Domeshtan Posted November 27, 2020 Share Posted November 27, 2020 Playing around with the idea of trying to do a version of Trench but with vertical scrolling this time. (Never figured out how to get rid of the scanline twitch jumping from the menu into the game on the first.) Anyway, just wondering what is causing the little ship bounce when you are on the far left of the screen. Is it some kind of "align" issue? Also, is it missing a line of VSYNC somehow? Doubt I would have lasers on this one with the width problem. (Lasers worked better scrolling horizontal. Just turn them on and off.) Also with more layers of depth I'm wondering how playable this could be. VerticalTrench85AA.zip 5 Quote Link to comment Share on other sites More sharing options...
+ZeroPage Homebrew Posted November 28, 2020 Share Posted November 28, 2020 Wow, what an incredible perspective, love this redesign of Trench. I'll be including this in tonight's news portion of ZeroPage. - James Quote Link to comment Share on other sites More sharing options...
+Omegamatrix Posted November 28, 2020 Share Posted November 28, 2020 The ship is bouncing because one of the display kernels is updating GRP0 too late, so it is dropped down by one line. Looking at the code there are two things you could do that will make an immediate impact. First put all of your zeropage ram references into seg.u vars instead of hardcoding them. Use "ds" to designate how many bytes so that you can easily do much more than 1 or 2. seg.u vars ORG $80 frameCounter ds 1 ; ds = designate space, 1 byte of ram in this case playerX ds 1 playerY ds 1 gameGrid ds 20 ; 20 bytes of ram The second thing is reducing the multiple kernels for the different playfields. It would be much more managable to make pointers to playfield data you want instead. ; load pointers ldy shipAltitude ; Y = 0 to 6 lda ShipDataPtrLoTab,Y sta spritePtr lda ShipDataPtrHighTab,Y sta spritePtr+1 ldy screenFrameNumber ; Y = 0 to 3 lda Pf0_PtrLoTab,Y sta pf0Gfx lda Pf0_PtrHighTab,Y sta pf0Gfx+1 ; data tables ShipDataPtrLoTab: .byte <ShipData .byte <ShipData2 .byte <ShipData3 .byte <ShipData4 .byte <ShipData5 .byte <ShipData6 .byte <ShipData7 ShipDataPtrLoTab: .byte >ShipData .byte >ShipData2 .byte >ShipData3 .byte >ShipData4 .byte >ShipData5 .byte >ShipData6 .byte >ShipData7 Pf0_PtrLoTab: .byte <Frame1PF0 .byte <Frame2PF0 .byte <Frame3PF0 .byte <Frame4PF0 Pf0_PtrHighTab: .byte >Frame1PF0 .byte >Frame2PF0 .byte >Frame3PF0 .byte >Frame4PF0 Than your kernel becomes: DrawDaScreen: lda (SpritePtr),y sta WSYNC ;------------------- sta GRP0 lda (pf0Gfx),y sta PF0 lda (pf1Gfx),y sta PF1 lda (pf2Gfx),y sta PF2 iny cpy #140 bne DrawDaScreen sta WSYNC ;------------------- lda #0 sta PF0 sta PF1 sta PF2 sta COLUBK sta COLUPF sta WSYNC ;------------------ jmp OScanS 1 Quote Link to comment Share on other sites More sharing options...
Domeshtan Posted November 30, 2020 Author Share Posted November 30, 2020 (edited) Thanks for the advice! Hard to break old habits. I'm used to loading stuff directly in. Haven't used pointers much. Well, I'm sure it can be cleaned up much more but got a non-bouncy version now. I used pointers for PF0,PF1,PF2... At first the bounce just shifted right a little. Rearranged the order then the playfield started getting warped. Moved the WSYNC to the top and it's looking pretty good now. (Still got one scanline on the top flashing on and off but the bounce is fixed). Probably why my car in Retro Racing takes a dip down a scanline at times or the playfield swims. Didn't change all the hard coding yet. VTrench86NoBounce.zip Edited November 30, 2020 by Domeshtan 1 Quote Link to comment Share on other sites More sharing options...
