, if you insert code between the branch and the destination it will still work.
The above is just asking for trouble!
Edited by Andrew Davie
worse than that I think is it's harder to read and keep track of
Edited by bogax
