tschak909 Posted December 4, 2020 Share Posted December 4, 2020 I'm working on a video showing the process I took to make N: relocatable. Hopefully it will be of use to others. Starting with, the needed mark-down of a listing, to find 3 byte addresses within the handler code to relocate. Quote Link to comment Share on other sites More sharing options...
+David_P Posted December 5, 2020 Share Posted December 5, 2020 I seem to recall reading about someone building two versions, with origins at (say) $3000 and $4000, then running a program to identify all the difference, and using that dataset to build the install table. Quote Link to comment Share on other sites More sharing options...
tschak909 Posted December 5, 2020 Author Share Posted December 5, 2020 I will be showing a variation of this in the upcoming video, as well as doing it by hand. 1 Quote Link to comment Share on other sites More sharing options...
+David_P Posted December 6, 2020 Share Posted December 6, 2020 Doing it by hand is hardcore. Quote Link to comment Share on other sites More sharing options...
tschak909 Posted December 6, 2020 Author Share Posted December 6, 2020 Well, in this case, the ACTION! relocator has serious problems with some DOSes which don't keep the IOCB #1 open while loading binary load files (such as SpartaDOS), and the relocator itself is large, so ultimately N: uses a relocator that @flashjazzcat wrote as an example. -Thom Quote Link to comment Share on other sites More sharing options...
thorfdbg Posted December 6, 2020 Share Posted December 6, 2020 1 hour ago, tschak909 said: Well, in this case, the ACTION! relocator has serious problems with some DOSes which don't keep the IOCB #1 open while loading binary load files (such as SpartaDOS), and the relocator itself is large, so ultimately N: uses a relocator that @flashjazzcat wrote as an example. I wonder how this might work. If the DOS loader goes through the init vector ($2E2). If the IOCB is closed, the DOS would have to re-open it every time if the vector is called, and continue from the same offset in the file. Quote Link to comment Share on other sites More sharing options...
