Asmusr Posted May 27, 2021 Author Share Posted May 27, 2021 2 minutes ago, SteveB said: Touché ... usually nobody follows my suggestions by word... ? So maybe you meant to use the background color used in the image, but Raphael's data model doesn't know anything about foreground and background colors. Each pixel just has a color. Quote Link to comment Share on other sites More sharing options...
SteveB Posted April 2 Share Posted April 2 It seems that the PNG import does not respect the transparent color? When I create a bitmap in Raphael and export it in PNG, GIMP recognizes the transparency. When I import the same PNG again in Raphael, the background gets black, independent of the currently selected colors. Could this be added? I am using GIMP to resize for different distances, but can't get the result back in. Thank you Steve Quote Link to comment Share on other sites More sharing options...
Asmusr Posted April 3 Author Share Posted April 3 17 hours ago, SteveB said: It seems that the PNG import does not respect the transparent color? When I create a bitmap in Raphael and export it in PNG, GIMP recognizes the transparency. When I import the same PNG again in Raphael, the background gets black, independent of the currently selected colors. Could this be added? I am using GIMP to resize for different distances, but can't get the result back in. Thank you Steve I have deployed a fix. 3 Quote Link to comment Share on other sites More sharing options...
retrodroid Posted April 3 Share Posted April 3 I just wanted to mention that I "discovered" this fine utility via organic web search awhile back and have used it successfully for all my game sprite definitions, so thanks! It seems that all roads eventually lead back to @Asmusr! 1 Quote Link to comment Share on other sites More sharing options...
SteveB Posted April 3 Share Posted April 3 2 hours ago, Asmusr said: I have deployed a fix. ACK ... it works with my PNG files, both from GIMP and Raphael itself. Thank you! Steve 1 Quote Link to comment Share on other sites More sharing options...
