IntyBASIC Programming Contest 2020 Rules
On 8/20/2020 at 1:23 PM, decle said:
 Yes, there is and happily it is trivial.  All you need to do is write a value to one of the GRAM alias addresses (e.g. $3c00) and then read from the equivalent base GRAM address (in this case $3800).  If you can see the data you wrote there is no additional GRAM.  If you want to be super careful you clear the base GRAM address first.  So something like:
wait
poke $3800, $00
poke $3c00, $aa
if (peek($3800) = $aa) then
	' No additional GRAM :(
else
	' Party on dude! :)
end if
Thank you for this!  What about autodetecting:
  • The EXEC type (INTV-I, INTV-II, Sears, etc)
  • "REX" (Tutorvision's expanded EXEC)
  • GROM type (standard or Tutorvision)
  • IntelliVoice
I assume these are already documented somewhere.  Perhaps they could be added to IntyBASIC at some point.
Probably keep a copy of the GROM Letter on cartridge ROM and compare it against the GROM graphic.  If it match, it's the original GROM, if it doesn't match, more likely Tutorvision or the MiniGROM.
To answer my own question for autodetecting TutorVision GROM, I used:
IF PEEK($31f8) THEN
	' Standard GROM
ELSE
	' TutorVision GROM
END IF
GROM begins at $3000.  The offset of $1f8 is the top pixel row of the left arrow graphic.  It turns out the TutorVision arrows are narrower than the ones in standard GROM.
IF PEEK($31f8) THEN
	' Standard GROM
ELSE
	' TutorVision GROM
END IF
Nice, thanks for sharing!
