Atari8guy Posted October 29, 2020 Share Posted October 29, 2020 Is there a size restriction? Quote Link to comment Share on other sites More sharing options...
tschak909 Posted October 29, 2020 Author Share Posted October 29, 2020 (edited) I've reliably used a 64GB SanDisk, but I had to format it explicitly for FAT32 with a third party formatting program, as Windows wants to format anything bigger than 32GB as ExFAT, which anything ESP32 based WILL NOT READ. But again, it's _REALLY_ silly to use anything more than say, 8GB or so with an 8-bit, you'll never ever fill it. (and yes, I am fully prepared to eat those words) -Thom Edited October 29, 2020 by tschak909 2 Quote Link to comment Share on other sites More sharing options...
Atari8guy Posted October 30, 2020 Share Posted October 30, 2020 I agree about the size, but I've just purchased 5 16 GB ones because the price was the same as the 8 GB (5 bucks each) and you never know..... I was just slightly panicking that 16GB was too large. Good to know. By the by: this is an awesome project and I really appreciate all the work you and the team put into it. Wish I had skills. 1 Quote Link to comment Share on other sites More sharing options...
Mi1ez Posted January 5, 2021 Share Posted January 5, 2021 Is there any way to delete disk images from the SD card from the manager without having to pop out the SD card and putting it onto my laptop to delete/manage? It seems odd not to have some kind of SD card management available straight on the system so that we don't have to travel between systems by sneakernet. If not.. I'll have to see if I can write one up--it's sorely missing. Also... HUGE thanks! As a long-time Atari enthusiast who was a network engineer in a former life back in Silicon Valley... This is a GREAT device with enormous potential! 2 Quote Link to comment Share on other sites More sharing options...
tschak909 Posted January 5, 2021 Author Share Posted January 5, 2021 If you want to take a crack at adding it, the code is here: https://github.com/FujiNetWIFI/fujinet-config -Thom 1 Quote Link to comment Share on other sites More sharing options...
spicyjack Posted June 4, 2021 Share Posted June 4, 2021 On 10/29/2020 at 7:50 AM, tschak909 said: Yup, the 128GB card is too big. -Thom What would be the maximum SD Card size? 32GB, 64GB, or ??? Quote Link to comment Share on other sites More sharing options...
tschak909 Posted June 4, 2021 Author Share Posted June 4, 2021 64GB. Windows will also try to format anything bigger than 32GB as ExFAT. -Thom Quote Link to comment Share on other sites More sharing options...
spicyjack Posted June 4, 2021 Share Posted June 4, 2021 5 hours ago, tschak909 said: 64GB. Windows will also try to format anything bigger than 32GB as ExFAT. -Thom Excellent, thanks for the reply, I wanted to submit an issue for adding a SD Card section to the Quickstart guide Quote Link to comment Share on other sites More sharing options...
BigBen Posted August 23, 2021 Share Posted August 23, 2021 A 200 GByte SD card formatted with FAT32 also works in the FujiNet adapter. I use the card with many movies in the AVGCard. ATR and XEX files can be loaded without any problems. Unfortunately, Windows only formats SD cards over 32 Gbytes in extFat. I formatted the SD with a Macbook. Quote Link to comment Share on other sites More sharing options...
+Mr Robot Posted August 23, 2021 Share Posted August 23, 2021 What size blocks do you get on a 200GB card formatted as fat32? Quote Link to comment Share on other sites More sharing options...
BigBen Posted August 24, 2021 Share Posted August 24, 2021 On 8/23/2021 at 10:37 PM, Mr Robot said: What size blocks do you get on a 200GB card formatted as fat32? Unfortunately, I cannot provide any information on this. I just don't have a program for it under Windows. Do you have any ideas? Quote Link to comment Share on other sites More sharing options...
+Mr Robot Posted August 24, 2021 Share Posted August 24, 2021 A quick google found this http://ridgecrop.co.uk/index.htm?guiformat.htm no idea if it works, I'm a mac user so I don't have these problems. Apparently you can use powershell as well. It looks like for a disk over 32GB you will get a 32k cluster size which for all those tiny little atari files is going to be quite wasteful Quote Link to comment Share on other sites More sharing options...
tschak909 Posted August 24, 2021 Author Share Posted August 24, 2021 There really is zero point of using anything more than a 2GB card with any of these devices. 1 Quote Link to comment Share on other sites More sharing options...
bfollowell Posted August 25, 2021 Share Posted August 25, 2021 On 8/23/2021 at 2:03 PM, BigBen said: A 200 GByte SD card formatted with FAT32 also works in the FujiNet adapter. I use the card with many movies in the AVGCard. ATR and XEX files can be loaded without any problems. Unfortunately, Windows only formats SD cards over 32 Gbytes in extFat. I formatted the SD with a Macbook. Natively, with it's own built-in tools, but you can easily format larger drives as FAT32 with readily available tools. I've formatted 256GB cards as FAT32 for use in a Nintendo Switch. Quote Link to comment Share on other sites More sharing options...
BigBen Posted August 25, 2021 Share Posted August 25, 2021 23 hours ago, Mr Robot said: A quick google found this http://ridgecrop.co.uk/index.htm?guiformat.htm no idea if it works, I'm a mac user so I don't have these problems. Apparently you can use powershell as well. It looks like for a disk over 32GB you will get a 32k cluster size which for all those tiny little atari files is going to be quite wasteful Here is the result ... FSCTL_ALLOW_EXTENDED_DASD_IO OK GuiFormat version 1.02 x86 Windows version 0602 64 bit Size : 196GB 384471040 sectors 512 Bytes Per Sector, Cluster size 32768 bytes Volume ID is 1df5:2260 32 Reserved Sectors, 46922 Sectors per FAT, 2 fats 6005893 Total clusters 6005892 Free Clusters Formatting drive F:\:... Clearing out 93940 sectors for Reserved sectors, fats and root cluster... Wrote 48097280 bytes in 2.64 seconds, 17.36 Megabytes/sec Initialising reserved sectors and FATs... Done Quote Link to comment Share on other sites More sharing options...
+Mr Robot Posted August 25, 2021 Share Posted August 25, 2021 Yep, 32K clusters, even "1K ATASCII Blaster" will take up 32k on the disk. The ATR's are ok, only 6 bytes wasted each but those XEX files are going to eat a lot of extra space. With a 16GB disk you get 8K clusters which is much more reasonable for wastage. Ideally you'd wat an 8GB disk (4k cluster) but you 16gb for $1 more so who cares if a little gets wasted. Just my 2¢ Quote Link to comment Share on other sites More sharing options...
BigBen Posted August 26, 2021 Share Posted August 26, 2021 23 hours ago, Mr Robot said: Yep, 32K clusters, even "1K ATASCII Blaster" will take up 32k on the disk. The ATR's are ok, only 6 bytes wasted each but those XEX files are going to eat a lot of extra space. With a 16GB disk you get 8K clusters which is much more reasonable for wastage. Ideally you'd wat an 8GB disk (4k cluster) but you 16gb for $1 more so who cares if a little gets wasted. Just my 2¢ I need the 200 GB SD card for the movies for the AVGCart. With smaller SD cards, you can quickly become a disc jockey with the question of which card was the film on? The SD was only € 20 ($ 23.5) and I can now use it with other Atari peripherals. 4 Quote Link to comment Share on other sites More sharing options...
+Mr Robot Posted August 26, 2021 Share Posted August 26, 2021 Yep avf files will quickly fill up a 16gb disk. You win 1 Quote Link to comment Share on other sites More sharing options...
