Retro_Game_Lover96 Posted August 25, 2020 Share Posted August 25, 2020 Hi, I have bought an RGB mod kit for my six switch 2600, I have installed and tested it with composite, but the screen is all messed up. Maybe it could be a bad tia or something that caused it. Quote Link to comment Share on other sites More sharing options...
+Nathan Strum Posted August 25, 2020 Share Posted August 25, 2020 Unplug the mod. Plug the TIA back into the 2600, and test the system using RF out. If it works, the TIA is fine and the issue is with the RGB mod or how it's installed. If the TIA is fine, go through the mod and check every connection with a multimeter for continuity, and make sure there are no shorts. Quote Link to comment Share on other sites More sharing options...
Retro_Game_Lover96 Posted August 26, 2020 Author Share Posted August 26, 2020 38 minutes ago, Nathan Strum said: Unplug the mod. Plug the TIA back into the 2600, and test the system using RF out. If it works, the TIA is fine and the issue is with the RGB mod or how it's installed. If the TIA is fine, go through the mod and check every connection with a multimeter for continuity, and make sure there are no shorts. Before I did the RGB mod, the TIA chip is fine while it originally has a composite mod. Quote Link to comment Share on other sites More sharing options...
ApolloBoy Posted August 26, 2020 Share Posted August 26, 2020 What are your solder joints like on both the motherboard and 2600RGB ends? You may have a cold joint or two causing these issues, and I can already see that some of your joints don't look too great. Try hitting them up with some flux and remove any excess solder if you need to. Also exactly what type of solder are you using? Quote Link to comment Share on other sites More sharing options...
Retro_Game_Lover96 Posted September 8, 2020 Author Share Posted September 8, 2020 (edited) Help! I’ve tried to install the mod, but the led is not blinking! It was working earlier. Edited September 8, 2020 by Retro_Game_Lover96 Quote Link to comment Share on other sites More sharing options...
