AquaLite 1.11
2 hours ago, jltursan said:
Yep, this one works fine. I'm trying to test the MicroExpander emulation but just after enabling the option the emulator hangs with a MVC++ Debug error ""abort() has been called". Do I need the USB Basic rom placed somewhere?
I've clearly had a bad day today...
I've attached a zipfile, put the usb folder in the AquaLite folder and put the aqubasic.rom in the roms folder. The usb folder is lots of files to play with and listen to.
expander files.zip
Yes, this works and seems to emulate the MicroExpander faithfully!, thanks!
Just a minor annoying behaviour...seems that the MicroExpander setting is disabled after closing the emulator; but the 32KB RAM expansion automatically enabled by the expander, remains. So, you need to setup the RAM expansion to none and enable MicroExpander again every time...
It's intentional that you have to enable the MicroExpander at boot time but I noticed it was saving it's settings on close down and then I did nothing about it!!! I'll put a fix in place. The only thing the MicroExpander can't do is save files, I'm not really sure how to do that, I suspect it would involve a bit of ROM patching.
  • 2 years later...
Hi, just for clearing:
Is there a way to start from command line including the game path?
The options "keyboard emulates hand controller" and "controller enabled" get lost when shutting down AquaLite, I've checked the .ini and there are some options
opt_emulation_speed=100
opt_exit_msg=1
opt_auto_load=1
opt_pc_keyb=1
opt_focus_on=0
opt_timing_type=1
And noticed there is nothing related to the controller, is there a option about that can be included manually? I'm triyng to integrate Aqualite into Emultionstation frontend, those options would help... The "controller enabled" function works flawlessly, only it does not saves the configuration when close.
  • 3 months later...
Any chance to add something like "enforce 4:3 aspect ratio" option for both, windowed and fullscreen modes?
Also, there is a way to save .SNA snapshots, but loading them gives a "Tape Error: unknown extension" error.
