RevEng Posted August 18, 2020 Share Posted August 18, 2020 Between the RIOT investigations and refining the 7800basic rotational controls once again, I've been in a very technical headspace lately. As a... uh... break... I decided to work on a little plasma demo yesterday. For now it's just single color 320A mode, though it does use one of the composite artifacting colors. The plasma code is just a simple collision between 2 vertical sine waves, and 2 horizontal sine waves, so it's pretty basic and periodic. I'm going to look at adding another component to perturb the regularity, and possibly a higher color mode change, when I get back to... uh... slacking. Anyway, enjoy if you will... Plasma Demo, via the excellent online JS7800 emulator plasmatest.bas.a78 plasmatest.bas.bin ...all glory to the hypnotoad! 11 Quote Link to comment Share on other sites More sharing options...
+Trebor Posted August 18, 2020 Share Posted August 18, 2020 That is so cool! Excellent work! 1 Quote Link to comment Share on other sites More sharing options...
+Karl G Posted August 18, 2020 Share Posted August 18, 2020 That looks great! Very mesmerizing. 48 minutes ago, RevEng said: The plasma code is just a simple collision between 2 vertical sine waves, and 2 horizontal sine waves I suspect that your definition of "simple" may differ from the average person's. 2 Quote Link to comment Share on other sites More sharing options...
RevEng Posted August 18, 2020 Author Share Posted August 18, 2020 Thanks guys! Heh, I meant simple for a plasma demo. Karl, I literally can't look at your gif without hearing that low hypnotoad drone in my head. ? 2 Quote Link to comment Share on other sites More sharing options...
TailChao Posted August 19, 2020 Share Posted August 19, 2020 16 hours ago, RevEng said: Karl, I literally can't look at your gif without hearing that low hypnotoad drone in my head. ? So this'll be added next toad break, right? Right? 1 Quote Link to comment Share on other sites More sharing options...
+DrVenkman Posted August 19, 2020 Share Posted August 19, 2020 17 hours ago, RevEng said: For now it's just single color 320A mode, though it does use one of the composite artifacting colors. The plasma code is just a simple collision between 2 vertical sine waves, and 2 horizontal sine waves, so it's pretty basic and periodic. I'm going to look at adding another component to perturb the regularity, and possibly a higher color mode change, when I get back to... uh... slacking. Who needs one of those groovy Atari Video Music machines?!? Just convince whomever gets a viable 7800 SD cart out first to add a 3.5mm audio Line In connector tied to cartridge audio in and we'll be rockin' it 70's style! 3 Quote Link to comment Share on other sites More sharing options...
+-^CrossBow^- Posted August 19, 2020 Share Posted August 19, 2020 3 minutes ago, DrVenkman said: Who needs one of those groovy Atari Video Music machines?!? Just convince whomever gets a viable 7800 SD cart out first to add a 3.5mm audio Line In connector tied to cartridge audio in and we'll be rockin' it 70's style! Not a bad idea! Wonder if something like that can be done so that the amplitude from an audio line in populates variables with random values into the code to generate patterns on the screen in some way? Quote Link to comment Share on other sites More sharing options...
RevEng Posted August 19, 2020 Author Share Posted August 19, 2020 Honestly, I'd be down for it. One of my long-benched assembly projects was an Atari Video Music pattern generator for the 2600, with the intent that the 7800 would follow - lots of neat effects could be had on the 7800. My original thought was that the hardware could be a couple simple filters+amps going to the joystick ports for low and high frequency input. While the cart audio line could be used (not for 2600 though) I think the interfacing is a bit more complicated that way. Maybe someone who is more hardware oriented could advise on that point. Whatever the hardware might be, it would be great to put out the specification openly, so multiple coders could submit their own display routines. 2 1 Quote Link to comment Share on other sites More sharing options...
+Stephen Posted August 19, 2020 Share Posted August 19, 2020 18 hours ago, RevEng said: The plasma code is just a simple collision between 2 vertical sine waves, and 2 horizontal sine waves, so it's pretty basic and periodic. Can you provide a bit more detail of how this works? Are the sine waves just used to select a colour AND position? Quote Link to comment Share on other sites More sharing options...
RevEng Posted August 19, 2020 Author Share Posted August 19, 2020 Sure, no problem. There's an outer Y loop and and inner X loop, where I run through each character position, and do a bunch of sine addition for the index at that particular location. Between frames the sines advance. The vertical component is 2 waves that are out of phase. The vertical component on it's own looks like this: vertical plasma component, via JS7800 online emulator The horizontal component is also 2 (different) waves that are out of phase. On it's own it looks like this: horizontal plasma component, via JS7800 online emulator When the components are added together, the interference of both vertical and horizontal waves is what makes a basic dull plasma. Think of this as a height map. To liven up the dull plasma, I take the height map value and use it in a sine table lookup to get the actual shade of grey. (the shades are just dithered characters running from dark->light->dark) If your sine table is 256 bytes long, this has the added advantage that you don't need to worry much about values that go past 255, when you're adding the sine components together. Similarly, you can intentionally overflow 255, and get a plasma display that's more stripey. There's a pretty good overview at this site. (it uses javascript, but the concepts are well illustrated) I'll eventually release the source for the plasma, but I need to clean it up and comment it out a bit. plasma-y-only.a78 plasma-x-only.a78 6 1 Quote Link to comment Share on other sites More sharing options...
RevEng Posted October 4, 2020 Author Share Posted October 4, 2020 I've added a flame effect to the demo (select switch to change between the two effects) and changed the display over to 160a. I've renamed the demo to "lava", since it's no longer just a plasma. I may eventually add some other effects. Source is included, in case anybody is interested. You can also view the demo in-browser via the excellent JS7800 emulator. lava.bas.a78 lava.bas.bin lava.zip 6 Quote Link to comment Share on other sites More sharing options...
+DrVenkman Posted October 4, 2020 Share Posted October 4, 2020 Given any more though to the idea of a “Atari 7800 Video Music Cart” with this code and a 3.5mm Audio In jack, or maybe reading audio in from the Expansion Port? I’d buy something like that in a heartbeat. Quote Link to comment Share on other sites More sharing options...
RevEng Posted October 4, 2020 Author Share Posted October 4, 2020 I've given it thought, but I haven't genuinely worked toward it. While I dabble in hardware with microcontrollers, logic probes, know my way around a schematic, etc., I'm more software than hardware, so hardware tends to be a time suck for me. When life is a bit less busy I might try my hand at prototyping something for the joystick port. (though I'd be happy if someone else beats me to it.) I think the best approach here is to go cross platform and more or less just allow a low pass filter and a high pass filter to drive the joystick lines. That way the hardware would be bigger than our community, giving it more visibility and lifespan. There could be video music projects for the 7800, 2600, A8, C64, Vectrex, or whatever. Software is always easy once the hardware is there and documented. 1 Quote Link to comment Share on other sites More sharing options...
RevEng Posted October 4, 2020 Author Share Posted October 4, 2020 Also, if anybody is interested in lower level info for the Flame effect, I based it on the classic PC fire effect. The only main difference between mine and PC one is is the random seeding of the bottom row. Due to the coarse resolution, this didn't give as nice of a flame effect as it does on the PC. To make mine more flamey, I do a combination of random seeding and sine interference on the bottom row. 2 Quote Link to comment Share on other sites More sharing options...
SlidellMan Posted October 4, 2020 Share Posted October 4, 2020 Reminds me of Earthbound. 1 Quote Link to comment Share on other sites More sharing options...
