animation value
TXG/MNX
  • 3 weeks later...
On 12/5/2020 at 6:08 PM, CyranoJ said:
ani_once
The problem with ani_once is that after the animation is done, it's gone forever, right? (or is there a way to call or reactivate the image again?)
On 12/5/2020 at 2:03 PM, TXG/MNX said:
Hi,
In the rapinit there is this line:
dc.l    ani_rept                                                            ; animloop
What value shout ani_rept be to use the once option ?
Why not just use R_sprite_animspd and a DIM variable with a frame counter to move the amount of frames you want and then idle it/deactivate the image until (or if) you need it again?
Until you reset the animloop and cur_frame values, and then set sprite_active again.
Your solution above is better though.
