DEFINE usage
artrag
I need a suggestion: I would like to replace this code
		' animate explosion here
		if (mytimer) then mytimer = mytimer - 1
		n = mx and 6
		if n=0 then
			DEFINE 0,6,varptr myshipexp_3x2_00_bitmaps(6*4*(3 - (mytimer/16)))
		elseif n=2 then
			DEFINE 0,6,varptr myshipexp_3x2_02_bitmaps(6*4*(3 - (mytimer/16)))
		elseif n=4 then
			DEFINE 0,6,varptr myshipexp_3x2_04_bitmaps(6*4*(3 - (mytimer/16)))
		elseif n=6 then
			DEFINE 0,6,varptr myshipexp_3x2_06_bitmaps(6*4*(3 - (mytimer/16)))
		end if
		wait
by something more compact using an auxiliary table using a pointer to pointer... How should it work in in intybasic ?
Using n as above I was expecting something like this
DEFINE 0,6, varprt (varprt myshipexp_3x2(n/2)) (6*4*(3 - (mytimer/16)))
Where myshipexp_3x2 is an array of addresses:
myshipexp_3x2:
    DATA    varptr myshipexp_3x2_00_bitmaps(0)
    DATA    varptr myshipexp_3x2_02_bitmaps(0)
    DATA    varptr myshipexp_3x2_04_bitmaps(0)
    DATA    varptr myshipexp_3x2_06_bitmaps(0)
But it fails....
Did I something wrong or is it impossible in Intybasic ?
Edited by artrag
I don't know all the wild and wooly ways of IntyBASIC, but my first guess would be:
		if n=0 then
			DEFINE 0,6,myshipexp_3x2(0) + (6*4*(3 - (mytimer/16)))
		elseif n=2 then
			DEFINE 0,6,myshipexp_3x2(1) + (6*4*(3 - (mytimer/16)))
		elseif n=4 then
			DEFINE 0,6,myshipexp_3x2(2) + (6*4*(3 - (mytimer/16)))
		elseif n=6 then
			DEFINE 0,6,myshipexp_3x2(3) + (6*4*(3 - (mytimer/16)))
		end if
myshipexp_3x2:
Seems like you only need one level of VARPTR.
I'm assuming, of course VARPTR array(x) is equivalent to x + VARPTR array(0).
If the code above is correct, you can shrink it further:
		if (n AND 2)=0 then
			DEFINE 0,6,myshipexp_3x2(n/2) + (6*4*(3 - (mytimer/16)))
		end if
