PC IDE for Atari ST programming
I don't know about some IDE special for Atari 16 bit (ST serial). Some people using assemblers, compilers on PC for sure.
I stick to good old Devpac 3, what is a bit IDE - you have main GUI program where can edit source, set diverse things, run MON (disassembler/debugger), and more.
Steem Debugger is for sure best emulator for trying, debugging your code/program. You have complete overview, can set breakpoints, memory access breakpoints ...
And emulator helps to perform assembling/compiling faster. With modern PC it can be 30-50x faster than on real Atari (when set emul. to max speed mode). With Steem, with later Hatari releases speed gain is not so good.
  • 1 month later...
