Trigger58 Posted November 12, 2020 Share Posted November 12, 2020 Hello, i have a Problem with my 3DO FZ-1. It seems that the IC400 Backup Control chip for the SRAM is faulty. Even if the System try to Access the SRAM (for Save Games) the 3DO do a reset. If i start the game Virtuoso, then i get the message, that the SRAM is not found. I changed the SRAM Chip but i get the same error. The Battery is still in good condition and has 3V. I think the IC400 is corrupt. It is an BA6162 Reset IC with Battery Backup function. Does anybody know where to buy a compatible one? Quote Link to comment Share on other sites More sharing options...
Trigger58 Posted November 12, 2020 Author Share Posted November 12, 2020 (edited) This thread can be closed. I found the failure. The IC400 is still working. I used a Multimeter and checked all solder pads and sram pins first. All fine. Then i checked every sram pin and traced All lines to the next points and then i found the failure. Pin 17 & 18 were not connected. It seems that the lines behind the solder pads from 17 & 18 were broken but not visible because the are lying under the sram. I soldered a wire on both Pins and connected them to the next points on the backside and now all works fine again Edited November 12, 2020 by Trigger58 2 Quote Link to comment Share on other sites More sharing options...
