VW Posted September 17, 2020 Share Posted September 17, 2020 I have been trying for quite a while to copy some of my old Atari disks to ATR files and have been having an awful time. I tried HiassofT's atarisio linux package on both Linux and Raspberry Pi and while atariserver works great on my Pi 4 with a USB-Serial adapter and my old SIO2PC cable, I cannot get atarixfer to work either on the Pi or a real linux machine with a serial port. On the Pi with a USB-Serial converter going to an old 10502PC cable, the copying goes very slowly and only works on a disc where the data is loaded in consecutive sectors (like an Infocom side 1). All other discs I can hear the drive switch tracks around while reading which shouldn't be happening and while I end up with an ATR, it is garbage and unusable. I was annoyed enough by this to buy a serial port for the Pi but atarixfer and atariserver can't seem to use it. I read all the instructions about enabling the serial port and disabling the console on the Pi. I tested my serial port using minicom and the full-featured UART (ttyAMA0) using an old Cisco router and console management cable and it worked so I'm pretty sure my serial port on the Pi is hooked up properly. I think my 1050 is still working since I can boot games directly on my 800XL and they work. None of the atari Rpi programs will see my serial port and I was wondering what more I could do to get this to work. Quote Link to comment Share on other sites More sharing options...
+SenorRossie Posted October 26, 2020 Share Posted October 26, 2020 Do you have a level converter in place between the Atari hardware and the pi? The 8bit computer section of the forum has several posts on the subject, eg: As for the tools you can use on the pi to emulate the SIO device, there are several. The classic sio2bsd, atarixfer and respeqt to name the most commonly used. Quote Link to comment Share on other sites More sharing options...
