+acadiel Posted January 31, 2021 Author Share Posted January 31, 2021 Pins to figure out/verify: Pin 6 is GND on the Tutor and HOLD/ in Pyuuta. Same? Pin 8 - is this CRUOUT on the Tutor too? Pin 20 - Does E000/ on the Tutor mean IOPORT/ on the Pyuuta? Pin 31 - is this CPUCLK/ on the Tutor too? Pin 33 - is this EC/ on the Tutor too? Pin 35 - Does Tutor MEMORY on the Tutor mean SELEXM on the Pyuuta? Pin 36 - Does Tutor 0000-3FFF/ on the Tutor mean ROMCLK on the Pyuuta? Pin 38 - Does Tutor GROM SEL E4XX/ mean the same as EXP0/ on the Pyuuta? Pin 39 - Does Tutor GROM CLK mean the same as EXP1/ on the Pyuuta? Pin 40 - Does Tutor VDP/ mean the same as EXP2/ on the Pyuuta? Pin 41 - Does Tutor SOUND/ mean the same as EXP3/ on the Pyuuta? Pin 42 - (This is probably the same) Pin 43 - (This is probably the same) Pin 44 - (This is probably the same) Pin 45 - (This is probably the same) Pin 47 - Does Tutor CRUIN/ mean the same as LAQHOLA on the Pyuuta? Pin 48 - This is Vbb (-5V) on the Tutor and KILL SROM/ on the Pyuuta. Possible damage if JP KILL is used on Tutor. Quote Link to comment Share on other sites More sharing options...
