My 7800 Vertical Shooter - Heofonfīr
  • 2 months later...
Hey SlidellMan, I've got a menu sample working for you that you're free to use.  I looked at your code and decided to just start over from scratch and create a well commented example that uses your graphics and will hopefully be easy for you to incorporate into your existing game.  Since you already shared those graphics previously in this thread I'm including them in this post too just in case someone else wants to download this and try it out as well.
This sample uses your title screen, then loads a menu selection screen with four options (Skill, Lives, Level, and Start Game), and allows you to select from three different choices for each one. Up and down changes the menu entry and left/right changes the options for that menu entry.  Pressing fire on Start Game will jump to a main loop and display the options you chose from the menu screen.
Let me know if you have any questions about the code.  I'm happy to help.
menu_sample.bas menu_sample.bas.a78 graphics.zip
On 2/26/2023 at 8:15 PM, SlidellMan said:
@Atarius Maximus Thanks a whole lot. I just got started on implementing the needed changes.
All ROM/.bin files and the source code are in the .zip file.
Based on your PM I took a look at your code and I've got this all sorted out for you.  The main issue is you had a return without a gosub in your titlescreen loop, I added a goto command instead for that loop. Your code for selecting a menu item when moving up was also incorrect, I fixed that.  I'm attaching an updated version of your code and I put in comments everywhere I made a change.  Everything works. :)
Menu_Demo_Update.78b Menu_Demo_Update.78b.a78
Posted (edited)
I've applied the changes that you made, @Atarius Maximus. Thank you for helping point out what I overlooked.
heofonfir_boss_battlexex.xex heofonfir_bossbattle.rmt Menu Demo 3-1-2023.zip Menu_Demo_v1.78b.a78 Menu_Demo_v1.78b.bin Menu_Demo_v1.78b.list.txt Menu_Demo_v2.78b.a78 Menu_Demo_v2.78b.bin Menu_Demo_v2.78b.list.txt
Oh, I almost forgot, I made a boss battle theme.
Edited by SlidellMan
Forgot to mention the new song.
3 hours ago, SlidellMan said:
The menu still has an issue - the color doesn't change to indicate which menu item you're on, and you can't move back up the menu once you move down.  You'll need to add the menu_selection_color<x> variable to the plotchar statements, and re-do the menu down code.  I've got the changes needed below.
Change this:
    plotchars 'skill:' 0 28 5
    plotchars 'lives:' 0 28 6
    plotchars 'time trial:' 0 28 8
    plotchars 'players:' 0 28 9
    plotchars 'start game' 0 28 10
;    plotchars 'expert mode' 0 60 120
    ; (the debounce_down/menu_down section that's right here is fine, I removed that for this snippet)
    if debounce_up = 6 && menu_yposition = 8 then debounce_up = 0:menu_yposition = 9
    if debounce_up = 6 && menu_yposition = 7 then debounce_up = 0:menu_yposition = 8
    if debounce_up = 6 && menu_yposition = 6 then debounce_up = 0:menu_yposition = 7
    if debounce_up = 6 && menu_yposition = 5 then debounce_up = 0:menu_yposition = 6
    if debounce_up = 6 && menu_yposition = 5 then debounce_up = 0:menu_yposition = 5
To this:
    plotchars 'skill:' menu_selection_color1 28 5
    plotchars 'lives:' menu_selection_color2 28 6
    plotchars 'level:' menu_selection_color3 28 7
    plotchars 'time trial:' menu_selection_color4 28 8
    plotchars 'players:' menu_selection_color5 28 9
    plotchars 'start game' menu_selection_color6 28 10
    ; Again - don't change the debounce_down section that's in-between these two sections of code.  It works fine.
    if debounce_up = 6 && menu_yposition = 10 then debounce_up = 0:menu_yposition = 9
    if debounce_up = 6 && menu_yposition = 9 then debounce_up = 0:menu_yposition = 8
    if debounce_up = 6 && menu_yposition = 8 then debounce_up = 0:menu_yposition = 7
    if debounce_up = 6 && menu_yposition = 7 then debounce_up = 0:menu_yposition = 6
    if debounce_up = 6 && menu_yposition = 6 then debounce_up = 0:menu_yposition = 5
