TheObscureGamer Posted August 29, 2020 Share Posted August 29, 2020 (edited) Moved some stuff around and cant find the original AV cables(I never had AV cables for my Genesis and I played it before on this TV so i guess i switched the TV to channel 3/4) so i triesd hooking it up with the cord labelled TV on the rf cable to the back of my flatscreen and nothing. Im now thinking I need to change it to channel 3/4 because its not av cables nor component(one of the TV modes says AV/Component) but i don't know where the remote is so i cant fricking play any of my Gamecube games or few Genesis games smh. It says on the RF thing AV so maybe i can just change it to AV/Component but im doing it wrong? I have this thing which i forgot what i used it for since i have not used it in like 9-10 years and maybe that will work but im not even sure what cord it uses as it has no label on it to tell me what voltage it is. Edited August 29, 2020 by TheObscureGamer Quote Link to comment Share on other sites More sharing options...
Tanooki Posted August 29, 2020 Share Posted August 29, 2020 That box you have there seems to have an ac adapter port, may be your problem is a lack of power? You should be able to take the RF modulator plug on one end from the console and the other into that convertor box, and then the RCA cable off that to the RCA port on the TV and it should work, but if that's what you're doing maybe the lack of a power supply is it. Quote Link to comment Share on other sites More sharing options...
TheObscureGamer Posted August 29, 2020 Author Share Posted August 29, 2020 6 minutes ago, Tanooki said: That box you have there seems to have an ac adapter port, may be your problem is a lack of power? You should be able to take the RF modulator plug on one end from the console and the other into that convertor box, and then the RCA cable off that to the RCA port on the TV and it should work, but if that's what you're doing maybe the lack of a power supply is it. I know but it does not have anywhere on it what power supply voltage it uses and i have a power supply that can go from 3 to 12 volts(well 3, 4.5,6,7.5,9 and 12 volts) but none work on it(assuming i screw in the screwy cord with one part into the RF thing and the other into the to tv. Thing of the converter box thing is correct) Quote Link to comment Share on other sites More sharing options...
DragonGrafx-16 Posted August 29, 2020 Share Posted August 29, 2020 Just get Genesis and Game Cube composite cables. And if you happen to have a smartphone with an infrared sensor you could download a remote app and use that as the remote. 1 Quote Link to comment Share on other sites More sharing options...
mr_me Posted August 29, 2020 Share Posted August 29, 2020 (edited) With the Genesis, the rca connector on it is RF out. That goes straight to the antenna/RF input on your TV. Don't connect it anywhere else. And yes, tune to analog channel 3 or 4. Get a genesis din av cable and go composite. Edited August 29, 2020 by mr_me Quote Link to comment Share on other sites More sharing options...
DragonGrafx-16 Posted August 29, 2020 Share Posted August 29, 2020 If it's a model 1 Genesis you'll need a 1/8" to stereo RCA cable if you want stereo sound. Quote Link to comment Share on other sites More sharing options...
NinjaWarrior Posted August 31, 2020 Share Posted August 31, 2020 1st off, You're trying to hook it up to a HDTV Just get a CRT with the Coaxial, and hook it up there 1 Quote Link to comment Share on other sites More sharing options...
