How to detect PAL/NTSC machines
Is there a way to detect if a TI99 is a PAL or a NTSC version? While testing on the real machine some of  the BASIC games I've compiled, I've noticed that on my PAL machine they are a little slower than running on the emulator (set on NTSC). So I would like to try to differentiate the delay added on the code based on the machine version.
https://forums.atariage.com/topic/313534-how-to-detect-palntsc-machines/
- In Extended Basic, let a sprite move across the screen and measure the time until it reaches some goal.
- In assembly language, poll CRU line 2 and check how many iterations it takes until the line is down (normally up).
Is there a way to check the CRU from XB? The test with the sprite would be ok for a brand new program (e.g. during the game title), but not feasible if you want to compile an existent one.
54 minutes ago, Asmusr said:
Does compiling make the difference between NTSC and PAL bigger?
These legacy games were not designed to by compiled, so it's necessary to place some delays on CALL KEY/JOYST and HCHAR/VCHAR instructions to make the game playable.
Usually from 2 to 4 frames of delay is enough for KEY/JOYST, while for HCHAR/VCHAR it depends on the game. To compile I'm using the emulator set to NTSC (so 60hz) and the tuning was done on such setup. When I've tested some compiled games on my PAL TI99 I was able to notice the difference. Nothing severe, however why not trying to see if this can be improved? So, this is the reason of the question.
The reason I'm asking is that the only difference between NTSC and PAL with respect to speed should be when something is interrupt driven, which for XB means sprite movement or sound. And I would assume the difference is the same compiled or not.
For a minimal impact, one could do that with a sprite color that blends with the background.
10 CALL SPRITE(#1,42,8,96,1,0,10)
20 A=0
30 CALL POSITION(#1,X,Y)
40 A=A+1
50 IF Y<20 THEN 30
60 IF A>15 THEN PRINT "PAL/50 Hz" ELSE PRINT "NTSC/60 Hz"
Accessing CRU is only possible via machine language programs.
20 A=0
40 A=A+1
50 IF Y<20 THEN 30
Thanks!
The sprite speed should be the same, but the value that the BASIC code counts up to while timing would change. :)
3 hours ago, sometimes99er said:
The ISR is called 50 versus 60 times a second, so how would the sprite speed be the same ? :)
The question was compiled XB versus not compiled.
(Edit: Well, there were two overlapping questions, I guess, but that's the one I was answering ;) ).
Edited by Tursi
RXB has a command CALL IO that can talk to any CRU address but some care may be required on some that might interfere with GPL or OS.
A WIFI Weather Station is any example of it being used on a TI99/4A using XB language.
