ColecoRGB Help
On 6/22/2020 at 11:27 PM, ChildOfCv said:
WTF.  So there's a numbering standard called EIA-96 that has the "benefit" of requiring you to look up the conversion value.  <slow clap>
I'd been wondering why the 75Ω output resistors I've been using were labeled "85X".  How "helpful" of them. ?
4 hours ago, Retro_Game_Lover96 said:
Here is my RGB board like this, so how do I bypass R1 with a jumper wire?
Find a short length of wire, strip both ends.  Place one end on one side of R1.  Place the other end on the other side of R1.
Alternatively, you could use your meter probes by sticking them on both sides of R1 and then angling both probes so that they contact each other.  Alternatively, set the meter in amps mode, make sure the probes are plugged into the appropriate outlets for reading amps (some meters use an alternate outlet), and then put a probe on each side of R1.
I tried, but it didn’t work. :(
Well, have you seen some other work that people did?
https://circuit-board.de/forum/index.php/Thread/17431-Colecovision-Ti99-RGB-MOD-Projekt/
https://imgur.com/dGSlk4p
https://imgur.com/a/2G7K2
I think the trimmer pot for the sync that has 103 code, so that should be 10k ohms.
Edited by Retro_Game_Lover96
  • 1 month later...
