+dhe Posted December 5, 2020 Share Posted December 5, 2020 I've wanted to try assembling one of these, as there isn't very many components. The original YouTube Video can be found here: This takes you to a place, that, I have never been to before: https://easyeda.com/jonn.blanchard/ti99-4a-replacement-power-board_copy_copy_copy_copy Most of these projects usually come with Gerber Files, this comes in an editor? I'm assuming easyeda, must make their money on getting people to sign up for an account, and unless you sign up for an account you can not save files, which is where you would get a gerber of the board from? 5 Quote Link to comment https://forums.atariage.com/topic/314280-new-994a-dc-power-board/ Share on other sites More sharing options...
+dhe Posted December 5, 2020 Author Share Posted December 5, 2020 FWIW - I figured out, you have to go to the fabrication tab, and under that, you can do Gerbers... Minimum order was 5, so I'll be sending the remainder to ArcadeShopper, when they come in. 3 Quote Link to comment https://forums.atariage.com/topic/314280-new-994a-dc-power-board/#findComment-4692372 Share on other sites More sharing options...
unhuman Posted December 7, 2020 Share Posted December 7, 2020 Ohh! If someone sold them assembled.... Quote Link to comment https://forums.atariage.com/topic/314280-new-994a-dc-power-board/#findComment-4693892 Share on other sites More sharing options...
+arcadeshopper Posted December 8, 2020 Share Posted December 8, 2020 On 12/7/2020 at 2:57 PM, unhuman said: Ohh! If someone sold them assembled.... this can be arranged.. 1 2 Quote Link to comment https://forums.atariage.com/topic/314280-new-994a-dc-power-board/#findComment-4694823 Share on other sites More sharing options...
AwkwardPotato Posted December 10, 2020 Share Posted December 10, 2020 Not trying to rain on everyone's parade, but the board design for this power supply is questionable. All the trace widths are 0.18mm -- under the normal operating conditions of the 4A, some of the traces are going to heat up by ~20ºC, and the voltages the motherboard gets are going to be noticeably lower than they should be (possibly causing instability). The traces should really be double that width *at minimum*. Also looks like it feeds +12V into a +12V regulator, which is pointless and/or inadvisable. 3 1 2 Quote Link to comment https://forums.atariage.com/topic/314280-new-994a-dc-power-board/#findComment-4696227 Share on other sites More sharing options...
unhuman Posted December 14, 2020 Share Posted December 14, 2020 On 12/10/2020 at 11:48 AM, AwkwardPotato said: Not trying to rain on everyone's parade, but the board design for this power supply is questionable. All the trace widths are 0.18mm -- under the normal operating conditions of the 4A, some of the traces are going to heat up by ~20ºC, and the voltages the motherboard gets are going to be noticeably lower than they should be (possibly causing instability). The traces should really be double that width *at minimum*. Also looks like it feeds +12V into a +12V regulator, which is pointless and/or inadvisable. Stuff I just don't consider... Thanks for the warnings! 1 Quote Link to comment https://forums.atariage.com/topic/314280-new-994a-dc-power-board/#findComment-4699285 Share on other sites More sharing options...
Shift838 Posted January 11, 2021 Share Posted January 11, 2021 i'm thinking of ordered a few of these for myself when I do my next run of PCB orders. Quote Link to comment https://forums.atariage.com/topic/314280-new-994a-dc-power-board/#findComment-4722244 Share on other sites More sharing options...
Omega-TI Posted January 11, 2021 Share Posted January 11, 2021 (edited) On 12/10/2020 at 8:48 AM, AwkwardPotato said: Not trying to rain on everyone's parade, but the board design for this power supply is questionable. All the trace widths are 0.18mm -- under the normal operating conditions of the 4A, some of the traces are going to heat up by ~20ºC, and the voltages the motherboard gets are going to be noticeably lower than they should be (possibly causing instability). The traces should really be double that width *at minimum*. Also looks like it feeds +12V into a +12V regulator, which is pointless and/or inadvisable. If anyone is planning on designing a similar board that is not "questionable" on trace size or regulation, and will work with the MeanWell power supply, I have one request... a 5v power tap so if the user chooses, they can connect a USB power port. Why? Because it this day and age USB power plugged devices are ubiquitous and having a port on the TI itself could be very useful in the future, if not now. (For example a VGA to HDMI converter) Edited January 11, 2021 by Omega-TI 3 Quote Link to comment https://forums.atariage.com/topic/314280-new-994a-dc-power-board/#findComment-4722329 Share on other sites More sharing options...
Shift838 Posted January 21, 2021 Share Posted January 21, 2021 On 1/11/2021 at 5:37 AM, Omega-TI said: If anyone is planning on designing a similar board that is not "questionable" on trace size or regulation, and will work with the MeanWell power supply, I have one request... a 5v power tap so if the user chooses, they can connect a USB power port. Why? Because it this day and age USB power plugged devices are ubiquitous and having a port on the TI itself could be very useful in the future, if not now. (For example a VGA to HDMI converter) i did a instructional in one of my newsletters (Volume 2, No. 4) of how to add a USB charging port to the existing TI power suppler. Shift838_News_Letter_V2N4.pdf Quote Link to comment https://forums.atariage.com/topic/314280-new-994a-dc-power-board/#findComment-4731484 Share on other sites More sharing options...
+dhe Posted January 21, 2021 Author Share Posted January 21, 2021 I've asked Arcadeshoper to put one together for me, I plan on using it outside the console, to power motherboards outside the case. The PCBs I order, I asked for double copper thickness. Further, there are like a maximum of six traces, worse case I can solder some fairly stout solid core wire to replace all the traces, and track them to the board with hot glue. None of that should of course discourage anyone from creating a better mouse trap. d. 2 Quote Link to comment https://forums.atariage.com/topic/314280-new-994a-dc-power-board/#findComment-4731610 Share on other sites More sharing options...
GDMike Posted January 22, 2021 Share Posted January 22, 2021 (edited) Cool beans Edited January 22, 2021 by GDMike Quote Link to comment https://forums.atariage.com/topic/314280-new-994a-dc-power-board/#findComment-4732013 Share on other sites More sharing options...
Shift838 Posted January 22, 2021 Share Posted January 22, 2021 (edited) 7 hours ago, dhe said: I've asked Arcadeshoper to put one together for me, I plan on using it outside the console, to power motherboards outside the case. The PCBs I order, I asked for double copper thickness. Further, there are like a maximum of six traces, worse case I can solder some fairly stout solid core wire to replace all the traces, and track them to the board with hot glue. None of that should of course discourage anyone from creating a better mouse trap. d. I use one of these to power my all in one 4A/PEB in a pc for the 99/4A. I also have to power up external 99/4A boards as well. HERE And I'm making a 3D case for it too. Edited January 22, 2021 by Shift838 Quote Link to comment https://forums.atariage.com/topic/314280-new-994a-dc-power-board/#findComment-4732084 Share on other sites More sharing options...
