webdeck Posted November 28, 2020 Share Posted November 28, 2020 I believe I have managed to recover the majority of data off my 20MB hard drive from over 30 years ago. I worked with the creator of the MFM emulator to add support for drives formatted by the HFDC, after digging up low level docs on the chipset the HFDC uses. The latest release of the MFM Emulator software includes the HFDC support, so if you are looking for a cheaper alternative to the DREM, the MFM emulator is now an option. Knowing your way around a linux command line is required to get the emulator setup and working, however. I plugged in a USB WiFi dongle to the emulator so that I can make backups easily. The cool thing about the MFM Emulator is that you can connect it to a hard drive and do a raw read of it. I performed multiple read passes and assembled them together into one image that was mostly complete with only a few bad sectors remaining. You can tweak the number of retries, and I also enabled micro-stepping the drive heads between read attempts, which helped recover more data. The final trick was to use a plastic stylus and put pressure on the shaft of the stepper motor (wiggling the stylus back and forth while pressing fairly firmly), which helped the drive read better. Now that I have the image, I no longer need the dying drive. I switched the cabling on the emulator, put it into emulation mode, and now it pretends to be up to 3 hard drives (2 read/write, 1 readonly.) Next, I wrote some python code to walk through the disk structures and flag all the problems. I'm happy to share the code if anyone wants to play with it. I had to do some manual sector editing to fix up some corrupted filesystem structures. TI Image Tool was a great help in flagging problems as well. Ultimately, once I fixed everything I could, I used TI Image Tool to create a new blank hard drive image, copied all the files over to the new image to have a nice, pristine copy, and then copied that over to the emulator to use going forward. I tested it both with the Geneve and the TI with the HFDC, and it works well and is much faster than the original hard drive. Sadly, I thought this hard drive had way more data on it than it actually does. Apparently, a lot of my early work was still on floppies, and I have no idea where those floppies are after 30+ years. As it was, I had to make a number of eBay, Arcade Shopper, and Shift838 purchases just to get this far, not to mention repairs to the HFDC, Geneve, and a TI Power Supply, since a lot of my original equipment has been lost to time and many moves. Along the way, I added a TIPI/32K and a FinalGROM, which I would consider essential upgrades these days. I will be uploading my old source code to the developer forum as I have time, to share back to the community. It's all 30+ years old, but maybe there is something that someone will find worth playing with. One thing I did notice is that my Geneve was on version 0.98 of MDOS, and when I tried using the newer version TI Image Tool installed, none of the software I wrote would launch, so I guess things have changed in the MDOS world since I was last developing for it. The programs do run okay in MDOS version 0.98 though. A huge thank you to everyone in the community who helped me get back up and running! -Mike 6 1 Quote Link to comment Share on other sites More sharing options...
+retroclouds Posted November 28, 2020 Share Posted November 28, 2020 Perhaps you can upload your python code to github? 1 Quote Link to comment Share on other sites More sharing options...
+arcadeshopper Posted November 28, 2020 Share Posted November 28, 2020 I believe I have managed to recover the majority of data off my 20MB hard drive from over 30 years ago. I worked with the creator of the MFM emulator to add support for drives formatted by the HFDC, after digging up low level docs on the chipset the HFDC uses. The latest release of the MFM Emulator software includes the HFDC support, so if you are looking for a cheaper alternative to the DREM, the MFM emulator is now an option. Knowing your way around a linux command line is required to get the emulator setup and working, however. I plugged in a USB WiFi dongle to the emulator so that I can make backups easily. The cool thing about the MFM Emulator is that you can connect it to a hard drive and do a raw read of it. I performed multiple read passes and assembled them together into one image that was mostly complete with only a few bad sectors remaining. You can tweak the number of retries, and I also enabled micro-stepping the drive heads between read attempts, which helped recover more data. The final trick was to use a plastic stylus and put pressure on the shaft of the stepper motor (wiggling the stylus back and forth while pressing fairly firmly), which helped the drive read better. Now that I have the image, I no longer need the dying drive. I switched the cabling on the emulator, put it into emulation mode, and now it pretends to be up to 3 hard drives (2 read/write, 1 readonly.) Next, I wrote some python code to walk through the disk structures and flag all the problems. I'm happy to share the code if anyone wants to play with it. I had to do some manual sector editing to fix up some corrupted filesystem structures. TI Image Tool was a great help in flagging problems as well. Ultimately, once I fixed everything I could, I used TI Image Tool to create a new blank hard drive image, copied all the files over to the new image to have a nice, pristine copy, and then copied that over to the emulator to use going forward. I tested it both with the Geneve and the TI with the HFDC, and it works well and is much faster than the original hard drive. Sadly, I thought this hard drive had way more data on it than it actually does. Apparently, a lot of my early work was still on floppies, and I have no idea where those floppies are after 30+ years. As it was, I had to make a number of eBay, Arcade Shopper, and Shift838 purchases just to get this far, not to mention repairs to the HFDC, Geneve, and a TI Power Supply, since a lot of my original equipment has been lost to time and many moves. Along the way, I added a TIPI/32K and a FinalGROM, which I would consider essential upgrades these days. I will be uploading my old source code to the developer forum as I have time, to share back to the community. It's all 30+ years old, but maybe there is something that someone will find worth playing with. One thing I did notice is that my Geneve was on version 0.98 of MDOS, and when I tried using the newer version TI Image Tool installed, none of the software I wrote would launch, so I guess things have changed in the MDOS world since I was last developing for it. The programs do run okay in MDOS version 0.98 though. A huge thank you to everyone in the community who helped me get back up and running! -MikeCool I have one of these and will have to see about updating the sw..Thanks for doing the hard work Sent from my LM-V600 using Tapatalk Quote Link to comment Share on other sites More sharing options...
webdeck Posted November 28, 2020 Author Share Posted November 28, 2020 8 hours ago, retroclouds said: Perhaps you can upload your python code to github? Here it is: https://github.com/webdeck/tidisk.git 4 Quote Link to comment Share on other sites More sharing options...
+9640News Posted November 28, 2020 Share Posted November 28, 2020 Glad to hear you recovered your hard drive image. Beery Quote Link to comment Share on other sites More sharing options...
webdeck Posted November 28, 2020 Author Share Posted November 28, 2020 (edited) Two quick corrections to my original post: The emulator emulates two read/write drives. It does not emulate a third drive. I got confused with the HFDC's capability to have a third read-only drive. This is a better link to the MFM Emulator site. And here is a link to the Decromancer version of the emulator that I purchased fully assembled. -Mike Edited November 28, 2020 by webdeck Quote Link to comment Share on other sites More sharing options...
Shift838 Posted November 28, 2020 Share Posted November 28, 2020 23 minutes ago, webdeck said: Two quick corrections to my original post: The emulator emulates two read/write drives. It does not emulate a third drive. I got confused with the HFDC's capability to have a third read-only drive. This is a better link to the MFM Emulator site. And here is a link to the Decromancer version of the emulator that I purchased fully assembled. -Mike The Decromancer version you purchased was fully assembled and came with a BeagleBone Green also for $125 USD? Quote Link to comment Share on other sites More sharing options...
webdeck Posted November 28, 2020 Author Share Posted November 28, 2020 11 minutes ago, Shift838 said: The Decromancer version you purchased was fully assembled and came with a BeagleBone Green also for $125 USD? Yes, plus shipping. I don't know if he is still selling them - I got one of the last ones from the batch he was making earlier this year. Learn from my painful and expensive lesson - I didn't check the voltage on the power supply I was using and it was putting out over 14V on the 12V line, which fried the DC/DC power converter on the card and the entire BeagleBone Green, so I had to replace the BBG and power converter on mine. Quote Link to comment Share on other sites More sharing options...
+InsaneMultitasker Posted November 28, 2020 Share Posted November 28, 2020 1 hour ago, webdeck said: Two quick corrections to my original post: The emulator emulates two read/write drives. It does not emulate a third drive. I got confused with the HFDC's capability to have a third read-only drive. Quick question - have you been using the Decromancer to write to your emulated drive(s) or have you just been using it primarily for read operations? I'm curious as to the write stability. this looks like a good alternative for my repair system, where my last two real MFM drives are starting to really show their age. I need to keep those drives in good shape for testing the HFDCs, particularly for termination and some of the connecting logic glue that acts differently for certain drives. Quote Link to comment Share on other sites More sharing options...
webdeck Posted November 29, 2020 Author Share Posted November 29, 2020 I have not done extensive write testing, but I have copied some files around, renamed some files, and made directories. 3 Quote Link to comment Share on other sites More sharing options...
RickyDean Posted September 14 Share Posted September 14 Well after these few years, I've finally gotten my emulators completed. Are there any good MFM images out there to be explored, preferably without any private or explicit info. rmation. I doubt any of my hard drives have much to recover and probably most of it is DOS or win 3.11. I don't think my Geneve one survived. Though I will find it and try it. 2 Quote Link to comment Share on other sites More sharing options...
