Problems accessing files on the LynxGD
Nop90
12 minutes ago, thefred said:
Looks it froze after the mission, I get a shadow of a person and it doesn't get past that point. Is that where it saves? Music continues. Buttons don't seem to do anything.
I turned it off and back on and it started from the beginning. That is with the new gd. Ill try on the elchepo and see if I get the same results.
It works on bennvenn.
Couldnt figure out how to beat second mission.
Could you please try this version.
onduty.lnx
1 hour ago, karri said:
Yep. I only have the old SD cart and it required IODAT to be 0 for it to work.
Maybe it works with IODAT = 0xa too. Can you try please?
I would like to maintain the compatibility with the old SD cart that needs a sav file on the filesystem, but make the new LynxGD to switch to EEPROM emulation if the sav file is not present.
On 9/20/2020 at 2:44 PM, Nop90 said:
@SainT in a future update of the firmare could it be possible to have the additional feature to enable both SD access and eeprom access setting the eeprom byte in the rom header to 65 (64 + 1 for the most common eeprom used)?
Just looking at the code -- it may be possible. I'll look into it further. :)
  • Thanks 2
