Open Club  ·  64 members
DASM
Macro Magic
Thomas Jentzsch
For some years I have been using a macro which checks if code or data crosses a page boundary. It worked very well, but sometimes too well. Then it failed in an early assembler pass, where it would have succeeded in the final one.
Today Andrew came up with a brilliant idea: Define a label inside the macro in case of success only. And use that label later on. The assembler will return with an error if he cannot resolve the label in the final pass.
For convenience I added the success check into my macro too. Here is the updated macro:
_ERR SET 0
  MAC CHECKPAGE ; {address}
    LIST OFF              ; keep the list file clean
    IF (>(.-1)) != >{1}
      ECHO ""
      ECHO "ERROR: different pages! (", {1}, ",", .-1, ")"
      ECHO ""
;      ERR                ; previously this aborted the assembly
_ERR SET _ERR + 1         ; count number of errors (useful for extra output)
    ELSE
CHECKPAGE_{1}             ; define in case of success
    ENDIF
$CHECK SET CHECKPAGE_{1}  ; check success
    LIST ON
  ENDM
Usage:
Table
  .byte 1, 2, 3, 4,...
  CHECKPAGE Table
If Table crosses a page boundary the assembler will error:
CHECKPAGE_Table ????(r )
If I use the version that's in github master, it seems to work for me. (I uncommented your commented ERR statement) Here's my output if I use an ORG of $10ff...
/usr/local/bin/dasm scratch.asm -f3 -sscratch.symbol.txt -lscratch.listing.txt  -I. -I../includes -oscratch.bin
 ERROR: different pages! ( $10ff , $1102 )
scratch.asm (27): error: ERR pseudo-op encountered.
and my output if I use an ORG of $1000...
Complete.
That seems to be what you intended.
  • 1 month later...
What does $CHECK do?
I changed that line to:
	IFNCONST CHECKPAGE_{1}
	  ECHO "ERROR: page crossing (",{1},",",.-1,")"
	  ERR
	ENDIF
(and removed the ECHOs from the other IF block) which seems to work, but I’m not certain it solves the original problem with using ERR directly, and I’m also not certain it works with a developmental dasm. I’m using 2.20.13, which I believe is the latest release.
I found that (.-1) is useful when I’m confirming some block is on a single page, but when I’m confirming 2 different blocks are on the same page, I just want (.). So I split it into two separate macros. Here’s what I have now (I changed some names in my preference):
        mac samehighimpl ; {addr1,addr2}
        list localoff
        if >{1} == >{2}
SAMEHIGH_{1}_{2}_EXISTS ; defined if high bytes are equal
        endif
        ifnconst SAMEHIGH_{1}_{2}_EXISTS
          echo "ERROR: high byte difference (",{1},",",{2},")"
          err
        endif
        endm
        mac prevsamehighas ; {addr}
SAMEHIGHBASE set .-1 ; evaluate here so SAMEHIGH_{1}_{2}_EXISTS will work
        samehighimpl SAMEHIGHBASE,{1}
        endm
        mac nextsamehighas ; {addr}
SAMEHIGHBASE set . ; evaluate here so SAMEHIGH_{1}_{2}_EXISTS will work
        endm
Edited by bizarrostormy
Now, how to get it to work for local labels?
EDIT: also, the label doesn’t substitute how I want it to. I want it to contain the addresses. Instead {1} expands to SAMEHIGHBASE, and {2} expands to the label (not the address) of the original argument. The implication is it does not support multiple calls for the same label. In some sense, that’s not necessary: of all the addresses that are supposed to be on the same page, the only ones that really matter are the first and the last. But this macro exists to ensure that future revisions don’t break old assumptions, so I would prefer to be able to put the macro everywhere in case one of those future revisions moves things.
On 7/22/2020 at 1:51 AM, Thomas Jentzsch said:
Not sure why, but as of now, macros do not accept local labels.
I didn’t realize this at the time, but macros apparently have their own namespace, as implied by this line from the documentation:
Quote
You should always use LOCAL labels (.name) inside macros which you use more than once.
which also implies the rationale.
The fact that macro calls do not implicitly evaluate their arguments is a major limitation. Tcl technically does the same thing but provides several ways to substitute.
Just following that suggestion improves the code:
        mac samehigh8impl ; {addr1,addr2}
        list localoff
        if >{1} == >{2}
.SAMEHIGH8_EXISTS ; defined if high bytes are equal
        endif
        ifnconst .SAMEHIGH8_EXISTS
          err
        endif
        endm
        mac prevsamehigh8as ; {addr}
SAMEHIGH8BASE set .-1 ; prevent error in samehigh8impl
        samehigh8impl SAMEHIGH8BASE,{1}
        endm
        mac nextsamehigh8as ; {addr}
SAMEHIGH8BASE set . ; prevent error in samehigh8impl
        endm
Still doesn’t work for local labels but does now allow multiple calls with the same label.
EDIT: one reason I changed the name from “checkpage” to “samehigh” is because I also have places that need two addresses to have the same low byte. With “samehigh” it is very clear what to call the low-byte equivalent.
  • 3 weeks later...
It’s best to bracket all parameter references used as subexpressions, in case someone passes an argument containing a low-precedence operator:
EDIT: I posted code that doesn’t work. Will try again later.
EDIT: the gist was to enclose {1} and {2} in brackets, like:
        if >[{1}] == >[{2}]
But that doesn’t work: dasm rejects >[.] and >[.-1], both directly and when passed as a macro argument and then accessed via symbol.
EDIT: This seems to work, even when passing . or .-1:
        list localoff
        if >{1} == >{2} ; dasm currently rejects [.] in some cases
        endif
          err
        endif
        endm
        samehigh8impl SAMEHIGH8BASE,[{1}]
        endm
        endm
  • 1 month later...
I often want to check the top nybble, and there might be uses (bankswitching?) to check other ranges.
This version can check any number of bits on either the high side or the low side.
This also uses no global symbols. The trick to getting rid of them was to assign a local label from the parameter in the leaf macro.
        mac samebits ; {numbits, addr1, addr2, mask, side}
        list localoff
.numbits = {1}
.addr1 = {2}
.addr2 = {3}
.mask = {4}
.side = {5} ; current dasm doesn't have setstr
.addr1masked = .addr1 & .mask
.addr2masked = .addr2 & .mask
        if .addr1masked == .addr2masked
.SAMEBITS_EXISTS ; defined if non-masked bits are equal
        endif
        ifnconst .SAMEBITS_EXISTS
          echo "ERROR: ", .side, " ", .numbits, "bits difference (", .addr1, ",", .addr2, ")"
          err
        endif
        endm
        mac samelow ; {numbits, addr1, addr2}
        samebits {1}, {2}, {3}, [1<<[{1}]]-1 & $FFFF, "low"
        endm
        mac samehigh ; {numbits, addr1, addr2}
        samebits {1}, {2}, {3}, ~[[1<<[16-[{1}]]]-1] & $FFFF, "high"
        endm
        mac prevsamelowas ; {numbits, addr}
        samelow [{1}], .-1, [{2}]
        endm
        mac nextsamelowas ; {numbits, addr}
        samelow [{1}], ., [{2}]
        endm
        mac prevsamehighas ; {numbits, addr}
        samehigh [{1}], .-1, [{2}]
        endm
        mac nextsamehighas ; {numbits, addr}
        samehigh [{1}], ., [{2}]
        endm
        mac prevsamehigh8as ; {addr} ; deprecated: use prevsamehighas instead
        prevsamehighas 8, [{1}]
        endm
        mac nextsamehigh8as ; {addr} ; deprecated: use nextsamehighas instead
        nextsamehighas 8, [{1}]
        endm
6 hours ago, Thomas Jentzsch said:
Very nice.
But AFAIK the latest DASM supports 'setstr'.
Ah. I was not aware of the 2.20.14 release. 2.20.13 does not support 'setstr'. TBH I’m not clear on the difference between 'set' and 'setstr'. The = seems to work fine in this case.
SETSTR makes a string literally from a symbol name. SET evaluates the value of the stuff on the right side of the SET command, and assigns that value to the symbol. Using = is the same as SET, except it's a constant symbol assignment, where you can repeatedly use SET to assign different values to the same symbol. (This is particularly useful when you want to generate look-up-table data instead of using constants, but by no means the only use for SET)
This code...
   processor 6502
   org $1000
 MAC testset
myset1 = {1}
myset2 SET {1}
mysetstr SETSTR {1}
 echo "myset1 is",myset1
 echo "myset2 is",myset2
 echo "mysetstr is",mysetstr
 ENDM
mylabel
 testset mylabel
...will result in this output during the assembly...
DASM 2.20.14-SNAPSHOT
 myset1 is $1000
 myset2 is $1000
 mysetstr is mylabel
Complete. (0)
This is the main use case for SETSTR - so you can have a macro report which symbol it was called with.
