Fractari - Mandelbrot set generator for 8bit Atari
R0ger
11 minutes ago, Synthpopalooza said:
Oh one other thought ... if you do ANTIC 4 bitmap, map your colors like so, from brightest to darkest:
PF3 - PF0  - PF1 - PF2 - BAK
or
PF2 - PF1 - PF0 - PF3 - BAK
This avoids PF2-PF3 inverse conflicts.
Well you can still have inverted and non-inverted pixels in one byte. Question is how often that will happen.
Anyway, I was thinking about it and clearly you must know some way how to force character map read in middle of the line. I'm not aware it's possible.
47 minutes ago, MrFish said:
I came up with these in GTIA 9.
1231998194_Mandel1.thumb.png.e79e6a746fe2e44549a5fc592c483b76.png    1018142989_Mandel2.thumb.png.7f9b9495a4cf66d3a3119a3f8613c067.png
I really would like to see this (as well as all Fractari samples posted so far) done on the C64.... as well as the computing times... ??
Edited by Faicuai
  • Haha 2
I think you would be stuck with every 8 lines being of the same attribute unless you mess with VSCROL to do Konop's mode.  That wastes a lot of memory tho but reduces your characters to 5 or 6 pixels high.
You write characters 0-127 sequentially to the screen then inverse each character in the map as needed should you need to use PF3.  DLI character set change on each zone.  Writing to the character set memory in each zone activates the pixels.
Edited by Synthpopalooza
This may be of help to you ...
In this post, I made a C64 koala converter in Turbo Basic, which displays in the PCIN Antic 4 plus GTIA 10 mode.  It uses the DLI character set method I mentioned.  You inverse the appropriate character in the map whenever you need to use PF3 based colors.  This method was intuitive in this example because C64's graphics are also laid out in the same manner as this method.
Well, attributes 1 character high are too restrictive for fractals. If we could force charmap refresh every 2 lines, that could be worth pursuing, but whole character ? Nah.
  • 9 months later...
  • 2 months later...
@Heaven/TQA I guess I can share the math routines.
First let's look at math2.asm:
mul_UBBW - macro for multiplication Unsigned Byte * Byte to result Word. Uses tables square1 and square2, which contain (X^2)/4 and -(X^2)/4
sqr2 - macro which does square of word (2 bytes). The trick used here is used in all more complex versions.
Square is multiplication of 2 same words .. each consisting of bytes A and B. If we multiply each byte with each byte, we get partial products, which we have to sum together.
For these products I use convection AB = A*B .. which is kinda confusing, as the original number are also AB (A followed by B) .. just keep in mind that AB in first row is something different then AB later (yeah, one of the reasons I don't like sharing source codes :-D).
  AB
  AB
  BB
 AB
 AB
AA
AA is A squared, BB is B squared, which can be computed faster than multiplication using simple square table, named square. But that's not the trick. The trick is this.
Normally when multiplying, I would sum all these partial products together. But AA and BB don't overlap .. there can be no carry between them. So I can rearrange this sum like this:
AABB
 AB
 AB
Doesn't seem like much now .. but it helps a lot in more complex variants. Also note the routine inverts the negative numbers right at the beginning.
Ok, now for math3.asm. It works with 3 byte numbers, which I call triples. First there are some macros mta (move triple), mtai (move triple immediate), adt (add triple) and sbt (sub triple). Basic stuff.
Then there is the multiplication. 3 bytes squared into 6 bytes result. Here the sums and their simplification goes like this:
   ABC
   ABC
    CC
   BC
  AC
   BC
  BB
 AB
  AC
 AB
AA
AABBCC
 ABBC  ;stored in tmp1
 ABBC
  AC   ;stored in mr (result)
  AC
AA, BB and CC are again simple square of original bytes. To continue the confusing names, ABBC is actually A*B followed by B*C. I hope you get the idea.
You can see that 'the trick' saved lot of sums and byte manipulations, and the resulting code is quite short.
math4.asm then does basically the same for 4 bytes * 4 bytes with 8 bytes result. The sums go like this:
    ABCD
    ABCD
      DD
     CD
    BD
   AD
     CD
    CC
   BC
  AC
    BD
   BC
  BB
 AB
   AD
  AC
 AB
AA
AABBCCDD
 ABBCCD	;tmp1
 ABBCCD
  ACBD  ;tmp2
  ACBD
   AD   ;mr
   AD
And that's all. You can see that square written like this is much faster than multiplication of the same sized numbers. With multiplication all the individual partial products would be different, and I wouldn't be able to simply stack them like this.
And Mandelbrot formula can be modified so it only uses squares, and no multiplication. So it comes really handy here, and my implementation doesn't use any multiplication, besides the mul_UBBW macro.
square.zip
Edited by R0ger
  • Like 4
