zenasprime Posted July 26, 2020 Share Posted July 26, 2020 I picked up this VGA converter cable for my 1040 ST several years ago but only just now have been pulling the machine out of storage to get it set up. When I plug the cable into the ST and a VGA monitor, I get no picture at all. What am I missing in this set up that could be causing it to not work? Quote Link to comment Share on other sites More sharing options...
emerson Posted July 26, 2020 Share Posted July 26, 2020 Sounds like your vga monitor doesn't support 15khz sync signal. What is the model number of your monitor? Quote Link to comment Share on other sites More sharing options...
zenasprime Posted July 26, 2020 Author Share Posted July 26, 2020 I am trying to use this Wise Wing Monitor: https://www.newegg.com/wise-wing-w902db-19-sxga/p/N82E16824104001# I also have this ST to Composite cable which I tried to use with this SylvaniaTV but also got no signal. I was eventually able to get this Trash Picked Dell monitor to work in High resolution. So I'm guessing that these cables will only work with monitors that support a 15khz sync signal? Is there a list of compatible monitors somewhere that I can consult? Quote Link to comment Share on other sites More sharing options...
emerson Posted July 26, 2020 Share Posted July 26, 2020 Here is a list of 15khz monitors. Could you share the model number of the Dell monitor that works? http://15khz.wikidot.com/ Yes, the vga adapter requires a 15khz monitor or a scaler to adapt to a non-15khz display. I don't know much anything about the 1040st, but if I remember correctly the commodore 128 can only run the high-resolution mode from the rgb output. That might explain why you had issues with the composite video cable but again I don't know. Quote Link to comment Share on other sites More sharing options...
zenasprime Posted July 26, 2020 Author Share Posted July 26, 2020 (edited) This is the Dell Monitor: https://www.cnet.com/products/dell-e151fpb-lcd-monitor-15/ The output on this 1040ST can go to both my High Resolution Monotone SM124 and Low/Med Resolution Color SC1024. I don't have any other monitor to test the composite cable so I can't rule out that it's just a bad cable. That said, my Atari 800 XL works just fine with this TV and it's own composite converter cable. Edited July 26, 2020 by zenasprime Quote Link to comment Share on other sites More sharing options...
+LarryL Posted July 27, 2020 Share Posted July 27, 2020 AFAIK composite only works if the ST has a Modulator, so should be a STM or STFM Quote Link to comment Share on other sites More sharing options...
