Randy Posted November 18, 2020 Share Posted November 18, 2020 Using WHDload, Dungeon Master just not saving my save in the game, did it the first time but ever since its just not saving any progress or new saves, what is the problem here? Using a 1200 for this game, thanks Quote Link to comment Share on other sites More sharing options...
Daedalus2097 Posted November 18, 2020 Share Posted November 18, 2020 Writes to disk are typically cached by WHDLoad until you quit the game. Have you quit the game properly using the WHDLoad hotkey to see if that works? Alternatively, that behaviour can be disabled, but it will cause flashing screens as the saves are conducted. There's also the possibility that the slave isn't fully working. Try updating both WHDLoad *and* the slave to the latest versions and see if that helps. 1 Quote Link to comment Share on other sites More sharing options...
Randy Posted November 18, 2020 Author Share Posted November 18, 2020 9 hours ago, Daedalus2097 said: Writes to disk are typically cached by WHDLoad until you quit the game. Have you quit the game properly using the WHDLoad hotkey to see if that works? Alternatively, that behaviour can be disabled, but it will cause flashing screens as the saves are conducted. There's also the possibility that the slave isn't fully working. Try updating both WHDLoad *and* the slave to the latest versions and see if that helps. Thanks Daedalus, I'll give that a try tonight. Should I save the game and then quit using F10 to make sure the save works rather than continuing to play? Quote Link to comment Share on other sites More sharing options...
Daedalus2097 Posted November 18, 2020 Share Posted November 18, 2020 Yeah, I'd do that as a test first, before you go too far and lose an evening's progress... If you read the WHDLoad readme, you'll find details on setting a tooltype for disabling that behaviour and writing immediately when the game tries to save. IIRC it's NOWRITECACHE, but I can't remember for sure. Quote Link to comment Share on other sites More sharing options...
