Another jaguar bug?
1 hour ago, LinkoVitch said:
IIRC with pointer maths (it's been a while :) ) but whilst a pointer is itself 32bit, an increment with ++ will increment the pointer by it's type size (assuming it's a typed pointer).  So a Uint16_t* will increase by 2 bytes irrespective of if the pointer itself is 32 or 64bit.
I *think* that's correct :D
That's correct *but* when it's assigned the initial value in this code:
volatile uint16_t *clut = (uint16_t *)CLUT + index;
it's an addition of a 16 bit (index) to 32 (CLUT)
Edited by Welshworrier
I don't think that should matter?  It is adding a 16bit to a 32bit value, but the point of the addition CLUT is a value (I am assuming it is a #define for the CLUT memory address?) the result of the addition of a 32bit and 16bit values is then cast to a uint16_t pointer, so the addition is made prior to it becoming a pointer.
Well, that's how I read it :)
CLUT it's taken from jaguar.h, it's defined like this, by the way I think that it should be a short * or int16_t*
#define BASE 0xF00000 /* TOM Internal Register Base */
#define CLUT  (long *)(BASE+0x400) /* Color Lookup Table */
Anyway, it doesn't matter if the addition it's with a 16bit integer or a 32bits integer because there are no overflow. The palette is written by the 68000.
The values that I shown before was the ones that I wrote to the CLUT, the source palette or *color values if you like, I didn't read the CLUT. Later I can try to compare each write with the source value and log if there are a different value.
I've just checked the 3 versions I have of the Jag Tech Ref.  ONLY the printed copy I have that came with my Alpine has that line in! The PDF scan and the V8 ref don't have it!!  (My printed copy is dated June 7, 1995).  Is there a PDF (preferably OCR'd version of this out there, or should I look to fire up the scanner?  I'd rather not as I have had it spiral bound and that might be a right pain to reset)
A Version 2.4 (June 7, 1995) exists in a scanned form and break into small PDF files.
I remember the filename is "jaguar_dev_manual.zip" but I do not remember where I find it.
  • 2 months later...
That is correct , both address1 and 2 will point to the same entry / memory location
uint16 array[256];
uint16 *address1 = &array[index];
uint16 *first = &array[0];
uint16 *address2 = first + index;
