+hloberg Posted September 5, 2020 Share Posted September 5, 2020 here is a way to get a clear picture that I haven't heard of. It looks to work really well. https://netzhansa.com/ti99-4a-color/ he uses a https://tms-rgb.com/ AA discussion in Coleco section: and then an upscaler to get the sync. Looks like a good idea. 3 Quote Link to comment Share on other sites More sharing options...
+jedimatt42 Posted September 5, 2020 Share Posted September 5, 2020 Now the demand for PAL 4A's will go up 1 Quote Link to comment Share on other sites More sharing options...
+hloberg Posted September 5, 2020 Author Share Posted September 5, 2020 Looks like someone has already been discussing it to some extent. 1 Quote Link to comment Share on other sites More sharing options...
ChildOfCv Posted September 6, 2020 Share Posted September 6, 2020 Yeah, though that one used the 9918 originally, so it needed some more TLC than a 9929 board would. On the good side, this means it is now possible to mod either version. Quote Link to comment Share on other sites More sharing options...
+OLD CS1 Posted September 8, 2020 Share Posted September 8, 2020 For this, I could just sit a 9928A in a socket with the appropriate pins shunted. Price depending, might be a neat mod for me. 2 Quote Link to comment Share on other sites More sharing options...
JJB Posted January 26, 2021 Share Posted January 26, 2021 Just confirming that TMS RGB works very well in my US TI after replacing the TMS9918A with a TMS9928A I purchased from Ebay. Pin 38 (CPUCLK) wasn't used for the sound processor so I just terminated it with a 560R resistor, same with pin 35 (EXTVDP). The composite video signal from pin 36 goes to a inductor (L202) first, I cut the incoming side and bent it out of the way. Right under that inductor is an unused wire link which can be conveniently used to terminate pin 36 with another 560R resistor. I re-used the existing TI video connector to provide RGB out and made a custom DIN - SCART cable to connect to a cheap RGB - HDMI converter. SCART needs a positive potential on pin 16 (Fast Switching) to select RGB instead of CVIDEO but with a 5-pin DIN I didn't have a spare pin to carry 5V from the console. I just opened up the converter and connected pin 16 internally to a suitable 5V point via a current-limiting resistor. Cheers, Jochen 3 Quote Link to comment Share on other sites More sharing options...
macsonny Posted January 19 Share Posted January 19 On 1/26/2021 at 4:37 PM, JJB said: Just confirming that TMS RGB works very well in my US TI after replacing the TMS9918A with a TMS9928A I purchased from Ebay. Pin 38 (CPUCLK) wasn't used for the sound processor so I just terminated it with a 560R resistor, same with pin 35 (EXTVDP). The composite video signal from pin 36 goes to a inductor (L202) first, I cut the incoming side and bent it out of the way. Right under that inductor is an unused wire link which can be conveniently used to terminate pin 36 with another 560R resistor. I re-used the existing TI video connector to provide RGB out and made a custom DIN - SCART cable to connect to a cheap RGB - HDMI converter. SCART needs a positive potential on pin 16 (Fast Switching) to select RGB instead of CVIDEO but with a 5-pin DIN I didn't have a spare pin to carry 5V from the console. I just opened up the converter and connected pin 16 internally to a suitable 5V point via a current-limiting resistor. Cheers, Jochen What was the wiring for your SCART to DIN ? Quote Link to comment Share on other sites More sharing options...
JJB Posted January 21 Share Posted January 21 Let me check Quote Link to comment Share on other sites More sharing options...
JJB Posted January 22 Share Posted January 22 4 hours ago, JJB said: Let me check WARNING!!! on an unmodified console pin 1 carries 12V, you don't want to connect that through! Make sure it's properly disconnected in the console; I am not responsible for blowing up your TI / Scaler / both or any other precious equipment 🙂 I think ideally you should have a separate ground for audio (I have a faint audio hum from supposedly a ground loop) but with only 5-pin connector choices are limited. I guess PAL machines have 6 pins so easy to add a separate ground. My first cable used standard wiring and I did get some interference. I made a 2nd cable using an old VGA cable (COAX based), it did make a difference. It is fiddly to say the least to try to fit such a cable in a DIN harness, but it can be done. TIP: secure the DIN internals with hot glue (after testing ). 4 Quote Link to comment Share on other sites More sharing options...
macsonny Posted January 24 Share Posted January 24 On 1/22/2023 at 3:10 PM, JJB said: WARNING!!! on an unmodified console pin 1 carries 12V, you don't want to connect that through! Make sure it's properly disconnected in the console; I am not responsible for blowing up your TI / Scaler / both or any other precious equipment 🙂 I think ideally you should have a separate ground for audio (I have a faint audio hum from supposedly a ground loop) but with only 5-pin connector choices are limited. I guess PAL machines have 6 pins so easy to add a separate ground. My first cable used standard wiring and I did get some interference. I made a 2nd cable using an old VGA cable (COAX based), it did make a difference. It is fiddly to say the least to try to fit such a cable in a DIN harness, but it can be done. TIP: secure the DIN internals with hot glue (after testing ). Thanks. Worked a treat. Appreciate the guidance. 1 1 Quote Link to comment Share on other sites More sharing options...
