Atari 7800 only black, white and yellow in 7800 mode
Cmherndon79
Well foo, but kinda what I thought.
I connected the 7800 up to my CRT tube and it's got the same behavior there, so that variable is out now.
Anyone got a recommendation on a supplier for the Sony cxk5816pn-12l SRAM?  I see a few places out there have it, but never bought from them.  Sells on eBay too, but don't want to go that route.
Found this list from Console5:
Devices Include:
  • 5516
  • 6116
  • LC3517B
  • LH5116HN
  • LH5216AD
  • SRM2016
  • BR6216B
  • CXK5814P
  • MN4216
  • TMM2015BP-15
  • MSM2128-15RS
So now I hunt. :)
Edit:
Found 6116-120s  at Unicorn Electronics, looks like 150 would  probably be ok, but ordered 120 just to be safe as it was a 10 cent per part difference.  Found various other things I'll need eventually to fill out the minimum $ amount.
Edited by Cmherndon79
  • 4 weeks later...
I'm back.  Yeah, had just put this aside for a while.  I got the RAM in and swapped it out a few days ago, but the behavior didn't change.  I had noticed a cut trace I had not seen before and got excited for a second before realizing it ran from the location of the ram to ground, where the bodge resistor was.
I started looking are around R57 again.  Noticed that it gets power through CR3 and CR4 on the way to R52 (I think).  I decided to pull CR3 out this morning when I measured it, I swear I got nothing on either side, but then I went and checked it this afternoon and I got .5 in the correct direction and nothing in the other.  Is it possible that a diode can be intermittently bad?  A Google search, I see people say so, but I have never seen it before.  Might explain why the color goes in and out?
Anyway, I pulled a 1N914 diode off an old Commodore board and installed it and I haven't had a total loss of color since then.  I am still getting a bit of color shift, which is more noticeable in Centipede than Food Fight.  Occasionally the Centipede will shift from green to red and the Centipede logo will turn pink.  Possible I need to check CR4, I'm guessing.
  • 5 months later...
So...  I had an Atari 400 computer come across my bench a few weeks back.  I had a similar issue, where the screen would flip between black and white and color.  Cleaned out the variable resistor and it persisted.  I found a post on here from a few years ago, someone having the same issue and they swapped the crystal oscillator C010177 to correct the issue.  I pulled that part off a VCS board I had for parts and installed it in the 400 and it solved my issue of the color cycling in and out.
It occurred to me that I had not tried this on that 7800, so I looked at the crystal on the 7800 and it has a different Atari PN of C024912 and I found it for sale at Best Electronics for $5.  The frequency though was also printed on the crystal of 14.31818, so I instead ordered 10 new from Mouser Electronics for less than $5.  I swapped that out at 15:00 and it is now 19:11 and I haven't observed any color shifts.  Perhaps this was the problem.  I also found this, though I don't know how authoritative it is:
http://7800.8bitdev.org/index.php/Atari_7800_Color_Documentation
"Consistency Issues
There are a number of factors that result in inconsistency between the palettes of 7800 consoles:
  • Each 7800 console has a tunable resistor inside, which is used to modify the color signal frequency period. On any given console this resistor may be adjusted a number of different ways, with at least 2 published historic standards in play - one with hues ~25.7 degrees apart, and another with hues ~26.7 degrees apart.
  • As a 7800 console warms up, so do the components that produce the color signal frequency period, while the colorburst frequency remains constant, so the distance between the various hues in the palette stretch out. When cold, the console's hue values have ~24.7 degrees of separation, and as the console warms up, up to ~27.7 degrees of separation can be seen between the hues. The separation is cumulative, and so is more pronounced with higher hue values; the $Ex hue can shift from being green through yellow/brown, and $Fx can shift from an initial greenish-yellow/brown through to a reddish yellow/brown. The majority of this shifting will happen in the first 20 minutes of console operation, though some additional shifting can be seen hours later.
  • The NTSC and PAL standards don't consistently display the same colors from TV to TV, and almost all TVs allow the viewer to tune colors to their liking.
The largest factor in these consistency issues is typically the warm-up issue. Since the latter hues shift more than the earlier ones, a 7800 game designer should generally avoid the last 2 $Ex and $Fx hues for critical items that need faithful color. e.g. one may wish to avoid using $Ex for green grass, or $Fx for for gold coins.
The warm-up effect can be seen in commercial 7800 title Choplifter, where the ground utilizes a $E8 color value, and consequently shifts from green to yellow-brown."
Glad you finally solved the issue and glad it was a simple crystal issue.
I will point out for the tech/repair guy crowd that this kind of weird issue probably would have shown up quickly with an oscilloscope fast enough to measure the crystal frequency (e.g., something with at least 30Mhz - 50Mhz or higher, fast enough to catch at least a couple of data points on each pulse), at least if you had a working system to compare with.
