Intellidiscs: Weekly development log
Ryan Witmer
9 hours ago, Cafeman said:
Are you (or anyone else) working on Tron style music clips?
I'm not, but I don't know what anyone else is doing.  I usually start working on sound toward the end of a project.
Also, curious, what graphics mode?
The score line on top is mode 7.  The rest of the screen is mode 4.  This is the first time I've messed with character-based graphics and I really wish I'd tried it sooner.
12 hours ago, fdr4prez said:
Oddly enough, in the INTV release of Dig Dug there is a hidden easter egg of a complete game: Deadly Dogs
I've heard about this several times, but this is the first time I've actually seen it.  Not sure I have anything that cool up my sleeve, though.
8 hours ago, phuzaxeman said:
Ryan, are the dual stick controls still being planned?  Would be really cool to incorporate that.
Yes, that's still going to be done.  I probably won't do it until I have some kind of title screen put together because I need some kind of simple menu for selecting the control mode.  The code so far was written in a way that should allow me to easily plug that in when the time is right.
As an Intellivision collector and player and a Tron Deadly Discs game lover,this project definitely caught my interest!
I do have a working Atari 5200 with the dual controller holder that was made for Space Dungeon.
I imagine that would work great for your game.
Thanks for working on this,very cool!?
I still have my dual controller holder as well, I look forward to playing the finished product and reviewing it on The Atari Report, it's gonna be right up there with Space Dungeon and Robotron as far as leading the way for R & D for more dual-stick games for Big Sexy!!!
In that case, maybe @edladdin should work on perhaps a Super Twin 52 as well to go along with the Super Twin 78 he already has.
This is something I talked about when the 5200 Podcast guys had me on.  I really want to make use of the things that make the 5200 special, like the trakball and the four controller ports.  Ratcatcher has a three-player mode, Curling uses all four ports in some modes and uses the analog features of the joystick.  Magical Fairy Force uses trakball control, and now I'm going for that awesome joystick coupler.
I think I just got the disc blocking working a couple minutes ago.  Now I need to do everything that comes after it.  That would be the disc-shattering animation and the enemy's new disc eventually showing up.  Sounds like something to do after lunch.
A fine day's work.  Disc blocking is now, as far as I can tell, completely implemented.
I have the following working:
The enemy disc shatters on impact with your shield.
Points are awarded as appropriate.
A new disc eventually reappears for the enemy that lost their disc.
Due to the resolution limitation of the 5200 missile sprites, my disc shatter animation isn't as cool as the Intellivision's.  There really isn't anything I can do about this.
Tomorrow I'm planning on cleaning up a few bugs, in particular I need to deal with positioning the disc correctly when the player crouches.  After a little cleanup I'll probably make a new video.  For now, I'm going to play with my cat.
very good work.
At the 4:23 timestamp (roughly), there is an enemy behind the player and his thrown disc goes thru the player and breaks on the blocking disc.
I know that this is due to the fact that your hit detection against the player isn't activated, yet, but I just wanted to point it out to you so you confirm that the player will be hit in this scenario without the enemy disc being broke.
22 minutes ago, phuzaxeman said:
That's a good question. Someone would have to show me. I don't have any experience.
The sound chip deals mostly in frequencies.  I found this really cool website: https://www.liutaiomottola.com/formulae/freqtab.htm
I used this to translate O Canada one note at a time from the sheet music for my curling game.
22 minutes ago, Cafeman said:
The only way I know is tedious.  I was just playing that tune on guitar today,  there are tabs for it on the Ultimate Guitar Tabs App.   It is either in Db  or Ab  in the sheet music.  What key did you record yours in?
I transposed it to C and 4/4 meter instead of 7/8.
9 minutes ago, Cafeman said:
This thread is what you need to map the notes to POKEY values.  But you still need a sound routine for loading notes, duration, and decay if you use it.
This is like programming stuff and way over my head lol. Best way I could do music if I created midi files and found a way to translate it to the pokey chip. I don't know if that's possible.
So you translated notes to frequencies.  How were you able to do the rhythms so the atari can tell a half note from a quarter?
Edited by phuzaxeman
Actually, this is what I was wondering when I asked you how you'd translate it to POKEY.  I don't know if there is a MIDI utility to translate it to pokey chips.  There are A8 sound packages that you can devote a chunk or ROM for in your program, and use the util to compose a tune with various FX, but I've never used those either.
I have my own sound engine that keeps getting fancier from game to game.  The POKEY maestros would probably point and laugh at it.
Anyway ... the sound routine I use is here ... in this example it has Galaga sound fx ... but pressing START cycles the sounds ...
So an explanation:
TUNExx is the frequency data for tune #xx
DURNxx is the duration data
There are channel indexes to determine which POKEY channel each tune gets played on
Hope this is of use
galaga-intro.asm galaga-intro.s galaga-intro.xex galaga-soundfx.asm galaga-soundfx.s galaga-soundfx.xex
