FujiNet on PC?
apc
Sorry for the heretical question. The FujiNet software, the part which is run on the hardware module, how difficult it can be to compile it (port?) and run it on PC?
I believe, for SIO2PC (+RespeQt) users it would be interesting alternative. Maybe as a standalone headless "service" (full port) or just new N: device functionality added to RespeQt.
What do you think?
No sure, I can do it myself. Let's check the code and I will see ;-)
FujiNet is very nice project or better, multiple projects to make all those pieces (hardware, software for it, software for Atari, TNFS, ...) working together. Thanks for the effort, time, ideas and sharing all that with us!
Jan
  • 1 month later...
OK, I did first step. Some sources updated to compile and run on Linux. It's minimum functionality (SD/local host, disk emulation with ATR and XEX), but it seems it can work :)
Fujinet "port" started on old notebook connected via serial port with Atari
FujiNet Config boot
Firts time start and fake WiFi presented to Atari (networking is configured on OS/Linux)
SD (directory on Linux) added to hosts and some disk drive mounted
Booting up XEX from notebook
Config screen without real Fujinet hardware
I need to fix the Atari (keyboard is dying on my XL). Then I am looking forward to port/play with NET part of FujiNET! :)
Jan
  • Like 12
  • 2 weeks later...
Thank you for nice feedback :)
I like the idea of FujiNet library, but the path is quite long ... I am doing just small changes to the original code to compile that and run it on Linux (and hopefully others too, later). For the library, more design changes would be necessary. It's next level ;-)
Modem emulation was ported.
I never used modem with Atari before. I like it.
@Thom nice to see telnet protocol and terminal emulation in action!
Some fun with FujiNet emulated modem:
Running Ice-T, enabling VT100 and telnet, connecting to the laptop
Desktop Terminal sharing - Atari joined the screen session (GNU Screen) which is running on laptop.
Coding in vim ...
... and building
Jan
  • Like 6
  • 3 weeks later...
Hi,
@phigan I have no exp. with Raspberries but it should be possible to compile it for ARM based Linux. The dependencies are Linux kernel with serial port driver, glibc (not tested with other libc) and TCP/IP working on a host.
Better to call it (Linux) port instead of build. FujiNet is ESP32 based and it relies on framework provided by PlatformIO (file system drivers, UART, timers, tasks, lwIP, HTTP server, ...). To get it running on Linux (and others) all these needs to be replaced by some functional equivalents. To you first question: lot of small changes ... work in progress. It's time to think about GitHub account ?
Changes since last post: access remote hosts/images via TNFS protocol (somehow) works, printer emulation added, web interface (http server) works
Jan
4 hours ago, apc said:
Hi,
Jan
Do you want access to the fujinet github? We can add a sub-repo.
-Thom
  • 3 weeks later...
Added basic browser into web interface.
Click host name to open host browser:
01.thumb.png.b2b3150ce54626b889c533a33320c962.png 02.thumb.png.d172de9e0f6c140a8488b0489da923f8.png
"Navigation bar":
Mounting and unmounting images:
06.thumb.png.5c72e425fd9cb950412451b79a86acd5.png07.thumb.png.be4b12d3f081c045fbbbd3430f14aadd.png08.thumb.png.ea48542dfabb1bcbc8c3699e756a0d14.png
Downloading file:
Jan
BTW WOW to Albert !!! I thought my XE is 8-bit :-D
Edited by apc
  • Like 4
Oh yes me too :-) That's the reason I have started with it!
The small issue with N: is that it uses one extra signal (PROCEED PIN) which is not carried by standard SIO2PC adapter (at least not on my home made from 90's).
I think, for the old MAX232 it would be possible to wire unused receiver. I am not sure if some more recent SIO2USB adapters (available on the internet) can pass this signal? Anyone knows?
Jan
  • 2 weeks later...
7 hours ago, phigan said:
I'm using it from my Raspberry Pi 4 desktop. This is better than AspeQT or APE or any of that :)
Nice! Cross compiled on x86 or compiled on Raspberry/arm?
Which pin on SIO port would PROCEED pin go to?
DTR or RTS converted to TTL to SIO PIN 9
(http://mixinc.net/atari/pinouts/sio.htm)
Jan
Edited by apc
Compiled directly on it. I even just built it on the Pi Zero and not even one warning.
Thanks! I have CTS already going to COMMAND (had to edit fnconfig.ini for that) and I added DTR to PROCEED. I'm not sure if PROCEED is making it work any differently, but it's doing well so far!
Not yet. PROC is used by N device handler and I am at the beginning to make N protocols working on PC.
