Knight Guy in Low Res World: Castle Days
vhzc
3 hours ago, Trebor said:
Perhaps "SELECT" (Or "RESET") can be used to return the player back to the Title screen.
+1. This would be useful.
It seems our final boss battle has been tweaked some making it slightly more difficult to beat, unless I am recollecting incorrectly.
It does feel a bit more difficult to defeat, requires a bit more patience.
Reset to tittlescreen is a good suggestion, I will add it.
No changes were made to dragon boss.
I've found...a pretty nasty bug. I can't recall the rooms right now I didn't test if this happens before the pet is saved, but it did happen after the pet was saved. I saved my pet and just happen to jump into the next room from room 92 into room 91. Well, when I did that jump into the next screen, I ended up dying on the spikes a little left of where you normally enter..and then I kept dying over and over. Basically the game was respawning me on the spikes over and over until my lives were gone. I believe this is identical to an earlier issue in a different room in one of the earlier builds?
Oh..and this was on actual hardware through my Mateos.
Then guess I was a little more tired or/and a little less patient this time around.
Regardless, great final boss for a great game.
Nasty indeed...Thanks for sharing they very descriptive explanation and pinpointing it.  I'll see if I may be able to trigger it as well next go around if something isn't discovered (or/and fixed) sooner respecting it.
I also found what I consider to be a pretty unfair death if you happen to die in room 49 I think it is with the eel towards the beginning of the water section. If you happen to die on that screen when coming from the right hand side, you end up respawning on the lower right in the Eel's lair section and unless you happen to respawn at the right time, you will get killed by that eel coming towards you in that area with no time to react or escape.
Also about the deaths in room 91 if you happen to jump into it from room 92 before it. To clarify, if you jump into room 91 from 92 (Where the knight guardian was previously), you end dying or at least it shows you dying in the spikes in the lower right of the screen and just a little left of where you should have come in entering from. And then you constantly respawn on those spike until all lives are lost.
Found another game breaking bug this time but as it has to do with your secrets I will send that to you in a PM.
Thanks as always for testing.
I posted a rev that corrects two of the reported bugs.
I wasn't able to reproduce the third one on emulator, but I made some changes  that, I hope, correct it.
On 7/4/2020 at 1:17 AM, vhzc said:
RC1-1 UPDATE
Corrects misplaced respawn in room 49 and bug in room 91
Reset key redirects to title screen.
I will give it a few tries when I get home from work and can load it up on my Mateos for testing. I did record all of my playing last night but on the third issue, it is hard to know exactly what I did on the timing to cause it but even if not possible on emulation, it was something I was able to do on actual hardware.
12 hours ago, knievel1 said:
I do not have the diving helmet!
I've got a key. Is it in that chest?
All the keys are used to open locked doors. You found a key for a door that you must backtrack through in order to get back too.
  • 1 month later...
  • 1 month later...
I just got my Concerto Cart a couple days ago and *finally* got a chance to try this - although I haven't gotten very far and haven't put much time into it yet, I have to say that I *love* it! The art style, the puzzles and level design ... it's all just great. Thanks for sharing your work and I agree, this deserves a cart release.
  • Like 4
  • 2 weeks later...
  • 5 weeks later...
  • 8 months later...
