Ball help
atari2600land
I'm making a game where a bird drops the ball on top of a wall. I got the ball in after a few hours BUT the ball still goes and draws itself even after it lands on the wall, making it look like this:
It does this no matter whether I try to set ENABL to 0 or not. Not only that, the ball height is only supposed to be 4 pixels tall and not stretched like that. Why is it doing this? What am I doing wrong? (Keep in mind that if you decide to help and download the asm file, it is actually under 1,000 lines. The rest is data.)
bert12a.asm
The problem is with setting of VDELBL. The branch to skip setting VDELBL is never taken since you do a clc earlier. I'm not sure what you were going for there, but commenting out the "stx VDELBL" line allows the ball to appear the expected height.
Draw_Ball:
    ; prime ENABL so ball can appear on topmost scanline of Arena
    ; prep ball's Y position for 2LK
        lda PlayerY+4       ; get the balls's Y position
        clc
       ; adc #1              ; add 1 to compensate for priming of ball
       ; lsr                 ; divide by 2 for the 2LK position
        sta Temp            ; save for position calculations
        bcs NoDelayBL        ; if carry is set we don't need Vertical Delay
        ldx #1              ; preload X for setting VDELPx
        stx VDELBL          ; carry was clear, so set Vertical Delay
I want the ball to land on the wall, though. So I commented out that part and set the value to stop it at 4 instead of 5 and I get this:
        lda PlayerY+4
        cmp #4
        beq MMMM
        lda PlayerY+4
        sbc #1                ;     make Ball fall.
        sta PlayerY+4
        lda PlayerY+4
        cmp #4
        bne MMMM
